Question about Maytag Dryers
My dryer ignites and after a few seconds the flame goes out
My dryer ignites and after a few seconds the flame shuts off and dryer keeps running as usual but no heat.
    President:
  • 1,304 Answers
Hold and assist coils
with model number i could get you the part numbers
Posted on Oct 03, 2009
White knight gas tumble dryer lights then cuts out
Flame sensor next to the burner is eather bad or there is a bad connection at the flame sensor (that's why the kick works)
Jan 05, 2014 | Dryers
Mod 417.94052500 won't heat
Have you tried to watch or listen to see if you hear it ignite and then it goes out or does it not try to ignite at all?
If it doesn't try to ignite at all, replace the igniter with this part.
If it ignites and goes out after a few seconds, replace the flame sensor with this part.
Oct 19, 2012 | Kenmore 77632 Gas Dryer
The igniter wasnt igniting.. i changed it. it ignites and gets hot for a few seconds then goes out. may have put the thing back together wrong. help
The problem is either the flame sensor or dryer coils. First check the flame sensor also called the radiant heat sensor for continuity. If it has none replace it. If it does have continuity the dryer coils need replacing. They are easy to check and replace. Here are a few links that should help
Replacing the dryer coils
Flame sensor replacement
Troubleshooting a gas dryer
Oct 22, 2010 | Dryers
Amana NDG2335AW Gas Dryer runs but doesn't heat
Check the spark ignitor when firtst starting the dryer up. It should click within the first 15 seconds to light the pilot up
May 31, 2010 | Amana NDG2335AW Gas Dryer
My Rheem Ruud 25M01A water heater flame goes out before the thermostat is satisfied. The igniter goes into a ignition sequence from here on trying to get the flame to ignite for ever. If i turn the unit...
Check the air lines going to air pressure switch for cracks or splits. I know that will affect the gas valve but not sure if that is your problem.
May 07, 2010 | Heating & Cooling
Gas dryer mod.# MDG6000BWW, Igniter lights but no flame
Replace the flame sensor on the side of the heat canister. You may also have to replace the gas valve coils.
Aug 27, 2009 | Dryers
Flame shuts off after five seconds
HI! I BELIEVE THE PROBLEM YOU ARE HAVING IS CAUSED BY A PART CALLED THE THERMOCOUPLER. THIS IS A SAFETY DEVICE THAT SHUTS OFF THE GAS IF THE FLAME GOES OUT, BUT IT NEEDS HEAT TO MAINTAIN THE PROPER CIRCUIT. THIS MEANS THAT THE THERMOCOUPLER IS BAD AND NOT HOLDING THE GAS VALVE OPEN AS IT SHOULD. IT IS A SMALL THIN ROD TYPE THING THAT WILL BE VERY CLOSE TO THE PILOT OR IGNITER AND IT HAS TO FUNCTION PROPERLY TO ALLOW THE GAS TO CONTINUE TO FLOW. WHAT IT IS DOING IS GETTING JUST WARM ENOUGH TO OPEN THE GAS VALVE, BUT THEN THE IGNITER STOPS AND THE BAD THERMOCOUPLER COOLS AND TURNS YOUR GAS OFF. YOU NEED TO REPLACE THE THERMOCOUPLER AND YOU SHOULD BE BACK TO WARM CLOTHES IN NO TIME. HOPE THIS HELPS YOU. ANY QUESTIONS, JUST REPLY AND I'LL HELP MORE.
ARCLIGHT1217
Nov 02, 2008 | Maytag MDG2706A Gas Dryer
KENMORE gas dryer
Hi .No The Solenoids Are Turning The Gas On . I would Check The Venting . Remove The Venting Clean All Venting. Thanks The Appliance Doc
Oct 03, 2008 | Kenmore 73952 Gas Dryer
Gas dryer
hi. no not now. i would check the venting. clean the venting. thanks the appliance doc
Oct 03, 2008 | Kenmore 73932 Gas Dryer
Dryers Logo
132 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
