Question about FrancisFrancis! X1 - Stainless Steel Espresso Machine
Low temperature Hi, the temerature guage sits on 20'C and only 60'C when the steamer is turned on? What can I do - please let me know? Thank you, Josh
  • 4 more comments
  • ethan67 Mar 31, 2008
    FrancisFrancis! X1 about 2 years old; Thermostat only goes to 60 for brewing instead of 90 and 120 instead of 160
  • b1tkw Apr 07, 2008
    I have the same problem as ethan.  The Thermastat reading does not go beyond 90 C.  Just happened a week ago.  I was able to make 4 espresso a day.  Temp doesn't raise high enough to even consider steaming.  Thanks for any help.
  • jadel1 Apr 09, 2008
    i also have this problem. my temperature will not rise enough to steam, and barely enough to make espresso. the machine is three years old. what can i do???
  • Anonymous Apr 09, 2008
    My machine temp is lower than should be
  • cadaveria Apr 09, 2008
    I have the same problem with my temp, just started!
  • Anonymous Apr 25, 2009
    I have the same problem.. the temperture gets stuck at 20 degrees even. It dosent affect the boiler though, it still steams just fine..
I had the francis francis examined.  It is indeed the boiler, a $200 fix if you could get the part.  Francis Francis X1 is now a brick!
Posted on Apr 14, 2008
Oh my...I too have this issue. While my X1 has been working perfectly for the last year, suddenly the thermostat has dropped to 40'C and 80'C respectively.
Posted on Feb 03, 2008
Where is the engine temprature switch in a 1998 jeep cherokee?
Hi there lewis3559! What i believe you are actually looking for is the engine temerature sensor. To locate the temperature sensor:
  1. Open Hood
  2. Locate the upper radiator hose
  3. Locate thermostat housing (the upper hose attaches to the housing)
  4. It is the 2 wire sensor next to the thermostat housing
If your ETS is not working properly the engines computer calculates the air/ fuel mix incorrectly resulting in poor fuel economy. It may also affect the temperature reading on your guage cluster.
I hope this helps you out, good luck!
Mar 31, 2011 | 1998 Jeep Cherokee
I have a Vienna my question is temerature of hot watheroutlet and coffeeoutlet temperature i have about 70 degreds celsius is it okej?
The temperature varies according to the use if you just pure out hot water for fist time should be around 90 degrees however after one or two mugs can go up to 75 to 80. The same is for coffee. In any case the 70 degrees is low. Please note that I mention the temp. at exit point not in the cup since some seconds after the exctraction is normal to go at 70.
Jul 01, 2010 | Saeco Vienna De Luxe Espresso Machine
My brother has leant me his 1993 Ford fairmont EB11. A red light is flashing intermiitanly it looks like a fan in some kind of cylinder. Could someone tell me what it is?
  • Full instrumentation pack (four ancillary guages plus tachometer) - with volt meter & oil pressure guage.
  • Speedometer, odometer, tripmeter, fuel guage & water temperature guage standard in addition to the above.
  • WARNING LIGHTS: High beam, rear window demist on, turn signal / hazard light, alternator fail, lights on, park-brake on, washer fluid low, radiator coolant low, cruise control indicator and low oil pressure.
  • AUDIBLE WARNING CHIMES: low fuel, lights on, low alternator charge, low oil pressure, high coolant temperature and brake failure.
  • Trip Computer standard featuring fuel consumption figures, distance to empty, average speed & time display.
I found this site, no mention of the fan in a cylinder, but I'll let you figure it out. Hope this helps.
http://www.trueblueford.com/ed_pages/EDfalcon_fairmont.html
May 31, 2010 | 1983 Ford Fairmont
2001 dodge neon, temperature guage not moving
try changing the heater sending unit it is a small metal unit usually on the manifold with a wire with a plug on it check your manual or get one from auto supply so you know what it looks like before you take out the old one
Dec 15, 2009 | 1992 Audi 80
Car overheating guage. Changed the temperature
Change the thermostat if you haven't already. It's inexpensive and easy enough to do.
Hop this helps...
Jul 05, 2009 | 1995 Toyota Camry
Sony tv won't turn on, standby light just flashs.
pls tell us specific problem that how many times LED blinks along with model No. to help you better.
thank you for using fixya
Nov 01, 2008 | Televison & Video
Have a Karcher steamer SC1002. The safety cap will not turn. Did not leave any water in it after I last used it. According to the instructions I needed to contact customer services but they were no help....
Dear friends,
I once solved a problem like this with a simple trick. The problem is that it should be done by a qulified tecnician. I will suggest this trick, but do not take responsability if unqualified persons try to do it. The trick is to fill the steamer again with water from some where else. Most probably the cover of the steamer has to be removed. Thou one can try to fill ot from the outlet. Now when there is water in the steamer, one must put it on, and let the temperature rise. When the temperature is at its normal reading, you just let it cool slowly. (leave as much water inside as possible). As it is cooling, you must try at intervals to unscrew the tap. If it is still very hot this is not possible(safety)....if it is too much cold, also not possible. So find the RIGHT and SAFE temperature. And the tap can be removed.
fulltech
Oct 13, 2008 | Karcher 2500 PSI Pressure Washer
FrancisFrancis! X1 - Stainless Steel Espresso Machine Logo
581 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Joe Lalumia aka...
Joe Lalumia aka...
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
