Question about Water Heaters
I have a rheem rr40-38m water heater. today it started leKING FROM THE VALVE ON THE BOTTOM where you would normally drain ity. i had a hose on the fitting. I tried to tighten it and broke the plastic fitting inside the heater. I can probably get the remains of the valve fitting out. Can I get a replacement fitting? Also what would cause this problem, we have very hard water here in calgary?
  • 252 Answers
Cause??? Yes you can get new water heater drain valves- pretty common - or use a 3/4x6 gal nip and any drain valve
Posted on Oct 01, 2009
How do I drain my Rheem electric water heater? There is a screw on top of the turn valve. Do I hvae to loosen that before trying to turn the value open
No the small screw is to remove the handle only . close top valve and with hose attached to the bottom spigot then open that valve .OR CALL A PLUMBER
Jan 01, 2018 | Rheem Water Heaters
Drain valve plastic slow leak 81V-80D
If the drip is coming out of drain valve: Put a hose cap over end of drain valve.
If water is seeping out of cracked drain vale, then replace it.
If the leak is seeping around previously sealed threads, then tank may be rusted beyond repair.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
http://waterheatertimer.org/Leaking-water-heater.html
Oct 06, 2012 | RHEEM 30 GAL ELEC TALL Water Heater 6YR SC...
I have a 21v407 Rheem water heater that is leaking from the top relief valve. The leak i believe, is from under the valve. what is this problem. and how do u drain this thing?
Shut off the water supply valve over the heater. Shut off the electric or gas to the heater.
If you have any house or basement water valves below the level of the heater, open them and open a valve that is higher to vent it.
If necessary, open the drain at the bottom of the heater and using hose or buckets, lower the level below the relief/thermostatic valve. Be careful, the water is hot and softens even heavy hoses.
Once the water level is down, unthread the downtube (if there is one) from the discharge of the relief valve, unthread the relief valve from the heater and either dope/tape the threads or replace the relief valve.
Write back with any questions.
Sep 09, 2011 | Rheem Water Heaters
Pop off valve dripping Rheem 50 gal electric valve at bottom
If you are reffering to the drain valve at the bottom of the hot water tank. It may be leaking due to the O ring being cracked or worn out. You can either drain the tank and replace the valve or you can buy a hosebib brass cap and thread it on the existing valve. There is no cause for alarm when doing this as this valve is just to drain the tank when replacing your hot water heater
Feb 23, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
How to drain the rheem 135 litre tank
1. turn off the electrical power first.
2. attach a garden hose to the hose bib attachement on the bottom of the water tank and run the hose outside to allow the water to drain out by gravity.
3. Turn the valve that is on the inlet of the water heater. Now that the power is off, you can drain the tank.
4. open the drain valve where the hose has been attached.
5. To release the pressure, you can open a hot water faucet in your kitchen. This will allow the water to drain out easier.
Sep 12, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Dripping from drain spout
If you are refering to the "Dripping coming from the preasure tempature valve,Then just turn off the valve where the water goes into the heater and open the P/T valve with a bucket below it draining only emought water to get below the level where it reaches.     Normally the drain valves are plastic with a Male hosebib attached.  Attach a  garden hose to the rain and run it out to a point lower that the vaslve in order for gravity to drain the tank.The valve opens counter clock wise. If the valve is stuck or does not drain,and you have a foor drain handy,remove the whole valve and replace it with a boiler drain valve.  If The tank is located below the drain level then you will have to either pump or carry the drain water to the higher level.     Replace the P/T valve  and reinstall the associated associated piping. I would use tefelon tape on the P/T pipe theads.    You may have to open a hot water faucet in order for the air to replace the water in the tank ,in order to drain.
Jan 31, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water Heaters Logo
581 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
