Question about Garden
The oiler on my ms 361 isnt working i tried cleaning it out but it didnt help what else could it be
    President:
  • 2,220 Answers
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at connections. If equipped with an oil pump it is usually behind the clutch (probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
You are not the one to have problems with teh oiler on a 361. Talk to your dealer, there may be an unannouced recall.
Posted on Sep 29, 2009
  • 143 Answers
Check your chain oil pump. It is mounted behiend the chain drive sprocket,
you`ll find the gears might be worn or sheared. You should be able to buy
parts in a repair shop or a hire shop. Stephen.
How to adjust chainsaw oiler on stihl MS230
you cant. the oiler on an Ms230 is preset and non adjustable. Make sure the oil worm gear isnt damaged
Apr 13, 2014 | Stihl 021 023 025 Ms210 Ms230 Ms250...
Chaisaw oiler on ms390 stihl is not working
Take bar and chain off and ensure oil feed is not plugged also use only stihl bars
Feb 11, 2013 | Stihl Hand Guard Chainsaw Ms 290, Ms 310,...
My M-R0013 or M215 logitech mouse isnt working the light at the top witch useually is green is now red and the mouse isnt working i tryed new batteries but it didnt work still i think it might be USB
Try out MS Fixit. Use IE (Chrome did not filter correctly). SelectWindows. Use USB as the filter.
There should be 2 executables (test these) and maybe some other solution. This a fairly new and dynamic site, so a little feed back would be great.
http://support.microsoft.com/fixit/
Oct 09, 2012 | Logitech WIRELESS MOUSE M215
My coins on diwips games ,,best casino have been taken,,no my coins are a minus 414,000,000 ,,and i cat play,,,why?
YAL HAVE NOT PAID ME..I HAV WON ON BIG WIN OVER 10,000,000..YAL DIDNT EVEN GIVE ME HALF.YAL STILL NOT PATING ME ON BIG WIN..I WROTE DOWN DAY TIME AMOUT. DIDNT GET A COIN.JUST THAT YAL HAV PAID ME.YAL DIDNT .I PAY TO BUY COINS.I USE TO LIVE YALS GAMES.BUT YAL ARE CHEATING PEOPLE OF THIER COINS FATZ 361 361 @YAHOO.COM
Sep 28, 2012 | Diwip Gaming Networking Best Casino
Have a stihl MS180 and it is not pumping any oil out of the hole and slot that makes contact with the bar. How do you remove the oil pump?
To remove the oil pump you need the following:
Assembly tool 1123 890 2200 Removing oil pump Puller 1130 893 1400 Installer 1130 893 1500
I would recommend trying to clean out the oiler first.
Please comment on this and tell us what type of oil you were using. There are rumors of wrong oil clogging or wearing the oilers. Was it used motor oil? Thanks Joe
Feb 16, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Stihl MS 250 16"
take the bar off and give it a good clean, get compressed air and blow it into the oil tank, making a seal around it first
May 09, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
I have a McCulloch 3516, The oiler isnt pumping. The screen is clean and free of dirt in the resevoir but the saw isnt pumping out any oil?/ How can I toubleshoot/ fix this problem?
Your basic model number is 600035. There are 11-, 21-, and 22- prefixes used with 600035s. There are also a ton of suffixes with the 600035s. I think the suffix is on your saw immediately after the basic model number somewhere (usually on bottom of older Macs along with the serial number. The dash of the serial on older Macs is the prefix). I must defer to you to find your exact IPL, here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
I chose this one as an example "22-600035-58" for an IPL
http://www.ordertree.com/modelinfo/MCC/22-600035-58-Mac-3516-IPL-211229-01/139.22-600035-58-Mac-3516-IPL-211229-01.1.59.1.html
The "Powerhead Assembly" lists an oil pump (1) and a worm gear (10). These are the most common failure on most saws but Macs have many more hoses than most. There are oiler components on at least 2 different details. It sounds as though you have done most of 1. Continue with 2. It appears the oil pump is on the starter side of the engine. and you may need to remove the fly wheel for access. I would examine every connection and perhaps try the "Kit Gear/Plunger Assembly" before trying to access the oil pump and gear.
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
Please see the IPL to aid in oiler component identification. Good luck with your project
You can reply below with any questions. I hope you found this most helpful.
Lou
Jan 30, 2010 | McCulloch Garden
I have a McColloch 16 in chain saw MS 1635 AV.
remove side cover,bar & chain.above bar mounting studs find a oblong channel that lines up w/ the small holes in the bar.clean everything,sawdust gets packed in the holes.if it leaks oil out the bottom,you need to replace the oil feed line fom the tank.
Sep 21, 2009 | McCulloch Garden
Kill switch not working
Brand new should be warranted; take it back to your dealer. Attempting to repair it yourself may void your warranty. Lou
Sep 02, 2009 | Garden
Garden Logo
177 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
