Question about Cameras
I have got error cf on my sandisk extreme 111,but i want to view my photos, what can i do?
Sandisk Extreme 4 Gig card. 151 photos on card, copied to computer. Took 140 more photos, viewed them on the camera many times. Tried to copy to computer, no photos are present in finder window and no...
try out in another computer whether the pics r there or not if there copy paste them in a separate folder in computer last time did u cut n paste or copy n paste try recalling if u have done the cut n pasting process the data will not be there in memory card
Sep 23, 2010 | SanDisk Extreme III 4GB Secure Digital...
SanDisk Extreme III 4GB, unable to retrieve the 500 images on it.
SanDisk Extreme cards are supposed to ship with RecoveryPro software which should help you get the photos back. If the software is not on your card you may be able to get it from their website or another SanDisk card.
Mar 27, 2010 | Cameras
Sandisk extreme III says CF full when the card is empty
If you've tried the usual fixes like reformatting the card and trying it out in other cameras, then there is nothing more you can do to fix this.
Fortunately, Sandisk are very good at replacing faulty memory cards provided they've not suffered physical damage. Just contact the company to find out how to exchange your CF card.
Nov 06, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
Card error
Take it to a camera store and ask for a data recovery. Once the data has been recovered, format the card in the camera and you should be fine.
Aug 10, 2009 | Cameras
Sandisk ext'me IV 8GB cf card states 'card error' in olympus e410
Please format the CF card in your computer with an external cardreader on full format and probly your card is working on an Olympus E410
Mar 08, 2009 | Olympus EVOLT E-410 Digital Camera
Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
Best regards - Michael
Jan 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
I have an E410 DSLR and am trying to use a Sandisk Extreme IV CF card of 4GB. I get message stating card full until I try to format it and then get a card error. Can you help ?
Currently Olympus has successfully tested Sandisk Extreme 3 up to 8gb without any card error messages. It sounds as if it is a card compatibility issue. Try to exchange to an Extreme 3 and you should be able to use that without any issues.
Aug 29, 2008 | Olympus Cameras
Err CF
Observe the connector inside camera, using a flashlight. If there is a bent pin take the camera to service immediately. Don't turn it on any more as we did in one similar case - creating a short circuit that damaged the camera electronics and voided the warranty.
If no visible problems, remove battery and leave it out overnight.
Jan 15, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Cameras Logo
56 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
