Question about Mitsubishi VS-60803 60" Rear Projection Television
I have a mitsubishi projection tv modell# vs-683r. cannot change the tint, and the picture is all pink please help
techman
  • 3130 Answers
SOURCE: Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Posted on Jun 16, 2006
  • 1153 Answers
SOURCE: mitsubishi model vs-5043
1. CHECK BASE BIAS VOLTAGE OF Q217, FOR 0 VDC (BIASED OFF) IF .7 VDC (BIASED ON) CHECK C268 (22 UFD 50 V) OFF C OF Q215 V-PROTECTOR ON THE SIGNAL PCB.
Posted on Aug 26, 2007
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi projection Model # VS-50501A (Power cutout)
they are fairly similar to each other, did you get a error code from the led by pressing menu and input both in together and holding for 5 seconds?
Posted on Aug 19, 2008
  • 109 Answers
SOURCE: 52" mitsubishi rear projection tv model vs6051 sound no picture
Not exactly familiar with this model but sounds like the projector lamp is burned out. Hopefully it's a replaceable type. Try calling these people - http://www.purelandsupply.com
Posted on Mar 29, 2009
maatmartin7
  • 1210 Answers
SOURCE: Projection TV, Sound but no Picture
If this Tv is a model year 1996 or 1998, It is quite possible your vertical IC needs resoldered. It is located on the small signal board. This board [quite large anyway] is the board on the left. I don't know the location off hand. The IC has seven pins and located on a heatsink, It is a TDA series. Resolder any and all grounds you see. May as well get the Large Signal board [On the right] resoldered. The other problem would be the P I P board, a small board standing up, that can be removed and replaced. But try the earlier first. This is tedious, but will produce results.
Posted on Jul 12, 2009
Mitsubishi vs-50609 green timer light comes on no
Unplug the tv and leave it unplugged for a couple hours. Plug tv back in press reset button. TV led may flash for a day but should come on. I did this last night to mine and it came on at 11am today.
Mar 29, 2010 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi VS-55609 distorted Picture Flickers
This is a convergence problem and not really a DIY Many amateurs try it to save money but end up spending more on it than a professional. There are dozens on here that managed to fix it for a day or two only to have it fail again.
cost of fix about $300.
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | Mitsubishi VS-5059 50" Rear Projection...
Mitsubishi VS-50603 Wont Turn on
The power supply will need to be changed. The capacitors inside the power supply are not sending the correct amount of power to tv and will need to be changed.
May 13, 2009 | Mitsubishi VS-50603 50" Rear Projection...
Mitsubishi 50inch TV Turns off right after I turn it on
tv is in shut down.could be several things.call a repairman.
May 10, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-60705
I have a Mitsubishi VS-60705 and the picture flutters vertically and horizontally i need to be fixed
Dec 04, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Red color abunDANT
Please verify model # from rear of set.PVAT! Look closely at signal PCB for signs of CRT coolant leak.
Oct 03, 2007 | Toshiba 42H82 42" Rear Projection...
Mitsubishi VS-60603 60 in pink spot
I have seen this before, and I can only describe it as a flaking of the phosphorus coating in one of the picture tubes. If you can, remove the back such that you can take a flashlight and look down into the 3 picture tubes. If you see any flaking or dark spots in the phosphor, there will be a spot on the screen missing that color. Unfortunately, this is not repairable, as all 3 tubes would need to be replaced (like replacing all 4 car tires when one is completely bald) and that would cost more than a new TV.
Jun 06, 2007 | Mitsubishi VS-60603 60" Rear Projection...
Televison & Video Logo
46 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
