Duplicacy in excel sheet
My data operator entered alot of duplicate date in a excel sheet to increase the no of count of data. i have to search every data by its pnone no how many entry of that no is in the sheet .then i delete the all except one entry. in such a way i have to search from the whole file containing thousands of data . is there is any shortcut
Since you are searching the data by the phone number , first select all the data in the spreadsheet and sort it in ascending order by the phone number.
Then, assuming you have 5 columns of data A through E, and the phone numbers are in column E, with row 1 occupied by column headings, use the following formula in cell F2=IF(E2=E1,"Duplicate",1)
Drag this formula down column F till the end of your data
Select the entire data and do an auto filter
In column F filter the data by Duplicate and delete all these rows
What remains should be unique data
Posted on Dec 29, 2007
Use COUNTIF formulae to found duplicate records in the excel spreadsheet.
Posted on Jan 13, 2008
How to export tally 9 to excel sheet
Great question and there are two way export date. Please follow step by step instruction.
  1. In the Balance sheet screen click E : Export or press Alt+E.
  2. Select the required language from the list of Languages displayed.
  3. Select a format from the list of Formats displayed.
  4. By default, the exported file will be stored in C:\Program Files\Tally.ERP 9 for Windows 7 and C:\Tally.ERP 9 for Windows XP operating systems
  5. Press Enter to accept the default Output Filename or type the filename of your choice in order to save the file with a different name.
  6. Press Enter to accept the default Output Sheet Name.
  7. To update the existing file select Yes in Update Existing File.
  8. To format the contents of the file select Yes in Excel (Spreadsheet) formatting.
  9. Select Yes for the Field with Colour, to retain the background colour in the exported file.
And Second:
selecting the ASCII (Comma Delimited) format, the user can export all the reports or data from Tally.ERP 9. The data exported is converted to plain text separated with commas and stored in a file with the extension .txt. This file format is widely used for emailing and used for importing data into another company using Tally.ERP 9
More information please visit this link.
Jun 10, 2014 | HP Office Equipment & Supplies
Macro help in Excel
go google and type in--- user manual for excel---
there is a pdf version about 900 pages long that explains everything you want to know and do in excel
Mar 27, 2017 | Microsoft Office Excel 2003 for PC
Inbox messages duplicated in Junk file
The time to time cleaning of your Outlook mailbox is a good routine to adapt as it makes sure that your mailbox remains free from any duplicate items. But once the mailbox database and the size of other folders become large, it becomes quite difficult to remove the duplicacy of the database. To avoid manual efforts, a dedicated Outlook duplicacy software can be used. To download one such tool visit
Jan 30, 2012 | Microsoft Office Outlook 2003 for PC
I'm using d-link dwl-3200 ap ( three) Received Frame FCS Error Counts indicate a problem? ___________________________________________ WLAN 802.11G Traffic Statistics Throughput Transmit...
Transmitted Error Count 4734440
Ack Rcv failure Count 15269951
  • As per the above there are error on Transmitting the packet and also for receiving the acknowledge packet.
  • Please check whether any disturbance in the link
  • Each PPP packet has a checksum attached to ensure that the data being received is the data being sent. If the FCS of an incoming packet is incorrect, the packet is dropped and the HDLC FCS count is increased.
  • Another reason for seeing too many FCS errors may be that the remote end has stopped talking PPP.
Feb 27, 2011 | D-Link AirPremier DWL-3200AP 802.11g/b...
Transforming birthdates into year codes
Here is a solution that might work for you. Please be mindful that there are several different solutions that will achieve the same thing in Excel (I am assuming Excel is your software).
1) Make sure each column in your spreadsheet has a heading.
2) Highlight (select) the column of birthdays.
3) Choose Format from the menu bar.
4) Choose Cells... from the drop-down menu.
5) For the "category", choose Custom.
