Question about Maytag Legacy Series Top Load Washer
Water pump is makeing a squeeling noise, I want to dissassemble it to see if something is inside the pump
    Brigadier General:
  • 3,513 Answers
The noise was indeed coming from the water pump. To clean the pump on this top-loader you have to unplug it, pop the top open, and remove the front face of the cabinet to expose the motor and pump. Slip off the two metal clips hugging the pump to the motor. Place a towel under the motor before detaching the hoses - there's a plastic drip pan between the pump and motor to guide the water away from the motor. Unclamp the two hoses from the pump by squeezing their spring-clamps with pliers and sliding them further down the hose. Pull the hoses off by lifting the pump off its axle and pulling it out while wiggling the hoses loose. I found a small sock jammed in the pump - it must have fallen to the outside of the basket but inside the drum during the last spin cycle, and went down the drain hose. Check the pump for damage and replace if necessary.Always remember that a clogged pump causes squealing, diminished spin speed, and slow drainage.
However Open the washer lid to gain access to the agitator. Depending on your model, lift the fabric softener dispenser off the top of the agitator. Some models only have a cap that lifts off the top.
Remove the barrier cap and the o-ring by pulling them out with your hands. Inspect the o-ring for damage and wear. Replace it if necessary when reinstalling the agitator.
Remove the bolt that attaches the agitator to the clutch in the middle using a socket wrench. Lift the agitator out of the washer. Some models, like Maytag, have a flex vane agitator which requires it to be lifted off bell housing. This is accomplished by inserting two screwdrivers opposite each other between the tub and the agitator. Lift up to remove from the bell housing.
Turn the agitator over to reveal the cogs that are in place. Remove the cogs from the agitator by snapping them out.
Thanks for contacting Fixya.com
Posted on Sep 29, 2009
How can you tell a bad water pump
sometimes a bad water pump will make a squeeling noise ..sounds kinda like a fan belt.
Nov 06, 2013 | 2006 Pontiac Grand Prix
When water pump goes bad does it make squeeling noise?
Like a pig running from the big bad wolf,that's the bearing making a noise.One little piggy ain't going to make it to the market.It will damage your engine and you will need a new pair of nike's.
Feb 18, 2013 | 1997 Nissan Sentra
I have a Maytag washer that the agitator is not working , I makes a squealing noise, How do I repair this? Thanks
Your problem may be a seized water pump with the motor turning the drive belt on a water pump pulley that is not turning (belt squealing). Or the noise could be originating from a water pump that has a noisy/bad bearing. If the pump pulley is turning and making the noise, you may be able to lubricate the pump shaft with some quality shaft lubicant (no guarantee that the noise will cease)! If other problem, contact an appliance service company.
Feb 20, 2010 | Maytag Washing Machines
Can a water pump be weak/bad in a 1996 chevy cavalier, all indications point toward this but its not leaking or making noise
yes sometimes the tell tail is there causes antifreeze leakage,car overheating, loss of heat in car sometimes makes squeeling sound the bearings in it...
Jan 28, 2010 | 1996 Chevrolet Cavalier
It makes a highpitched noise when turned on like something is caught in the motor
might have some thing in pump like glass /bone/ toothvpick/ plasitc / ect remove bottom cover and ck , if nothing is found replace the water pump seal . they can squeel .. mm
Dec 07, 2009 | Maytag 24 in. MDB5600A Jetclean II...
My 2006 jeep wrangler was making a noise like a belt squeeling drove about 5 miles noise stopped engine light appeared and oil pressure went to 0 (Jeep only has 38,000 miles)I imediatly turned engine off i...
have truck scanned for code can be anything oil pump timing chain etc also check warranty before doing any work most drive trains 5yrs- 100,000 miles
Oct 07, 2009 | 2006 Jeep Wrangler
Squeeling Noise (from the pully pump I think) Maytag MAV8600AWW
you need to replace the pump the pump bearings are starting to wear out eventually the washer will not drain
Dec 20, 2008 | Maytag MAV8600 Top Load Washer
Washing Machines Logo
152 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
