Hard disk problem
Recently i have purchased an harddisk 160 GB . I have installed winxp and software required for windows.
when i was copying the files to harddisk the sound is comming like fan while it working.
what is the problem. it will affect to motherboard or not.
can any one find me the solution
    Problem Solver:
  • 14 Answers
And if you mean the harddrive then no issue
usely the harddrive begins to make sounds because it is working
but if you got a new hardrive from todays 2008 hardrives and it is one of those silent ones than somethings wrong
but usely older harddrives make noise when at work
Posted on Mar 20, 2008
  • 21 Answers
Do you mean the fan is running more loudly?
It's possible the additional heat from the hard drive is raising the temperature inside the case. Most fans are thermostatically controlled (they run more the hotter the PC is) so you'd expect this.
Will it affect the motherboard? If the the fan is running properly, no. The PC should shut itself down before thermal damage occurs. Make sure you don't have it tucked into a space where there's no airflow.
Make sure all the vents are clear (vacuum if necessary); I will even open the case and vacuum, but if you don't know what you're doing, I don't recommend this.
Posted on Dec 19, 2007
I have windows xp o/s, p5vdc-mx motherboard with 512mb ram and 80gb harddisk, can i install windows 7 in this configaration? if no please tell me the configaration?
Windows 7 system requirements 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor1 gigabyte (GB) RAM(32-bit) or 2 GB RAM (64-bit)16 GB available hard disk space (32-bit) or 20 GB (64-bit)DirectX 9 graphics device with WDDM 1.0 or higher driverInternet access (fees may apply)Depending on resolution, video playback may require additional memory and advanced graphics hardwareSome games and programs might require a graphics card compatible withDirectX 10 or higher for optimal performanceFor some Windows Media Center functionality a TV tuner and additional hardware may be requiredWindows Touch and Tablet PCs require specific hardwareHomeGroup requires a network and PCs running Windows 7DVD/CD authoring requires a compatible optical driveBitLocker requires Trusted Platform Module (TPM) 1.2BitLocker To Go requires a USB flash driveWindows XP Mode requires an additional 1 GB of RAM and an additional 15 GB of available hard disk space
If you want to run Windows 7 on your PC, here's what it takes:
Additional requirements to use certain features:
Aug 17, 2011 | Computers & Internet
I am using a toshiba portege m400 and try to upgrade harddisk to 250 gb while installiing windows 7 hard disk is not detected.
maybe its not compatible to the laptop the hard disk that you purchase try replacing it with lower capacity hard drive then reinstall the windows 7 again
Aug 07, 2011 | SIB 250GB 2.5" SATA HDD Hard Disk Drive...
When i install windows xp harddisk could not found and red light has blinking what can i do
hi ajmalnizar_n,
Try to check if your harddisk is detectable in Bios if so,
The problem is in the installation of windows xp. install a new copy
of Xp. Reformat the disk using ntfs then create your partion if you like.
Hope this helps, Feedbacks appreciated
Thx
Banaple
Sep 03, 2010 | Seagate (ST3160827AS) 160 GB Hard Drive
FUJITSU MHT2060B-SATA hard drive driver wanted
Get the drivers from the motherboard homepage, extract the file at a floppy or USB, and start WinXP installation from your cd. At the begining at the bottom line is a message like "for ... drivers press F6 to install" Press F6 and after sometime the will prompt you to provide the drivers from the floppy. In the WinXP sp3 the generic SATA drivers are already on the installation cd.
Stelios
Feb 18, 2010 | Fujitsu (MHT2060BH ) 60 GB Hard Drive
My hardisk is inserted to the usb ports but it is
u might have received a CD along with the harddisk so install the software which is the driver for ur harddisk
Jun 29, 2009 | Computers & Internet
I bought a laptop without OS how can i now get vista in it?
You will need to get a windows system disk or install disk and boot up with this in the laptop to load windows whatever into your hard drive and set your laptop up to run on the new drive. Here is Microsoft's tutorial on how to install and set up windows:http://www.microsoft.com/windowsxp/using/setup/winxp/default.mspx
Hope this helps you.
Mar 29, 2009 | Dell Vostro 1510 Notebook
Disk manager for seagate 160 gb sata barracuda hard disk
windows xp setup not creat the partation.
and not show the tha harddisk,but harddisk are showing the bios setup.
my system is ACER ASPIRE tower Casing.
Jan 10, 2009 | Seagate (ST3160827AS) 160 GB Hard Drive
Install window on a portable ide harddisk
i dont think so dat window could b installed on usb.
Dec 31, 2008 | Computers & Internet
Barracuda hard disk 80gb
More than likely, since you say you did a DOS install of the OS, you did not set the FDISK parameters to set your primary drive. Insert the DOS CD you used to format the system. Boot to a DOS prompt and run the FDISK command. It should have an option, I believe it is number 2 or 3 to "Set primary drive". Select your hard disk 0 as this drive and you should be fine at rhat point.
Sep 17, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
My dvd rw is not detected
Sounds like you need your manufacturer's SATA drivers.
This problem exists a lot when installing Windows from scratch on SATA hard disks. When you start the installation, Windows prompts you to "load additional drivers". It's at this point you put a floppy disk with the SATA drivers in.
If your install is already working, but just stopped as you say... then you could hunt around the BIOS for a SATA "compatibility" mode, which will get you booting straight away. Install the SATA drivers and you can then put the drive back into normal operation instead of compatibility mode.
This is also the reason why your other hard disk with Windows can see the SATA disk and optical drive... it probably has the SATA drivers installed.
Aug 20, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
87 people viewed this question
Alun Cox
David Payne
David Payne
