Question about Epson Stylus CX4800 All-In-One InkJet Printer
Epson CX4800.... the ink error red line stays on and doesn't allow me to print. I have even replaced the black cartridge (even though it didn't need to be replaced yet). The color ones are fine. I'm only trying to print B&W but can't. Can't scan or make copies..... help?
  • 26 Answers
SOURCE: ink light on
you must verify all lefvels of yopur ink cartrages some of the others maybe low
Posted on Mar 08, 2008
  • 12 Answers
SOURCE: color, black ink cartridge error
contact epson support
they may replace your cartridge
Posted on Mar 14, 2008
Tirzo
  • 94 Answers
SOURCE: Epson Stylus CX4800 All-In-One
One possible solution that we can advice is to do a complete trash & reinstallation of printer driver as well as the scanner driver.
For iMac with Leopard, there is a big possibility that the printer driver is not the correct epson series printer driver that's why you can't ink levels is unavailable. Just to set an expectation, printer driver for CX4800 is pre-installed as resident driver in Leopard. Please try to the following to solve that issue:
Determine Which Driver is Currently Being Used
1. Click on the Apple icon in the upper left corner of the Finder and open System Preferences.
2. In the System Preferences window, click on Print & Fax.
3. In the list of printers on the left side of the Print & Fax window, click once on your Epson printer to select it.
4. Check the name of the driver being used; it is displayed in the center of the Print & Fax window next to “Kind”.
5. If the driver name displayed next to “Kind” is Gutenprint, the incorrect driver is being used. Follow the steps in the next section to select the correct driver.
Selecting the Correct Driver
1. Turn off the printer.
2. Delete the print queue and remove the printer from Print & Fax by clicking on the minus (-) button under the list of printers. Click OK to confirm the removal.
3. Click on the Apple icon in the upper left corner of the Finder and open System Preferences.
4. In the System Preferences window, click on Print & Fax.
5. Turn on the printer. The system should add the printer automatically.
6. If the system does not add the printer or if it adds it using the Gutenprint driver, contact Apple for assistance. You may need to reinstall the Epson drivers provided with Leopard.
NOTE: To check ink levels, click the Utility button, then click EPSON StatusMonitor. The Supply Levels button will not show remaining ink levels for your Epson printer.
Posted on Jun 11, 2008
  • 137 Answers
SOURCE: Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Posted on Jul 18, 2008
checkitright
  • 1362 Answers
SOURCE: Won't print unless all ink cartridges have ink.
Try changing it in the properties section under device settings
or go to color management if you have it and change the setting to black only,.
Posted on Aug 07, 2008
I have enough black ink to print a few pages in black, but the printer won't print. What do I do?
I had a Epson printer that would not print or even allow me to use the scanner because the colored ink was out. Even though I had full black ink, it still would not let me print until i replaced the colored ink.
Sep 25, 2012 | Lexmark 90T6005 Prospect Pro205 All-in-One...
Ink cardridge replacement
Try cleaning the print heads (that option should be on your printer's menu). It does use up some ink, but in my experience with Epson printers, it needs to be done way too often. If that doesn't work, try another new black ink cartridge. I just had the same problem with an HP printer that was fixed by using another new cartridge.
May 06, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Am getting black streaks on my printouts from my EPSON Stylus CX4800. They are darkest on the margins of the paper but the lines are visible across the entire page.
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 03, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Enable epson stylus CX4800 to only recognize black cartfridge and not color ones
for the Color Ones?????
Jan 28, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Epson 830u Printer Red light stays on even with new ink
I realised that I had to replace both the ink cartridges even though I only wanted to replace the black for it to work. Once I replaced both the black and colour cartridge the red light went off. Thanks
Feb 11, 2009 | Epson Stylus 830U InkJet Photo Printer
I've got the Epson Stylus DX 8400 printer. when I put the cartridge,this message come up: "ink cartridges cannot be recognized." txs
I had the same problem too.  I went to the Epson website and they gave instructions to shake the cartridge 4-5 times prior to installing.   It worked!!!  I tried alot of things before I saw that I needed to shake the cartridge.  Definitely give this a try if you haven't already.
Dec 27, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Restart after replace ink cartridge
my CX4800 has done the same thing. I ran the utilities dozens of times, replaced every cartridge and it feeds papers the print head moves like it's printing but nothing is imaged on the paper.
Searching the web is my last chance to fix it before i toss this 18 month old printer and never buy an epson again.
Aug 23, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Epson CX4800 dried ink
You can use the "Clean Print Heads" function if your printer allows and provides such an option. You can find this option via the printer proprties (Start > Printers and Faxes, right click your printer and select Properties. The clean options will usually be on the Maintenance tab)
May 27, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus CX4800 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
