Question about Epson Stylus C46 InkJet Printer
Epson Stylus c46 prints off centre
Hi my Epson Stylus c46 makes some nasty noises when printing and then prints off centre and over itself and with lines all over it. What can I do?
  • 556 Answers
SOURCE: I have not a CD for installation of Epson Stylus C46 I tink you ,
go to the following link
http://esupport.epson-europe.com/SupportHome.aspx?lng=en-GB&data=0ccCGROWIYM58zV3pqc84W2LhUcmWnHiUk31CNK52sUU003D
Select inkjet printer in product range
THEN
Select Stylus C46 in printer
THEN
Select you operating system
THEN
Click on Confirm Selection
You should have access to download the manuals and software that would have appeared on the CD.
Posted on Dec 11, 2007
SOURCE: Epson Stylus C86 won't print
The ssc program doesn't work if your ink light is solid red.
Posted on May 01, 2008
gwbm
  • 353 Answers
SOURCE: Epson C46, changed coloured ink, won't print flashing red light
If the red light is flashing by itself, it means the printer thinks a cartridge is low on ink. Have a look at what the Status Monitor thinks (right click the printer Icon in the bottom Right-Hand corner and select Ink Monitor). This will show which cartridge it is. If it's the new colour cartridge, it means the cartridge is faulty (then replace it), or it is a refilled cartridge that hasn't had it's chip reset to "full". For this you will need a chip resetter, available on E-Bay very cheaply. If it's the black cartridge then replace it.
If both green and red lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Posted on Mar 12, 2009
Ajkill
  • 2035 Answers
SOURCE: white lines on printed photos Epson Stylus NX400
You need to clean the print head on the cartridges , please follow these steps\
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Mar 15, 2009
gwbm
  • 353 Answers
SOURCE: epson c88 prints horizontal lines
It looks like storm_christ has lost interest in this problem, so we may call it "solved by poster".
Posted on May 06, 2009
Can i print without using my black ink
Unfortunately, you cannot print without using black ink on Epson, and most other, printers. Some printers allow you to use a combination of the color ink to create a "false black". But, the Epson Stylus C46 cannot do this.
Time to pick up some ink!
Thanks for using FixYa
Jul 13, 2011 | Epson Stylus C46 InkJet Printer
I need to align my epson stylus c46 but i need to know what number it needs to ba at for on the alignment page
Print head alignment. From print out find the square without any visible band(s) or square with thinnest band. Fill the number that corresponden it. Repeat it till perfect. Or you can print without high speed option.
Sep 17, 2010 | Epson Stylus C46 InkJet Printer
Hi! printing flight boarding passes on Epson
run it through a cleaning mode.
in ctrl panel
select printer and r click go to
properties and then the
maintenance tab.
Run clean
Run Nozzle check
When it prints correctly
ensure you select paper size as A4 and print your pass.
Pleazse rate my help++++Thanks for using Fixya
Jun 04, 2010 | Epson Stylus C46 InkJet Printer
What is the dpi of the C46?
Epson Stylus C46
Horizontal B&W printing resolution: 2880 dpi, Horizontal colour printing resolution: 2880 dpi
Blessings
Dec 18, 2009 | Epson Stylus C46 InkJet Printer
Epson stylus c46 installing with no cd
hi,
goto here Epson Stylus C46
where you will be able to download all the software you need plus manuals etc.
riz.
Mar 27, 2009 | Epson Stylus C46 InkJet Printer
Epson Stylus C46 wont print
Printer will not print red and green lights on all the time
Nov 06, 2008 | Epson Stylus C46 InkJet Printer
Delete print queue in epsom stylus c46
Hi
Go to control panel, click on printers, look for stylus c46 icon, right click and cancel all documents. restart your computer afterwards.
Thanks for using fixya!
Oct 31, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson c46
Here is the link :
Epson Stylus C46 : Drivers & Software
Unplug printer USB before starting driver installation.
Note : Vista drivers are not available for this printer.
Oct 19, 2008 | Epson Stylus C46 InkJet Printer
Help
could part of the paper still be in the unit look close, also when you pulled the paper out did you hear any of the gears move?
Dec 08, 2007 | Epson Stylus C46 InkJet Printer
C46 Epson printer
Check to make sure the paper alignment tool is up against the papers edge (snug), and verify no foreign objects in the feeder.
Nov 12, 2007 | Epson Stylus C46 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
20 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
