Texas Instruments TI-30XA Calculator Logo
Posted on Sep 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i add fractions and come up with an answer that is not an improper fraction? Example: I would add 4 3/4 + 7 7/8 and get101/8 instead of 96 5/8
Anonymous
Level 1:
  • Contributor 30 Answers
  • Posted on Sep 29, 2009
Anonymous
Contributor
Level 1:
Answers
30
Questions
0
Helped
15707
Points
50
See manual on p.6 how to enter mixed fractions. Adding the two fractions should work as long as you enter the two fractions as mixed fractions. I would post directly, but it's easier to read in the manual:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000010660.pdf
k24674
Level 3:
  • Texas Instru... Master 8,093 Answers
k24674
Level 3:
Answers
8093
Questions
0
Helped
4672654
Points
21595
You add them normaly, not worrying about the display until the final result. Then you press [2nd][c/d] and it will converted.
Hope it helps
2answers
How to solve franctions
Multiplying Fractions:
  1. Make sure you're working with two fractions.
  2. Multiply numerator x numerator, then multiply denominator x denominator.
Dividing Fractions:
  2. Flip the second fraction upside down.
  3. Change the division sign into a multiplication sign.
  4. Multiply top x top and bottom x bottom.
Converting Mixed Numbers into Improper Fractions:
  1. Convert mixed numbers into improper fractions.
  2. Take the whole (non-fraction) number and multiply it by the denominator.
  3. Add that answer to the numerator.
  4. Put that amount over the original denominator and you will have an improper fraction.
Method for Adding and Subtracting Fractions:
  1. Find the lowest common denominator (bottom number). For both adding and subtracting fractions, you'll start with the same process.
  2. Multiply fractions to match the lowest common denominator.
  3. Add or subtract the two numerators (top number) but NOT the denominators.
Mar 07, 2017 • Homework
What are improper fractions equal to 4 2/3?
I think of pizzas when doing fractions. If you cut the four full pizzas into thirds, how many slices will you have? Add this to the two other slices and you get your improper fraction.
So, to make an improper fraction, you multiply the whole number by the denominator and add it to the numerator. To get more improper fractions, you can multiply the numerator and denominator by the same number.
3answers
Multiplying mixed fractions
Convert each mixed number (what you call mixed fraction) to an improper fraction, then multiply the two numerators and multiply the two denominators. Reduce the resulting fraction to its simplest form
Example
(2 1/3)*(1 5/7)=?
Convert 2 1/3 to an improper fraction 2 1/3=2+ 1/3 = 6/3+1/3=7/3
Convert 1 5/7 to an improper fraction 1 5/7=1+ 5/7 =7/7 +5/7=12/7
(2 1/3)*(1 5/7)= (7/3)*(12/7)= (7*12)/(3*7)
The 7's in the numerator and denominator cancel one another leaving
12/3=4
(2 1/3)*(1 5/7)=4
Not all products of mixed numbers will give a simple result as this one. More likely they will not.
5helpful
It is showing fractions instead of Decimals when i do equations like (4 divided by 9) it gives 4/9 instead of the decimal.
Calculation results will be displayed using
fractions, r, and ?. When you press CHANGE, the display will cycle
through the following display styles:
• Mixed fractions (with or without ?) ? improper fractions (with
or without ?) ? decimal numbers
• Proper fractions (with or without ?) ? decimal numbers.
1helpful
How do you do a fraction on a sharp el531w
Hi eamon at hom,
Doing fraction on the Sharp El 531W really isn't that bad. I had to use pictures because, the symbols will not transfer over to your posting for me to show you. When you select the [ON/C] this clears the calculator of previous calculations and, data so that they won't interfere with your new calculations.
Let take the first example where a mix number is being added to a improper fraction. Because I used the [a^b/c] key this makes the calculator display the answer in a mixed fraction format or, a proper fraction format. If I press the [a^b/c] key again after the answer the format will change to a decimal format. The fractional formats are displayed in a mixed number, improper or, proper fraction formats. A improper fraction is really a proper fraction number with the top number (numerator) is greater than or equal to the bottom number (denominator).
[ON/C] [3] [a^b/c] [1] [ [a^b/c] [2] [+] [4] [a^b/c] [3] [=] mixed number results. Now let's do the same calculation as a improper or, proper fraction format.
[ON/C] [7] [a^b/c] [2] [+] [2] [a^b/c] [3] [=] still a mixed number result. Even though I enter the fractions in a improper and, proper fraction formats the calculator will still display in a mixed number format. This is because the calculator first displays as a mixed number if it can. If it can't then it will display the value as a proper fraction and, never as a improper fraction. To convert from a mixed number to a improper fraction format if the calculator did not convert it to a proper fraction, I have to use [2ndF] [d/c] keys on the command line.
This show a little more complex raised power use of the [a^b/c] key.
This shows the [2ndf] [x^-1] keys being used to calculate fractions.
When I first saw this question being asked it, was answered with just use the / command. Which that isn't really a good answer because, in math we like to use elimination. If you use the / command eventually the numbers are going to be rounded off and, your not going to be able to eliminate anything. If you have any further question on how to preform fractions with this calculator be sure to post your comment and, I'll be glad to help.
1helpful
3answers
Mixed fractions
When you get a fraction for he answer: shift-S<->D[a b/c<->d/c]
This way, you change it to a mixed fraction or improper fraction
1helpful
Fraction problem
follow the following sequence of steps
mode>exact/approx and then select approx
Fraction problem
Go into MODE to the second page.  In Exact/Approximate, change it to Approx instead of Auto or Exact.  This will give you decimals instead of fractions.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
