Question about Sony VAIO PCV-W20 PC Desktop
Cleaning my computer
I want to open the computer to clean it. Maybe it will help as I suddenly have a flickering screen coming on and I have to reboot the system to have it work again.
thank you for your help.
  • 231 Answers
Hi to clean up inside the best solution is to go to your nearest computer shop and buy a spray can of compressed air and a hardware shop and buy a small soft paint brush.
Disconnect all power and open the case with the computer on its side. Gently brush all dust you can see away and then using the spray blow out all heatsinks and that should help.
You should also make sure that all the PCI cards are pushed in firmly, especialy the graphics card.
Regards mistyman
Posted on Dec 19, 2007
Lenovo screen lines
Its a sign of bad RAM. Something it happen because of dust in the ram or something its indicate that ram is going to expire. If it is possible so I will recommend you to open your computer and clean the ram and try it again. If the problem will still present then you have to change your RAM.
Oct 17, 2013 | Computers & Internet
My Toshiba M55 Laptop has a vertical 'ribbon' of flickering. Is it fixable?
Maybe your screen is going bad or the video card inside the computer is going bad. Try connecting another monitor to the computer to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without the vertical ribbon then your lcd screen is bad and your video card is good. If the Borrowed monitor displays the same vertical ribbon as your lcd screen then your video card inside the computer has an issue.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 31, 2012 | Toshiba Satellite M55-S329 Notebook
I have one pro view 17" view sonic monitor CRT with win xp as my OS. when i am working in my computer suddenly the contrast and brightness symbol comes on the screen and begin to increase to maximum...
buttons are not working perfect.therefore pressing automatically. you have to remove the panel after power on the monitor, (it may be dangers therefore get support by electronic technician , he will remove buttons and solder new ones or replace the switch panel.
Jan 18, 2011 | ViewSonic E70fb 17" CRT Monitor
When my monitor goes idle, I can't get it to come back on. I eventually have to shut it down and reboot. And then maybe it will come back on. didn't use to do that before:
I dont know the answer but i also got the same problem.. When i start my pc suddenly one flash will come in monitor and go. then i've to reboot my pc through switching off power and then on(Cause nothing in monitor i cant see anything for turn off or restart) then may be on 2nd or third reboot screen will come..
Dec 09, 2010 | ViewSonic VA712B 17" Flat Panel LCD...
My desktop shutdown after several minutes, reboot it again but it shutdown again. reboot again but same thing happen, pc shutdown. what is the problem?
That's like stating my car was going down the road, then suddenly died. What is the problem?
Open the hood, take a look. Maybe it's something obvious.
Same thing with a computer.
1) Computer unplugged from power, open the computer case. See if the Processor fan is dirty, and the computer case fan/s.
If so use a can of compressed air for computers, and clean.
BEFORE you reach inside your unplugged from power computer, observe Anti-Static Precautions ]
2) See if there are Electrolytic Capacitors on the motherboard.
Bad capacitors for the motherboard voltage regulator circuit, will cause rebooting.
How to identify bad capacitors,
The motherboard Voltage Regulator Circuit,
(Starts at 0:04)
3) Power Supply
Weak Voltage power rail. Caused by failing Electrolytic Capacitors.
(Radial Aluminum Electrolytic Capacitors)
Sep 04, 2010 | MSI Computers & Internet
Games lock up on strange screen
hi there,
well if you' ve seen frequent flickering in your screen this is the sign of there's problem on your video card and sometimes at the middle of game or doing work at computer you will be hang,try to clean your video card it could be keep your screen smooth and recover the quality of graphics,how to clean your video card, unplug power supply unit, open your pc cover,disconnect vga cable from video card,pull out your video card,scrub the multi slotted terminal by eraser head of pencil both side,then put it back video card and vga connection,if the screen has good quality after cleaning and persist again the symton of flickering,replace your video card.have a nice day,rate my fix,thank a lot.
May 14, 2009 | Computers & Internet
Blue screen
Simply change your Ram with new one.
Apr 08, 2009 | Computers & Internet
My hp dv 2000 notebook is not get any dispaly on screen
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp)
has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out for parts, repair service and DIY info.
Mar 30, 2009 | HP Computers & Internet
Dell Inspiron E1405 reboots suddenly several times each day
i had the same issue on another pc, run the check disk if you can, you may have a boot.ini issue or another vital windows file corrupted.
Feb 23, 2009 | Dell Inspiron 6000 Notebook
Flickering then off
Problem is with Invertor Board maybe defective 2SC5707 transistors.
Jul 28, 2008 | BenQ FP71E 17" LCD Monitor
Sony VAIO PCV-W20 PC Desktop Logo
46 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
