Question about Konica Minolta DiMAGE G600 Digital Camera
Can i but a new cover slide some where and how much?
Midland walkietalkies -how do you put in new
You have to remove the belt clip, then the battery cover. There is a locking tab at the top of the belt clip.
To remove the belt clip, press the LOCK TAB down , then gently pull the belt clip up toward the top of the radio.
Then remove the battery cover, press near the seam and slide the cover down:
Replace the batteries, observing polarity.
Slide the cover back on until it locks in place.
To install the belt clip, slide the clip down into the slot on the back
of the radio until the belt clip lock clicks.
Hope this helps! If you need more help, please ask!
Oct 17, 2013 | Midland LXT310 2-Way Radio
Replace belt on hoover vacuum U4655
Turn the machine over and remove the 4 screws which hold the cover on the brush. Remove the cover and brush roller. Remove old belt. Slide new belt over the motor pulley, first. Then slide roller through new belt (if self propelled model, slide roller through the small belt, also) and slide brush roller into slots on housing (note: slots are different, match roller sides to correct slot.)
Oct 22, 2011 | Hoover Vacuums
How do i replace the battery in the garmin streetpilot c330
Follow these steps : 1. Determine that you do have a Garmin GPS with a replaceable battery. Find the information by checking the manual or with a close inspection of the back and sides of the GPS unit. GPS units that have a battery that can be replaced by the owner will have a battery cover lock on the back or side; it looks like a small sliding piece of plastic with slots or ridges.
2 Open and remove the battery cover by sliding the battery cover lock and pulling off the battery cover. In some models, you may have to hold the lock up while simultaneously pulling the battery cover off.
3 Remove the battery by sliding the battery out of the battery cavity. You may need to use gentle pressure to get it to slide out.
4 Put the new battery in by sliding it into the battery compartment. Line up the metal contacts on the battery with the metal contacts in the battery compartment to make sure it is properly installed.
5 Click the battery cover back into place. The battery cover lock should automatically lock and secure the cover. If this does not happen automatically, slide the lock back to the locked position.
May 16, 2011 | GPS
Replace black PCU ricoh aficio cl3000
To replace the black PCU:
- Turn the printer off.
- Open the cover on the right side (as you're looking at the front of the printer).
- There are two green levers, one toward the front of the printer and one toward the back -- pull these out and lift the cover that they're holding all the way up (it should stay in place).
- Remove the black PCU by pinching the green lever and sliding the unit straight out.
- Take the new PCU out of the box, take off the tape around it and remove the cover on top of the unit.
- Align the new PCU along the rails the same way the old one was aligned (using the green arrow) and slowly slide it in. As you slide it in it will slide out of the bottom cover -- throw that cover away.
- Lower the PCU cover and slide the levers into place.
- Close the side door.
- Turn the printer on.
Mar 06, 2011 | Ricoh Aficio CL3500N Laser Printer
How do i remove the battery out of my garmin 1300
  • 2 Open and remove the battery cover by sliding the battery cover lock and pulling off the battery cover. In some models, you may have to hold the lock up while simultaneously pulling the battery cover off.
  • 3 Remove the battery by sliding the battery out of the battery cavity. You may need to use gentle pressure to get it to slide out.
  • 4 Put the new battery in by sliding it into the battery compartment. Line up the metal contacts on the battery with the metal contacts in the battery compartment to make sure it is properly installed.
  • 5 Click the battery cover back into place. The battery cover lock should automatically lock and secure the cover. If this does not happen automatically, slide the lock back to the locked position.
  • Mar 01, 2011 | Garmin nuvi 1300 Car GPS Receiver
    How do you replace batteries of a Sentry S0607?
    How to install electronic fireproof sentry safe batteries
    slide open the battery cover located just below the keypad.
    Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
    reconnect the connector and put back the battery holder. Slide the cover back in place.
    New advanced electronic lock safe battery replacement instructions
    May 05, 2010 | Sentry Fireproof Safe
    How do I open the case to install new ram?
    http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/cvrop.htm#1138085
    Steps from the manual:
    1. Follow the procedures in "Before You Begin."
    2. Lay your computer on its side with the computer cover facing up.
    3. If your computer cover has a cover latch, slide and hold the cover latch.
    4. Grip the indents on the computer cover, and slide the computer cover toward the back of the computer
    Jan 03, 2010 | Dell Dimension 4600 PC Desktop
    How do i replace the keyboard on a dell inspiron 1525
    How to Install a Replacement Keyboard on Dell Inspiron 1525 Laptop Computer You may need:
    • New keyboard
    • Screwdriver
    ---Be careful to not break off any of the plastic tabs on the keys as they are difficult to replace.---
    1. Turn the computer off and slide the tip of the screwdriver in the notch on the right side of the hinge cover (the plastic section above the keyboard). Slide the hinge cover up and remove it from the computer, exposing a series of bolts. Unscrew the bolts and remove them.
    2. Pull up on the edge of the keyboard and slide it forward toward the display. Slide the keyboard all the way out of the computer case slowly.
    3. Unhook the flex cable from the computer board to disconnect it from the computer.
    4. Slide the new keyboard into place, connecting the flex cable first.
    5. Screw down the edge of the keyboard with the 4 bolts from before and replace the key cover.
    6. Power up the computer and see how your new keyboard works!
    May 01, 2009 | Dell Inspiron 1525 Notebook
    Motorola Z3 cover won't stay open
    you juss need to get a new one! if it slides open that easy when you turn it upside down...then yea a new one needs to be suggested.
    Nov 23, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
    Replace hard drive on Gateway laptop
    get a New 2.5'' laptop hardrive, and follow the steps: - Turn off the Laptop - Take off the Power Supply - Remove the Battery - Remove the Screw from the Harddrive cover plate - Once cover removed,romove the other (2) screws that hold the harddrive - Slide the Harddrive toward the Screw Hole - Lift the Connection End. - Slide the New Harddrive towards the connection end, Put back the Screws & cover plate - install a new copy of Operating System.
    hope this is helpful 'suraj'
    Oct 10, 2008 | Computers & Internet
    Konica Minolta DiMAGE G600 Digital Camera Logo
    23 people viewed this question
    Top Konica Minolta Cameras Experts
    Greg Cann
    Greg Cann
    Willem.
    Willem.
    ktpierce
    Level 1 Expert
    Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
