the modem is a ce-fm4 fax/modem Can i buy a New one Some where? oh ya and when i turn on my zaurus it says replace memory backup battery. Please read the operation manual for directions. And i did but it did not help me.
In my Zaurus ZR 5800 the two 1.5 volt alkaline AA batteries go dead in about 30 days even if the...
(More)
In my Zaurus ZR 5800 the two 1.5 volt alkaline AA batteries go dead in about 30 days even if the 5800 wasn't turned on. What could be draining the batteries? The 3 volt button was replaced with a new one. Same problem. Is there a common fix for this? Thanks. Jim in Tampa
I put in a new main battery and now the Zaurus asks the following: Do you really want to initialize...
(More)
I put in a new main battery and now the Zaurus asks the following: Do you really want to initialize the main battery [This will delete all main data ].What should I do to save the main data?
I have a factory reconditioned Zaurus ZR-5800 which is a spare in case my other unit stops working,...
(More)
I have a factory reconditioned Zaurus ZR-5800 which is a spare in case my other unit stops working, so it has had almost no use since having been reconditioned. However, I have kept it installed with good batteries, and I turned it on every once in a while. My problem is that last time I tried to turn it on, the screen remained blank. The touch screen and keyboard still beeped when touched, and the backlight works, but the screen remains blank. I tried changing the batteries and I tried changing the brightness on the screen using the keyboard, with no luck. Any suggestions?
