Question about Nikon COOLPIX L18 Digital Camera
I keep getting lens error on the screen. The lens
I keep getting lens error on the screen. The lens appears frozen. Any ideas?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Jul 26, 2012
Nikon l20 the screen froze
Take the batteries out of it let it sit for about 5 minutes and then put them back in
Oct 25, 2017 | Nikon COOLPIX L20 Digital Camera
I have a Kodak Easy Share 140 camera and it stopped working. On the screen is says Lens Error 111. Any ideas?
There are some methods to fix these lens error
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra power to help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one). Some people also have actually used a "Shop Vac" with this fix to help extend a retracted lens.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some obvious potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #6a: This is a variation of Fix #6, and should be tried if the lens barrels appears straight (not crooked). In other words, try this if there's no obvious mechanical damage to the lens barrels that's causing the problem. With the lens pointed down, try "gently" tapping around the lens barrels with a small item such as a pencil or a teaspoon. The idea is to try to dislodge any sand particles that may be jamming the lens barrel stuck. Simultaneously try turning the camera on and off as you're doing this.
Fix #7: The most extreme of the fixes. You especially might consider this if the lens barrel appears obviously damaged, bent, or crooked such as from a fall. Try forcing the lens. More people have reported success with this method than with any of the other methods (see the polls in the right column). HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error.
Sep 16, 2010 | Kodak EasyShare One Digital Camera
Lens error - could be sand in lens
Maybe you got sand or salt water (a killer in any electronic device)? Best contact the experts; you may need parts replaced.
Jun 29, 2010 | Cameras
CAMERA FROZEN..nOTHING WORKS. sAYS "LENS ERROR. rESTART CAMERA"
try to remove the ring over the lens- this is just alluminium ring. I had same problem when my camera felt on floor... i thought its wrecked ... but it was 4 months ago and since that i made thousands of photos and its working fine. Remove the ring, i did it by forcing it, twisting and when removed - lens error was not appearing. I fixed that ring and placed back with a little super glue. Everything is ok.
May 21, 2010 | Canon PowerShot SX20 IS Digital Camera
Wont load
Disc read errors are mainly due to worn out lens or dirty PS2 lens.Clean your PS2 lens to get rid of this problem if your lens is dirty.Watch this video it will help you to know how to clean your PS2 lens.Watch it carefully.
Remember to keep your PS2 in Dust free environment if you don't want your PS2 lens to get dirty.
If your PS2 can not play certain games like Rock band try this tip:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:
  3. Press the ps_b_triangle.gif (triangle) Button to enter Version Information Menu that looks like
  4. Highlight the Play Station Driver as above and again press ps_b_triangle.gif (triangle).
  5. New screen will appear like
  6. Highlight the Disc Speed as above and press ps_b_x.gif button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
And after that wait till your game is loaded.
Click here to view full tip.
Nov 16, 2009 | Sony PlayStation 2 (PS2) Console
When I turn on my PowerShot A70, it comes on and immediately shuts itself off and the Error E18 appears on the screen.
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
http://www.e18error.com/repair.html
Hope this helps, let me know if you have a proble.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 04, 2009 | Canon PowerShot A70 Digital Camera
Lens error
i had this problem i turn my camera on the lens came out i turned them then my camera stop sayind lens error but now my pic is not clear
Jan 06, 2008 | Nikon COOLPIX L4 Digital Camera
Lens error
Lens mechanism has failed and a repair/replacement is the only solution-
Sep 01, 2007 | Canon PowerShot SD600 Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
71 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
