Question about Echo Garden
How do I replace the clutch sprockt?
I need to know what I need to do to replace the clutch sprocket.
  • dhl4668 Sep 29, 2009
    My saw is an Echo CS-370. It is the sprocket (drum)that the chain goes around that I need to replace. I don't know how to remove the hub.
    Watched the video. Good info. Thanks.
    President:
  • 2,220 Answers
You didn't provide a model number, our instruction could have been more specific if you had.
R² Drive Link Outboard Clutch
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check at the IPL for your saw to see if any special tools are needed.
  2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. It is probably a left handed thread (tighten it to loosen it).
    Let us know how it worked for you. GL
    Lou
Posted on Sep 29, 2009
How can i stop the noise from chain set?
hi there is your chain in good condition or worn out ,is the chain dry and needs oiling or is it incorectly adjusted for the bike ,or is the chain out of aliagnment these would all cause noise problems ,or if the chain has been replaced before is it the right size for the sprockets ,and are the sprockets in good condition ,to check if the chain is stuffed move the chain sideways left to right of your bike and if it moves more than a sixteenth of a inch it is worn out .hope this helps cheers
Apr 23, 2014 | Yamaha YZF-R15 Motorcycles
Stairmaster left pedal clanks
The "clunking" you are describing is more than likely caused by either a faulty left drive sprocket, the drive shaft or a combination of both. The drive sprockets are equipped with a needle bearing type clutch. When they fail, the clutch does not grab the shaft and drive it correctly. You may just need to replace the left drive sprocket. In some cases you will need to replace the sprocket and the drive shaft.
Drive Hub for Stairmaster Steppers 4000PT 4400CL 4600CL 4400PT 4600PT...
Sep 30, 2013 | Stairmaster Exercise & Fitness
Motor runs but chain does not move
Probably the shaft on the sprocket has sheared off.
Knox Knolls Outdoor Power Equipment
Springfield, IL 62704
www.knoxknollsope.com
Oct 14, 2012 | Remington Electric Chain Saw
Echo chain saw sprocket not turning.
A few clicks form here will get an Illustrated Parts Manual, I find them them helpful.
EchoUSA
http://www.echo-usa.com/faqs.asp
If I read the pictures correctly it has an outboard clutch, this may also be helpful.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
  1. Check the IPL for your saw to see if any special tools are needed.
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
Lou
Nov 11, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
NEED TO KNOW HOW TO DISASSEMBLE SPROCKET FROM POULAN PRO (replacing a worn sprocket)
I think it is an inboard clutch, use this as a guide to remove what you can:
R² Drive Link Inboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=YUbSIHMSSP8
The C-clips tend to fly when being removed. Please wear eye protection and exercise care.
Use this as a guide to remove what remains. Remove the rope/cord piston stop before installing new clutch; rotate the opposite direction and reinstall after piston again above the exhaust port.
Lou
If all you are doing is replacing the drive sprocket ignore outboard clutch instruction. If replacing the centrifugal clutch it is helpful.
Nov 07, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Super25DA old chainsaw from the mid 70's.
Call your local Power Equipment Dealers and ask if any of them deal with OREGON replacement parts.
OREGON makes clutch drum, chain and bar combinations in the thousands!
NOTE: Along with clutch drum and chain replacement, your bar will need to be changed also, as the sprocket-tip in the nose of the bar will be a different pitch.
Oct 01, 2009 | Garden
Homelite chainsaw sprocket and clutch for chain
You can get the parts at your local tool rental store.. They should be able to do the service themselves to if you dont want to do it.. Let me know how you make out..
Jun 06, 2009 | Garden
How do you replace the chain drive sprocket on an Echo CS-440?
you need to replace the clutch, you woould pull the side cover off and remove the bar and chain. then you remove the nut holing the clutch on( the clutch and sprocket should be on piece) take it to your local saw shop and grab a naw one.
Mar 18, 2009 | Garden
Garden Logo
155 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
