Question about Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334 GB SATA Hard Drive
Cant detect hard disk
Even if trying cable select for many times!!!!
  • Anonymous Jan 02, 2008
    When I conect to the One touch Mini - the screen goes blank, and nothing happens
  • Anonymous Dec 14, 2008
    Other computers detect the drive fine except my computer. Just recently uploaded XP Service Pack 2. Do you know if this drive has issues with this?
  • 142 Answers
Hi all,i just had the same problem, heres how i fixed it.
in bios, check you settings
if using ide and sata, enable combo cable select
check motherboard compatability 1.5gps or 3.0 gbs
if 1.5 insert jumper on back of HDD
check now in BIOS to see if HDD seen.
now boot windows, open control panel, administrative tools, computer managemant, disc management and select drive, it may need to be formatted.
Posted on Jan 30, 2009
    Scholar:
  • 73 Answers
Try setting one drive to master with the pins and the other to slave... Also, check in your BIOS to see if they're being detected there; if they aren't, you probably have a dead (or seriously screwed up) drive.
Posted on Dec 25, 2007
External hard drive not seen in my computer, disk manager and device manager
Can you see the lights or hear spinning. Try using the hd on a diff system also use a different USB cables.
You could also open up Device Manager -> click on View -> select Show hidden devices -> expand all the nodes by clicking on "+" symbol and if you find any greyed ones right click on them and select Uninstall -> restart the computer and try to connect your drive again.
Jul 16, 2015 | Sony 500gb External Hard Disk Drive, Usb...
My Computer use windows XP Operation System. hp 540 laptop when I turn on windows, it show black screen with cursor. It cannot continue log to windows. I check in bios cannot detect hard disk. How to solve...
Open your laptop and and fix the hard disk cable.After this start laptop and check the bios if HDD detected then select boot device and select first boot device is Hard disk.Save the setting and restart the window.You are able to open your window. But If Hard disk drive is not detected change data cable,power cable of Hard disk.If hard disk is detected in bios follow upper rules. And if it is not detected again you should walk into Hard disk repairing center and check hard disk there.
Jun 07, 2011 | Computers & Internet
The hard disk worked well for 20 days..but then one day my system didnt detect the hard disk.I tried to disconnect the cable n reconnect again.but didn't work..
If your computer or laptop has a problem detecting a USBhard drive or a USB device, and another computer can detect it, then the problemcould be a RF interference problem. Try using an USB cable that is a shielded USB cable (ie. AnUSB cable that has a clear plastic covering and you can see a metallic weavewhich covers the wires) OR a USB cable that has a Ferrite core attached to theUSB cable (the ferrite core is a cylindrical object approximately 30mm long X15mm diameter and it is attached to the USB cable near the connector).
May 30, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My motherboard cant detect hard disk ,disk driver and when i start my computer it dint show HDD LED light (red light) and it show "No Hard Disk detected, Please insert Hard Disk and Press Enter. i...
THere maybe a problem with the SATA/IDE connection.Check the connection first using another cable or try to another port. If it doesn't work, try the drive on another PC. Check for the power connection cable as well.
Let me know if this works,
levibit
Dec 17, 2010 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Western Digital USB powered WD600U017 drive Does not appear to be spinning up. This drive has been in use for 2 years When plugged in the drive makes 3 beeps 2 low ones followed by a higher one. It...
The first thing I'd recommend is to check Disk Management, to see if the computer is detecting is as a hard drive. ( Right click on my computer, hit manage, and under Storage, select 'disk management').
From there you'll be able to see how it's detecting the hard drive.
Even if Device Manager detects it, if Disk Management does not, you know it's not being 'properly' detected.
From Disk Management, you can format the drive, or reassign a drive letter (if needed).
I've had a similar issue where the problem was the power connector to the hard drive. If you have important data on the hard drive, you could open the external case, and attach the hard disk with a separate usb device, such as http://www.tigerdirect.com/applications/searchtools/item-Details.asp?EdpNo=3276554 . Good Luck.
Nov 16, 2010 | Computers & Internet
Dell Optiplex Gx280 - cant detect two IDE hard drives
You should attach two hard drives on primary ide. Set both jumpers to cable select ( or one on end is master, middle one is slave). The one at the end of the cable is where your o/s should be. You could try putting the third on seconday, along with your dvd rom.
Hank
Jun 09, 2009 | Dell Optiplex GX280 (99301) Motherboard
Hard disk not detecting
Hi
The hard disk witll have jumper , try selecting it to CS (CAble Select ) and then boot should detect.
Dec 31, 2008 | Computers & Internet
Hard disk
first be sure the drive is a vaible drive.....meaning it should be in it;s originbal PC it came out of and able to boot up on the installed OS. If it can then you are in luck..... install the drive you want to copy to as a slave and use a program like DriveCopy or Norton Ghost to copy the entire drive.....or if you are just after select files, you can use the copy/paste method to the drive. By trying yo use the drive in a different PC it will not boot since it has the other PC's drivers on it =( If the drive will not detect in it's native machine then most likely the drive is lost (unless you pay to clean room recover the contents....spendy!) Let mem know if you need more help!
Jay
Jul 30, 2008 | Computers & Internet
Disk boot failure, insert system disk and press enter
The drive should be set with jumpers or cable select to be primary master. Some pc & drive combinations don't like cable select, others insist on it. Try both, one at a time.
Jul 15, 2008 | Western Digital (WDXB1200BBRNN) 120 GB...
System not detecting hard disk
is that a sata drive or ata?...if ata, try to change the IDE Cable that connected to your Hard drive?..
Feb 26, 2008 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334 GB SATA Hard Drive Logo
439 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
