Question about Garden
Two different size ultraviolet ballast. The .71AMP ballast feeds two 40W ultraviolet ''UV'' bulbs. The .37AMP ballast feeds one 40W ultraviloet bulb. The two light to larger bal;last want come on. The light on the smaller ballast just blinks. How do I troubleshoot to see why all three bulbs are not burning? Or is there a way to test a ballast?
  • 30 Answers
I usually test the ballast simply by excluding everything else.
1) Put in bulb that you know works
2) Replace starter (if you have one)
3) check that wiring is intact (sounds like it is for you but I had one light that the wiring barely made contact so sometimes it came on and sometimes it blinked)
4) If all that is good, then it's probably the ballast.
Posted on Sep 30, 2009
I have a T12 fluorescent light fixture and replaced the bulbs and ballast. I have double checked all the wiring connections. I get the bulbs to light when I move the bulbs, but only for a second.
Your description sounds like the connectors for the tubes. Also RECHECK wiring. Different on newer ballasts. See below...
Turn off fixture, unplug, or deactivate fuse...
Pull out bulbs and the tin fixture cover/reflector.
Extract the bulb connector. Go to hardware and buy 4 more, and just replace them. The connections fail where the wire connects and the rigours of bulb replacements damage this piece. TONS easier to get new pieces.
ALSO!!!! many new (fancy schmancy) ballasts WIRE UP completely differently from the old ballast. Follow the wiring diagram on the NEW ballast. This detail trips up many.
Doc
Sep 13, 2016 | Photography
My brand new shoplights flicker nonstop. Both of them. Bulbs are gef34 cw c41 eco hg. Lamp calls for f40 t12 in 25, 34, & 40 watt varieties. Am i using the wrong bulbs? or are my lights garbage?
Brandon, Do the lights have cold start ballast in them, if they do best to use cold start bulbs. press the helpful button
Do not put two different size or make of bulbs in the same fixture.
Feb 07, 2016 | Dryers
Where can i get a replacement lamp uv-145 2.5w
Sealand Replacement Bulb for Green Killing Machine - Petco
www.petco.com/.../Sealand-Replacement-Bulb-for-Green-Killing-...
PetcoWater flows in direct contact with UV lamp, making it extremely efficient. The zigzag flow are designed for maximum sterilizing time. Totally self-contained replacement bulb assembly for AA 9Watt UV Sterilizer Kit. .... 2.8" L x 2.5" W x 16.5" H
UV light sources - Norland Products
https://www.norlandprod.com/lightsourc.html
The Norland collection of long-wave, ultraviolet light sources have been carefully ...LED UV Curing System emits a consistent and repeatable 2.5 W/cm squared ... lack of liquid light guides and replacement lamps brings to the forefront of UV ...
[PDF]MultiPole LED UV Curing System - Electro-Lite
Dec 10, 2015 | Honeywell Air Purifiers
Where can i buy a replacement transformer for a FISH MATE 15000 11 watt UV ?
You can use a different manufacturer with different numbers. All that matters is that it is for a 11 watt fluorescent bulb. UV does not matter to the transformer. Here is one site; http://www.buylightfixtures.com/ballasts-and-transformers-1.aspx
Oct 09, 2014 | Garden
The UV light is not working on my 300307. How can I tell if it is the bulb, the ballast, or the transformer?
Read across both prongs of light with a meter set on ohm's to check for continuity(closed circuit) if no reading bulb is burned out. Mine attaches to the ballast and then is inserted into a glass tube wich is then screwed onto the housing. There is a micro switch attached to the ballast that setsmwhen insertet into the housing that might be bad(had to replace mine) Remove bulb and check if grtting power to it by inserting volt meter probes into receptacle for the light and check for voltage,set meter to correct setting. If getting power at plug for light ALL is good and it is your bulb
Apr 07, 2010 | Garden
''UV'' light not working!!
I`ve always used one ballast to one light.i.e if your bulb is a 400 you need a 400 ballast only and feeding no more off it. Try this
Sep 29, 2009 | Sunmaster Conversion Lamp HPS Ballast
NOS GE Ballast - Good?
Hi, The GE ballasts that you are referring to is OK. if stored correctly, they should be just fine.
Feb 25, 2009 | LG RU-60SZ30 60" Rear Projection...
BULB AND LAMP
I can give you some possibilities. A loose connection, a broken or corroded wire and/or terminal end, dust or moisture on a circuit board, the plate needs cleaning, the contacts for the plate need cleaning, the bulb ballast needs to be replaced, the bulb may not be properly installed, the support posts for the plate need cleaning. These are all I can think of at the moment.
Jun 18, 2008 | Ecoquest Fresh Air Air Purifier
Pure ion uv light does not turn on
Where can I get a replacement ultraviolet germicidal lamp? I have been to Brookstone store and on line without help. My unit is a Pure Ion.
Thank you.
Dec 25, 2007 | Brookstone Pure-Ion UV Air Purifier
Garden Logo
147 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
