Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water through the door but no water to the ice maker
GE Profile ..pulled out from the wall,no obvious issues, there was a small puddle to the front underside of the fridge. Didnt slow down in ice production just stopped. In various parts of the day, have seen the arm up like its trying to do something.
  • 193 Answers
Since you are seeing the arm up at times, ice maker is ok. Look for problem with water solenoid valve on back bottom of unit
Posted on Sep 30, 2009
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
How to remove ice maker on ge profile pfss6pkwbss
You would first have to distinguish between if the tray has a crack in it or if the water valve is not closeing which would mean you would need a new water valve. Most all ice makers are held to the freezer wall by 3 1/4" screws you would unscrew these screws and unplug the power connector and remove the ice maker from the unit. Fill the ice tray with water and see if you do have a crack in the tray which is not as common as a water valve allowing to much water to go into the ice tray makeing it overflow. If you have any further questions message me back I await your reply.
Thank you,
Rick
Jan 19, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
Stainless Steel GE Profile with Bottom Freezer.
Have you had any cooling problems coincide with the ice problem? if no evidence of temperature variations, you either have a crack in the ice maker mold, causing water to drip into the ice bucket. Or you may have a bad water valve solenoid, not closing completely when the ice maker stops calling for water, overfilling ice maker into the bucket, and further down your freezer.
those are the most common problems, though other odd situations could also be a problem.
Mar 28, 2010 | GE Profile Stainless Bottom-Freezer...
Profile ice maker stopped making ice
ice maker for ge profile wont' make ice.Unplugged elect supply from both waterin the door coil and ice maker coil.Plugged water in the door elect to ice maker valve coil and pressed water in the door input sw out front and got water to ice maker so this let me know it wasn't the solonoid valve.Got another ice maker unit plugged in and mounted waited several days still no ice.
Sep 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
Small puddle of water from dryer?
you should check the back vent on your wall have you had any rain lately some times the strong rain will go down the back wall in the vent if broken
Jan 30, 2009 | GE WDSR2080D Top Load Washer
Metal ice maker arm is stuck midway. Will not produce ice
The small metal arm that raises as the ice fills in my GE side by side with water and ice in the door is stuck. Will go all the way up but only half way down. No other obvious issues. Have felt inside the little tray to be sure nothing was jammed or frozen.I need help !!
Jan 07, 2009 | GE Refrigerators
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker not working
have you felt water in the ice maker or ice cubes thats the only way you know for sure.. just cause water in doors works doesnt mean icemaker getting water.. got different valves giving water to different places Is your freezer temp. right.. has to be right temp for icemaker to work.. check back wall in freezer make sure no frost buildup and if fan working
Sep 02, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
99 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
