Question about Eureka Boss Superbroom Bagless VacuumStick Vacuum
How do you disassemble when it's filled up so it can be emptied
  • 171 Answers
  • There is a container that fills with dirt and it should should be easy to find on the body of the unit.It will probably have a little button that releases it so it can pull out and then you can dump it out. I think you will find the container and the button on the front of the machine that would be the side the t faces forward while you are using it and to access the container you must get in front of it to see the button.
  • Thank you and I hope this will help you . Olease try to remember to click on the yes button on your way out if this helped you. Thanks for using Fixya!
Posted on Oct 12, 2010
Sharp vacuum stopped because overfilled. I emptied, but it will not start. Is that the end of the machine? No reset???
The thermal trip on the motor is unfortunately not s resettable unit, it requires disassembly and replacement to fix. Usually this means the unit is due for replacement
Jun 17, 2016 | Sharp Vacuums
I have a scunci ss 1000 hand held steamer cleaner. Its been used and given to me from a friend. The steam comes out the trouble is the steam is not hot, just luke warm. how can I fix it myself.
Try descaling it with CLR. Add CLR and water, turn it on but not fully to produce steam, just get it hot. Leave it for an hour. Empty that out and out some more in. Get this up to steam for 10 minutes, switch off, leave it for an hour and empty it. Fill and rinse out twice. Fill with water and see if it is fixed.
Nov 09, 2015 | Scunci SS1000 Handheld Steam Cleaner
Why won't my bissell steampower spray water anymore?
Steam Irons and carpet machines should be filled only with distilled water. Repeated use of tap water can lead to mineral build up, clogging the tubes and vents. Using white vinegar instead of water can dissolve the minerals over time (fill and let sit) the best method is to disassemble the unit and clean the heating elements and all water baring parts.
Jun 25, 2014 | Bissell Vacuums
Featherlite model 3M-852H
see this instructions:God bless you
Ensure the Dirt Devil is connected to a working power supply if it does not turn on or operate. Check the fuse or breaker and replace or reset as necessary.
  • 2 Empty the dirty water tank if there is little or no suction. Turn off the Dirt Devil and grab the top of the dirty water tank. Push on the latch to release the tank and pull the tank off the base. Remove the lid and empty the dirty water into a sink. Replace the cap and hook the front of the tank onto the machine base. Hook the nozzle on the base so that the nozzle is level with the cleaner base. Push the back of the dirty water tank down and into position.
  • 3 Check the dirty water tank and empty as necessary if there is water leaking from the cleaner. Open the latch on the top of the solution reservoir and pull the reservoir forward. Fill with Dirt Devil brand cleaner to the fill mark. Fill the rest of the reservoir with hot water and close the cap. Replace on the base unit.
  • 4 Make sure the solution reservoir is seated firmly in the base unit if there is no cleaning solution dispensing from the unit. Fill the solution tank with cleaner and water if the level is low.
  • 5 Examine the hose and nozzles for possible obstructions if the carpet cleaner does not seem to be operating correctly. Remove any blockages.
  • Jul 19, 2012 | Vacuums
    I have a Bissell ProHeat Turbo 2x, it isn't mixing the water & cleaning solution and isn't spraying. What do I do?
    Isn't Spraying:
    Possible Problems->Solutions
    -Water Tank may be empty-> Fill Heavy duty bladder with hot tap water.
    -Formula Tank might be empty-> Fill with Bissell fiber cleansing formula for cleaning.
    -Tanks may not be seated completely-> Turn power off and reset the tanks.
    -Pump may have lost prime-> Turn power off, then on again, wait one minute then depress the trigger
    You can also contact Bissell at: 1-800-237-7691 begin_of_the_skype_highlighting 1-800-237-7691 end_of_the_skype_highlightingto help you out on why the cleaning solution and water aren't mixing, but first try fixing the first problem, you never know, it might cure the first one. :)
    Hope this helps!
    Remember to give me 4 Thumbs Up
    for all the hard work to the Community! :D
    ~~Dayminner
    Jun 04, 2011 | Bissell Vacuums
    How do i fill the water
    There is a tank within a tank design on these deep cleaners. Use warm tap water and fill the inner bladder.
    The Tank-in-Tank system is designed with a bladder inside for
    clean water. As you clean, the bladder will empty. Dirty water
    collects in the tank outside the bladder.
    Apr 20, 2011 | Bissell 8910 ProHeat Clear View Upright...
    Keurig model B40 How do I empty the resevoir , I can empty the cold watet tank. We are moving so need to completely empty all water.
    The water reservoir lifts out. There are two tabs on the side which lock it in place. You may have to pres on them to remove it. If you are wanting to completely empty the entire machine, I have found an instruction manual and have instructions for purging: Fill reservoir with clean water and replace on machine with lid on it. Raise and lower handle without K cup inserted. Wait for the red light next to "heating goes off.
    The blue lights on the control center will begin flashing. Put a cup on the drip tray and press "Brew"
    When finished, repeat brew procedure 2 or 3 times and inner tank should be empty.
    Hope this helps, if it does, please place a vote for me.
    Good luck with your move,
    Handie Andie
    Mar 28, 2011 | Vacuums
    How do u open up the compartment to empty the trash
    I couldn't figure that out either...since I misplaced the owner's manual...Anyway, there is a little gray colored knob at the top of the "collection" canister...and simply press that button and it disassembles that canister from the rest of the upright and then you are able to empty that trash contained therein.
    Sep 29, 2010 | Euro-Pro NV22 Shark Navigator Bagless...
    I have a GE dehumidifier that i hooked a garden hose to for direct drain. it will work okay for awhile then will only drain into the drain bucket. is there something i can do to ensure that it will drain...
    This seems to be a fairly frequent complaint on these GE dehumidifiers, and none of the solutions I've read here or anywhere else have fixed mine. My hose is clear, straight downhill, tight to the nipple with a good gasket, no plugs visible in the nipple, but has always filled the bucket rather than drained through the hose (and it's always bone dry). After two years of this and emptying the bucket, I'm about ready to disassemble it to see if I can fix it but with all of the other unresolved complaints I've seen GE should step up to the plate and post a solution.
    Aug 19, 2010 | Vacuums
    Bissell Pro heat 2x the shampoo tank empties out
    the o-ring is likely dislodged on the screw on cap
    personally I would recommend just filling the soap container with water and a little bit of white vinegar instead of the detergent. You won't leave soap residue in your carpet that way.
    Dec 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
    Eureka Boss Superbroom Bagless VacuumStick Vacuum Logo
    85 people viewed this question
    Top Eureka Vacuums Experts
    Jim Parker
    Jim Parker
    charlesjo336
    Level 1 Expert
    Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
