Question about Zebex 90940-RS232-9 Handheld
Are there any components to be checked in vb that i need to check before i can use the barcode? or do i still need to use any dll to use the barcode? i am a beginner in vb6. thank you in advance for the help.
Z-3080 is just a input device via USB, PS2 or RS232. Just plug & play
Posted on Jan 07, 2008
Fix my vb script engine on my computer / Windows 7
Fix Windows Script Host If you are experiencing script host issues, you might notice error messages such as "Library not registered." Script host issues occur when scripting components do not exist in the Windows registry, according to Microsoft. Your version of Windows determines how the missing scripting components affect your system. You can repair script host problems by using your PC's native features.
Press the "Windows" key. Type "cmd" in the dialog box and press "Enter." This will open the Command Prompt. Type the following commands at the prompt one at a time and press "Enter:" regsvr32 %systemroot%\system32\vbscript.dll regsvr32 %systemroot%\system32\jscript.dll regsvr32 %systemroot%\system32\dispex.dll regsvr32 %systemroot%\system32\scrobj.dll regsvr32 %systemroot%\system32\scrrun.dll regsvr32 %systemroot%\system32\wshext.dll regsvr32 %systemroot%\system32\wshom.ocx Exit the Command Prompt. b> Register Components on 64-bit Systems b> Press the "Windows" key. Type "cmd" in the dialog box and press "Enter." This will open the Command Prompt. Type the following commands at the prompt one at a time and press "Enter:" %systemroot%\system32\regsvr32 %systemroot%\system32\vbscript.dll %systemroot%\system32\regsvr32 %systemroot%\system32\jscript.dll %systemroot%\system32\regsvr32 %systemroot%\system32\dispex.dll %systemroot%\system32\regsvr32 %systemroot%\system32\scrobj.dll %systemroot%\system32\regsvr32 %systemroot%\system32\scrrun.dll %systemroot%\system32\regsvr32 %systemroot%\system32\wshext.dll %systemroot%\system32\regsvr32 %systemroot%\system32\wshom.ocx Exit the Command Prompt.
Enable Windows Script Host b> Windows Script Host is an administration tool by Microsoft that creates an environment for hosting scripts. According to Microsoft, Script Host will manage security and invoke the proper script engine. Script Host comes standard on all Windows operating system versions 98 and later. Therefore, you can easily enable Script Host on your computer. Go to the Windows Desktop. Click on the "Start" button. Select "Run" from the menu of options and icons that opens. Type the word "regedit" into the text box of the Run window and then click "OK." The Registry Editor window will appear. Select "HKEY_CURRENT_USER\Software\Microsoft\Windows Script Host\Settings" from the folders on the left of the Registry Editor window. Double click on "Enabled" in the window pane to the right. Set the Value to 1. Return to the folders list in the Registry Editor. Select the folder "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Script Host\Settings." Again double click on "Enabled" in the window pane to the right and set the value to 1. That's it, you have successfully enabled Windows Script Host.
Jan 15, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Our software is a VB oriented software and SQL based. In this software requires winxp sp2 and 512 MB ram. We installed this software on several system. Some systems working fine, however in some systems...
Win XP SP2 is no longer supported by Microsoft & most manufacturers.
Visual Basic has a habbit of leaving odd dll files out when building exe files as it checks the win23 bin for files and doesn't add the odd file.
Installing VB on the faulty machines will place the missing dll's in the win32 bin.
Hope that helps.
Jan 22, 2011 | Computers & Internet
Ls2208 Barcode Scanner program for .NET
here is the Barcode Scanner Program right now, it seems like being able to scan barcode with Symbol Ls2208 handheld device.
if it is not workiing, go to this barcode website to find more compatible software for Ls2208, i am sure you will find the proper one.
NET Barcode Reader Barcode Reader ASP NET Barcode Reader VB NET Barcode... Barcode Components NET Barcode Generator Reader Java Barcode Generator...
Jul 28, 2010 | Symbol LS2208 Handheld
Have a VB app for Symbol MC1000 barcode scanner that has worked for about a year. Recently, scanner brought to IT dept since app no longer runs. Error is "Cannot find app_name (or one of its components)....
I had a similar problem on an MC75.
I had a back up of the registry, so I restored the backed up registry and it all started to work again.
Hope this helps!
Netty
Sep 09, 2009 | Symbol Computers & Internet
I have sato cx400 printer, looking for VB6 code
Try this link:
http://www.filebuzz.com/files/Codabar_C/freeware-1.html
Have a look at the VB Barcode Integration Kit
Feb 04, 2009 | SATO CX400 Thermal Label Printer
VB With MC9090S
If you are willing to use VB.NET, then it will be easy. You would need the Symbol EMDK. With that and VS2008 (Express should be fine as well), you only need few coding steps:
1) Add reference to dlls
Symbol.dll and Symbol.Barcode.Dll
2) Finder a scanner
s = Symbol.Barcode.Device.AvailableDevices.First()
3) make a reader
r = New Symbol.Barcode.Reader(s)
4) add data
d = New Symbol.Barcode.ReaderData(1, 1024)
5) enable laser
r.Actions.Enable()
6) enable reading
r.Actions.Read(nrd)
7) add handler
AddHandler r.ReadNotify, AddressOf r_ReadNotify
8) read data in event
msgbox(d.Text)
That is all there is too it. Good day.
Jan 22, 2009 | Symbol MC9090 Barcode Scanner
Does not go to the next line after scanning
you need to make a suffix so it presses enter or adf rule so that it can press the tab key if you need help let me know
Dec 08, 2008 | Symbol LS2208 Handheld
Barcode reader
This is a setting issue of your barcode scanner, the only way to solved the issue is to find the manual and look for the settings that are most likely what you need to display and send data.
Please rate me solved if you like my solution.
Best regards,
Philip
May 28, 2007 | Unitech (MS3301UB) Handheld
Zebex 90940-RS232-9 Handheld Logo
135 people viewed this question
Top Zebex Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Zebex Computer and Internet Expert? Answer questions, earn points and help others
