Question about Apple iPod touch
Trying to connect to my Sky wi-fi at home and do not know the password to connect to Sky - its asking me for a password. Where do I get this from?
    Problem Solver:
  • 5 Answers
You must ask the provider of the wifi connection, also sometimes it is on the actual wifi system, stickered on there.
Posted on Sep 29, 2009
Password is on a card supplied with box of goodies your router came in. If you can't find it then ask the person who's paying for the service.
Posted on Apr 06, 2012
How do I find Wi fi passwords?
Hi Andrew, If you're trying to connect to your home Wi-Fi The password in on the back of the modem, Write it down then go into your phone/tablet settings and click "CONNECTIONS", Then click on Wi-Fi and make sure it's switched on(should be a button there), Once switched on it should start scanning automatically for networks, but if not then there's a scan button there somewhere. When it finds the modem just tap on it and a small window opens asking for the password, You're connected... Bellow is a link to a short youtube video explaining pretty much the same thing..... I hope this helps...
https://www.youtube.com/watch?v=8XurHgNoZhs
Mar 30, 2016 | Tablets & eReaders
Tip
How can I go on Wi-Fi on my iPod Touch without a computer?
<p>Apple iPod touch Wi-Fi reception without using a computer. The device has a built-in 802.11 Wi-Fi receiver, which means that access to the Internet via a WiFi router that is in range. When connected to a WiFi signal on your iPod touch, you may be prompted for a password if you must know the password or ask the Wi-Fi to the administrator. Unsecured Wi-Fi does not require a password. <br /> <p><br /> <p>1. Press the "Home" button of your iPod touch and move the cursor to the right on the device. Enter the unlock code if you have programmed. <br /> <p><br /> <p>2. Touch the "Settings" icon on the home screen of the iPod touch Settings menu. <br /> <p><br /> <p>3. Play the "Wi-Fi" Network access to the names of all upcoming Wi-Fi to see. <br /> <p><br /> <p>4. Tap the name of a Wi-Fi to connect. If the network requires a password, you will be prompted to enter the password. <br /> <p><br /> <p>5. Touch "Join" to complete the connection. Now you can use any Internet-related programs on your iPod touch. <br />
on Aug 05, 2011 | Apple iPod touch
I cannot connect. I keep getting a message "authentication Failed"
Do you connect your PC to router in an administrator role using web browser? Or do you connect some device to Wi-Fi network?
  1. Administrator role: You need to have correct login name and password for admin access. Search in manual or ask Google for default login name and password of your router type. If non-default password is set in the router then you must reset router setting and erase its settings to default (factory) status. You will lose all router configuration but default password is back.
  2. Wi-Fi client role: There are more possibilities why authentication fails in wireless communication. Mentioned error message describes what kind of problem occurred.
    (a) A password you put to client device does not match the wireless network password which is set in router. Your computer, tablet or smartphone WI-Fi interface must have exactly same password as WI-Fi network which is transmitted from router. Check and compare passwords on both sides, in client device and in router.
    (b) Client Wi-Fi interface security (encryption) mode differs from Wi-Fi network encryption used in router. But the same mode must be set on both sides (client and router) for successful connection.
Encryption modes are
  • WPA2 Enterpise
  • WPA2 PSK ("home")
  • WPA Enterprise
  • WPA PSK
  • WEP
  • No encryption (open)
Higher position - better security. Enterprise Wi-Fi modes require security devices like authentication servers, certification authorities etc. They are not used in home networks usually.
Jan 21, 2016 | Computers & Internet
Authentication. problem
Is this your home network or are you trying to connect at a hot spot? Can you see that wi-fi is available? It may be as simple as needing a password to connect. I need more info.
May 28, 2014 | Computers & Internet
Connect to ipad
You don't assign an IP address to your iPad, it has one assigned to it by your router.
Open the Settings app on your iPad. Make sure Airplane Mode is OFF. Tap Wi-Fi. Make sure the Wi-Fi switch is ON, Ask to Join Networks is ON. Your in-home wi-fi network should be visible in the list titled Choose a Network.... Tap its name and provide the network password required by your router.
