Question about Toshiba Satellite R10-S802TD Tablet PC
Battery accesws how do i get the battery out of the machine?
    President:
  • 2,600 Answers
1. Turn off the power of the computer.
2. Disconnect the AC adapter and all other external devices from the computer.
3. Turn the computer upside down.
4. Release the battery lock switch.
5. Pull out the battery pack while sliding the battery latch toward the arrow pointing.
Posted on Sep 29, 2009
Third generation kindle screen is frozen. Have taken the battery out. Has not changed.
Did you short the battery terminals? (on the machine, not the battery.)
May 07, 2017 | Tablets & eReaders
When the screen is white instead of taking out the battery and putting it back in can I do something else?
Not sure why your removing the battery?
If you are shuting down the machine. Close all running programs before shuting down otherwise the machine has to close each program in turn before thr machine can shut down all together. Depending on how the settings are for the power button. The shut down process can be forced by holding down the power button until the machine has shut down. Black screen instead of white. Hope this helps answer your question.
Regards
Bob from OZ
Jun 15, 2015 | ProntoTec ntoTec 7 Inch Android Tablet Pc,...
My notepad turns off when i unplug the charger what do i do
check ur battery.do the followin things:
remove ur battery and keep it flat on the ground. ok then try to spin it.
if it spins like merry go round then ur battery is damaged, but if it dosent spin then there might be certain connectivity problem.
if you have tools or equipment like soldering machine or tester yhen do it your self or take it to some service shop
Mar 04, 2012 | Apple Tablets & eReaders
My machine will not charge and is very slow
It ispossible that sometimes the battery takes a longer time to charge if the voltage of the adapter is low. So after the battery is fully discharged , you must allow the charger to be connected overnight. If the battery does not charge fully then the battery and the adaptor must be cross checked in another unit.
If under warranty you must claim for replacement.
Sep 20, 2011 | Archos 101 Internet Tablet 501590
Ibm thinkpad x61 reset to original bios rootkit problem ?
There are 2 ways you can reset your bios2_bing.gif.
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in2_bing.gif your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and 3. Your reset is now complete
This is a great troubleshooting2_bing.gif step for those of you having POST issues or no POSTing at all. Like other troubleshooting steps, this will not always work but usually will depending on the problem.
Please let me know if you have any further questions or concerns.
Thanks.
Oct 28, 2009 | IBM ThinkPad X61 Tablet PC
How to reset bios password fujitsu lbp1120 lifebook
Thanks.
Oct 15, 2009 | Fujitsu LifeBook P1120 Tablet PC
Password problems on a Toshiba Protege m200 laptop
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password.
  1. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
  2. On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password.
  3. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper.
  4. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it.
Good luck and more power
nicole
Oct 03, 2009 | Toshiba Satellite R15 Tablet PC
My laptop turns off when it is not plugged in. Battery doesn't charge fully. Have replaced the battery - same result
It is probably the "Powersave" function that turns off the machine when it is only on battery power and is not being used for a certain length of time. Also if the batteries are not charged properly, the laptop will want to shut down as the power level is becoming critical. So there are two possibilites 1. change the Powersave function and/or 2. drain the batteries entirely and re-charge fully before using them. I have found that batteries work better when they are used entirely before recharging them, so I actually have the Powersave function turned-off. There is probably a Fujitsu Powersave facility that is integral to the laptop, in addition to the Windows one, whether the Fujitsu one controls the Windows one, I'm not sure.
Sep 26, 2009 | Fujitsu LifeBook T2010 Tablet PC
My toshiba portege M400 laptop will not start up, when I turn power on the power light starts blinking yellow and does nothing
This happened to me. The computer will not work with the battery in it.
Solution: Take battery out and plug in without battery... It should work,
You will need to get a new battery
Sep 19, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
When i turn on my pc it ask for a password i never created, how do i fix this problem
Hello again sounds like it has lost its bios configuration and wants the CMOS re-setting check the hard drive hasn't come loose or your CD if it is an interchangeable one .. and if the floppy drive was in the machine ( not a disk an actual changeable drive ) .was in the last time you shut it down put it back in and reboot see if it's ok unlikely but worth a try
So if no joy you will need to remove the CMOS battery probably located under the keyboard .. or sometimes behind the ram module underneath and a few machines have their own battery holder under the machine .. its silver looks like a large watch battery and is in a plastic holder .. don't touch it with your hands they are static sensitive as are the other components around it .. wear a pair of marigolds the rubber will help protect the circuit ... hope this is a success for you good luck .. Regards Vortash
May 19, 2009 | Acer TravelMate C110 Tablet PC
Toshiba Satellite R10-S802TD Tablet PC Logo
50 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
micky dee
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