6) In the "type" box, type yyyy
7) Click OK and when you return to your spreadsheet, you will see only the years displayed. However, when you try to edit a cell, you will see that the entire birth date is stored and preserved.
8) Now, highlight the entire table
9) Then, choose Data from the menu bar
10) Choose Subtotals... from the drop-down menu
11) In the "At each change in" box, choose the name of the column with the birth dates
12) In the "Use function" box, choose Count
13) Leave all other choices at their defaults
14) Click OK, and you are done.
Using this method, you can continue to enter the data as you always have. In that way, the birth date info is never actually destroyed or converted. What you are doing is simply deciding what is displayed.
I hope this helps.
Aug 02, 2009 | Microsoft Office Excel 2007
Merge two excel sheets with same columns with sum.
Please give some data for sample to solve your query..
Sunil Charate
Feb 19, 2009 | Microsoft Computers & Internet
Excel question
You can import data from one sheet to another. If you want to bring a total from Sheet 1 to Sheet 2, then in Sheet 2 enter [=sheetname!cell] (without the brackets of course. You will now have the data from Sheet 1 in a cell in Sheet 2 and you can do anything you want with it. One note: if the sheet name has a space in it (Sheet Name) you have to enclose the name in single quotes; that tells it that the whole thing is the name. For example, Monthly Sales, A10 is the total for last month; to put it in this month for a running total, you would enter in Sheet 2 ['Monthly Sales'!A10] (without the brackets again). Now you can have a running total between the two sheets.
Aug 19, 2008 | Excel (SS8SATAS5128400R)
Excel counting
Use Pivot table, it might help you reach your target..!!
Aug 12, 2008 | Microsoft Excel for PC
Copying data from one sheet to another if two fileds match
Nope, sorry, although I am truly an expert at Excel formulas, I do not understand what you are trying to end up with in the final cell. We can compare a specified field with two spreadsheets - use named ranges and index/match lookup formulas. But then where you really lose me is in reading "a generic field" to find a match, and then placing what "data from another field" into what "other sheet" - ? See the confusion?
Best way to compare 2 given parameters would be to use a nested if formula, with index/match combo. Here is a simple Excel example of how such a formula could be structured:
Sample Data (columnar arangement):
A1: Part B1: Code C1: Price D1: Find Part E1: Find Code
A2: x B2: 11 C2: 5.00 D2: y E2: 12
A3: x B3: 12 C3: 6.00 D3: y E3: 11
A4: y B4: 11 C4: 7.00 D4: x E4: 12
A5: y B5: 12 C5: 8.00 D5: x E5: 11
To retrieve the price for part y with code 12 and return the value to cell F2, type the following formula in cell F2:
Press CTRL+SHIFT+ENTER to enter the formula as an array formula. The formula returns the value 8.00.
To take this one step further, with range names, this example will find one value at a specified location which matches a specific row header value and column header value. Let's say the range is home values (Range=HomeVal), Column A of HomeVal contains street addresses,"row headers" (Range=StAddress), and Row 1 contains dates of the various values that are in the body of the table, "column headers" (Range=Dates). To return the specific value from the range HomeVal to another sheet, where A1=address specified and A2=date specified:
Then make sure to press CTRL+SHIFT+ENTER to enter the formula as an array formula - if you only hit enter, these types of formulas will not work properly.
Please post back if you need further help, with more details, otherwise thank you for using and rating FixYa!
Jul 08, 2008 | Microsoft Computers & Internet
Excel Sort Across Sheets
Hi Raymond, I have a solution for you. Asuming your 'main' sheet is Sheet1. On Sheet2, in the same line as your data on sheet1 (i.e. A5 on sheet1 is JIM), then on A5 on sheet2, enter a link ( the = ) and enter. copy this formula down. Do the same with Sheet3 linking to Sheet1. When you sort Sheet1, Sheet 2 and 3 will follow. Hope this helps. Regards DeltaC
Sep 11, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
268 people viewed this question
David Payne
David Payne