If you don't see your local router listed, it may not be properly configured.
Mar 10, 2014 | Tablets & eReaders
I can not or do not have a password for the sky wifi how do i get it
If the sky wi-fi is your own wi-fi service then the password is normally on a typed label stuck to the wi-fi router itself along with the SSID of the wi-fi network which should be the same as you have selected on the Kindle in confirmation you are connecting to the correct network.
If the sky wi-fi is not your own wi-fi then you will either need to contact the owner or administrator of that network or select a different wi-fi network to connect to as described in the Kindle Support web pages for your device.
Dec 27, 2011 | Amazon Kindle Wireless Reading Device
Ipod wi fi conection
Wi-Fi Functionality
  1. Connects over the last Wi-Fi network you used that's available.
  2. If no Wi-Fi networks you've used are available, iPod touch will scan for Wi-Fi networks and show a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show a lock icon (307189_1.jpg) next to them.
  3. Option to manually enter your Wi-Fi network name/SSID (if the Wi-Fi network is configured not to broadcast or be displayed to the public). If necessary, enter the password to join.
When iPod touch is connected to a Wi-Fi network, the Wi-Fi icon (307189_2.jpg) in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
Wi-Fi Settings
  1. Turn Wi-Fi on or off.
    Choose Settings > Wi-Fi and turn Wi-Fi on or off.
  2. Set iPod touch to ask if you want to join a new Wi-Fi network.
    When you are trying to access the Internet, by using Safari or YouTube for example, and you are not in range of a Wi-Fi network you have previously used, this option tells iPod touch to look for another network. iPod touch will display a list of all available Wi-Fi networks that you can choose from. Networks that require a password appear with a lock icon (307189_1.jpg).
    If "Ask to Join Networks" is turned off, you must manually join a network to connect to the Internet when a previously used network is unavailable.
    Choose Wi-Fi and turn "Ask to Join Networks" on or off. If you turn "Ask to Join Networks" off, you must join new networks manually.
  3. Join a Wi-Fi network manually.
    Choose Wi-Fi, wait a moment as iPod touch detects networks in range, then choose a network. If necessary, enter a password and tap Join. Networks that require a password appear with a lock icon.
  4. Make iPod touch forget a network, so that the device doesn't join it automatically. Choose Wi-Fi and tap the arrow (307189_3.jpg) next to a network you've joined before. Then tap "Forget this Network."
  5. Connect to a closed Wi-Fi network (an available Wi-Fi network that isn't shown in the list of scanned networks).
    Choose Wi-Fi, then tap Other and enter the network name. If the network requires a password, choose Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. Ask the network administrator which settings to use.
  6. Adjust settings to connect to a Wi-Fi network
    Choose Wi-Fi, then tap the arrow (307189_3.jpg) next to a network.
Dec 27, 2010 | Cisco Linksys Wirelessn Router Black...
I recently purchased a new 4th generation ipod and here's the problem when trying to add apps to my ipod thru my home wi-fi nothing happens [ I had Cox Cable set up my wi-fi ] but when I'm at a Starbucks...
Go into the setting on the ipod and reset network setting, Restart the ipod and then go back into the network setting and when it ask for the password, Enter the password for your home network
Dec 23, 2010 | Computers & Internet
Im connecting to my home WI fi and it says authentication failed
You will be asked for a password only if you are connecting to a password protected WiFi network.You can set a password for your Home WiFi modem and after that you have to enter the password whenever you try to connect.
Sep 12, 2009 | Samsung Jet S8000 Cell Phone
I GO TO NINTENDO WIFI.COM AND I DON'T KNOW WHAT TO CLICK ON TO GET MY DS LITE'S WIRELESS CONNECTION CODE FOR WIFI PLAY ON POKE'MON PEARL VERSION!!!!
Usually when you connect to Wifi, you automatically get a connection code. You do not usually need a code to connect... Something may be wrong with your DS's connection.
Dec 21, 2008 | Nintendo DS Console
Apple iPod touch Logo
367 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
