Home | Dell | W2600 26 in. LCD Television | I am having right the...
Dell W2600 26 in. LCD Television
Problem for Dell W2600 26 in. LCD Television
I am having right the opposite from most problems I have read....
By twillie36265 on Sep 29, 2009
The 26 inch Dell I have will power up but not stay on for more than 30 seconds can anyone pinpoint the exact problem? Wanted to fix myself this TV is not in warranty!!!!
Best Solution
posted on Sep 30, 2009
Very Helpful)
kenzmailroom
Rank: Guru  Dell Expert
Rating: 88%, 39 votes
yes, this problem is called intermitent power. The is not enough volts on the power board. Mainly because there is a loose or burnt out connection on the board. With a digiatl meter, perform a resistence test. (If familiar with process)If you have soldering exp. You can resolve this problem yourself. Otherwise, it will require replacing it. I have a unit here with me with the same problem. Once i look into it, I will share any additional info i feel may be useful.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Dell W2600 26 in. LCD
Questions and Unsolved Problems for Dell W2600 26 in. LCD
Do you recommend Dell W2600 26 in. LCD Television?
Answer
Answer
vga signal is present but(on the screen dell self test feature check) is displayed continus
Answer
dell w2600 relay clicks at turn on,will not click at turn off. does not come on
Answer
have to unplug tv for hours for it to turn back on
Answer
the problem is with the capacitor inside the tv the power is not being transferred from the wall to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell W2600 26 in. LCD...:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
