Question about Toshiba TDP-S8 Multimedia Projector
Ceiling mounting which holes do i use t mount the tdp s8 on the ceiling?
I unscrewed the two rubber stands on the bottom and used those to screw it to the ceiling mount. Seems to work pretty well!
HTH!
Posted on Mar 03, 2008
  • gatorbo Sep 06, 2011
    That worked for me as well, but I had to take it apart and remove the tiny nuts that the rubber stands had on the tips, otherwise you run the risk of a shock or messing up your bulb with those tiny things rattling in there.
I am looking for a hardware that will allow me to install Toshiba TDP-T45 on ceiling.
you can get a universal ceiling mount from pc world or online at toshiba get any toshiba.
Feb 05, 2010 | Toshiba TDP-T45U DLP Projector
How to mount using a universal ceiling mount
first, find out the distance range on your projector for the best fitting image on your wall. next, what type of ceiling? if it's a drop ceiling, use a plate to span the 2 feet between braces and clamp it to them. and it's always safe to attach a safety cable from the mount to something sturdy, like wood or heavier metal. if you are putting it on a drywall ceiling, find a stud to screw it in to. do not use drywall anchors to hold it. if you can get above the drywall, use a backer board (2x4 or plywood, 1/2" or thicker) and screw the mount through the drywall into that. the other end of the mount screw into the bottom of the projector (3 or 4 m4 holes should be already on the bottom of the projector. use the screws provided. you'll have to adjust the mount so it matches the projector holes. once it's mounted, you'll have to adjust the image. go into the menu and select ceiling image, and adjust the keystone. pop in a movie and enjoy!
Dec 22, 2009 | Acer P3250 DLP Projector
Cant remember password for my toshiba tdp s8
I had a projector toshiba TDP-S8 but it is used when i turned it on it required a password what can I do
thank you
Nov 09, 2009 | Toshiba TDP-S8 Multimedia Projector
Is toshiba TDP-S8 good projector because I bought it today for $ 300.00 used. Thank you
Toshiba's s8. Designed to deliver stunning images in breathtaking XXL format, the TDP-S8 features 2000:1 contrast, the latest DLP technology for brilliant color and sharpness, and 2000 ANSI lumens brightness for top performance. The product retailed for close to two thousand dollars. Due to problems production was discontinued. If it works for you then you got a good deal. Replacement parts are easily available on ebay.com for reasonable prices.
Jul 01, 2009 | Toshiba TDP-S8 Multimedia Projector
TDP-S8 Power supply led not lighting up. Unit not working
There seems to be problem in your power supply. Look for any swollen capacitor --- generally 3300uf, 10V. Be careful about the polarity of the capacitor before you take it out. Check the capacitor to make sure how it's mounted ( for polarity purpose). Negative side of capacitor will be toward the outside of pc board. Substituting 2200uf, 16V capacitor for 3300uf, 10V will work ok.
Mar 15, 2009 | Toshiba TDP-S8 Multimedia Projector
It shows no signal
Toshiba TDP-S8 projector cannot communicate from my laptop, it shows no signal. how can i fix it? thank you so much...
Feb 19, 2009 | Toshiba TDP-S8 Multimedia Projector
HOW TO RESET TOSHIBA TDP-S8 LAMP
after installing the new lamp, hold the volume top & bottom key simulteniously, when green light indicate at panel start the projector & go to service there you may found reset lamp ? press yes the lamp will reset.
Feb 01, 2009 | Toshiba TDP-S8 Multimedia Projector
TDP-S8 only run for 20 sec.
Possible filter problem or sensor related to over heat. Might also be a bad bulb or worn out bulb.
Leaning more towards bulb replacement.
Dec 08, 2008 | Toshiba TDP-S8 Multimedia Projector
No Power to My Toshiba TDP-S8
Console and mainboard not communicating. avalontc.com
Jun 05, 2008 | Toshiba TDP-S8 Multimedia Projector
Toshiba TDP-S8 Multimedia Projector Logo
171 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
