Question about GE Profile Harmony DPGT750EC Electric Dryer
Lightning strike power surge partially disabled dryer.(Whirlpool)
Dryer works but after about 5 minutes it trips the breaker. With heat control turned off it will run with no problem.Dryer is about 4 yrs old.
  • 73 Answers
If it took a lightning strike something in the heating coil is shorting to ground tripping the breaker. DO NOT Keep trying it, you could cause more damage or even burn your house down.
Posted on Oct 02, 2009
Control board sparks, smokes and smells when trying to start
Did you have a lightning strike near by? Or power outage with a power surge. Could have shorted the board.
Mar 13, 2015 | Maytag Epic MGD9700S 27 7.3 cuft. Gas...
If the lightbulb burns out in a whirlpool duet gew9250pw1 dryer will that cause it to quit working
Generally, a burnt-out bulb will not stop the dryer from working. However, the bulb may have failed due to a power surge. In that case, you'll have to check the components that could have also been damaged.
First, check that the circuit breakers are on. (There may be two breakers for an electric dryer.) Next, is the drum turning or does the unit not start. If the control board buttons aren't responding, the electronic control is likely bad or the wiring harness has an issue. If you aren't getting heat, you need to check the thermal fuse (thermal cut-offs), wiring, thermostat (high temp limit) and element. A multi-meter will tell you if the fuses have the appropriate resistance (10-30 Ohms).
I hope this helps.
(note: if you recently had a nearby lightning strike and other electric appliances were damaged, check if your insurance will cover the costs of repair after you meet your deductible.)
Jun 07, 2013 | Dryers
Whirlpool Ultimate Care II dryer trips breakers.
No way to know unless you do some checking. This video shows how to get into the machine: HERE
I have a repair manual that features the same basic style of dryer you may want to take a look through: HERE
Feb 14, 2010 | Dryers
My Whirlpool Ultimate Care II dryer does not heat up, however it does tumble. Any help would be greatly appreciated. Thanks.
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 02, 2010 | Whirlpool Dryers
I have a Whirlpool dryer Model # LGR7648K20 that just stopped heating. THE DRUM TURNS BUT IT WILL NOT HEAT.
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to Good luck
Regards:
VOTIT
Dont forget to rate:
Jul 01, 2009 | Whirlpool Dryers
Whirlpool 29"gas dryer Model#LGN2000LW1
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Dec 17, 2008 | Whirlpool GGQ8831L Gas Dryer
My whirlpool dryer will not heat up
Heating element
Thermal fuse
Wiring
Dec 09, 2008 | Whirlpool LER5636P Electric Dryer
Dryer not heating
Heating element
Thermal fuse
Wiring
Nov 21, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer will not heat properly
Heating element
Thermal fuse
Wiring
Oct 17, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Dryer problem
Heating element
Thermal fuse
Wiring
Mar 11, 2008 | Whirlpool GEW9200L Electric Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
274 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
