Question about SanDisk Sansa e250 MP3 Player
Power problem? my sansa e250 player just went off after I inserted its USB cord into my computer. A tab appeared saying the computer cannot recognize the device, then my player just went off and I can't turn it back on again, even if I use my own recharger. the player turns on by itself when you insert istd USB into the computer. in my case it opened by itself as usual. then all of a sudden, its power just died, and I cannot turn it back on again.. please help me..
  • Anonymous Dec 19, 2007
    the sansa was in a fire but when i turned it on it didnt come on tell i plugged it into the computer then a blue light came on and it shut off what is my problum?
Power on and off problem
Posted on Dec 19, 2007
How do i download music? i'm not reconized by computer . sansa e250
To have your system recognize your Sansa as a disk drive do the following:
1. Turn off the player.
2. Connect the usb cable to the computer. Do not connect it to the player.
3. Slide the lock switch to the right. You will see an orange strip.
4. Connect the usb cable to the player.
5. The player should appear in your computer as an external disk. Copy your music from the player to your computer, or viceversa.
Dec 09, 2009 | SanDisk Sansa e250 MP3 Player
Computer wont recognize Sansa Mp3
There are two connection settings in USB: MTP and MSC. For some reason MTP is the default, but it doesn't connect properly on all computers. Select MSC and plug the player in again, the computer will recognize sansa e250 but not show the driver just yet. It is installing recognition software (just basic drivers - nothing heavy) and it doesnt tell you what its doing until its complete. WAIT FOR IT. Once it is complete you will see both the sansa e250 and the removable memory slot in your "my computer" now you're good to go.
Jul 19, 2009 | SanDisk Sansa e250 MP3 Player
Sansa icon will not appear in source window
Jun 22, 2009 | SanDisk Sansa e250 MP3 Player
I turn on my sansa e250 it goes to refresh database, then blanks
Mar 30, 2009 | SanDisk Sansa e250 MP3 Player
Freezes on SanDisk Sansa screen
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Feb 03, 2009 | SanDisk Sansa e250 MP3 Player
My PC doesn't recognize MP3 player "sansa e250"
In this case wat u can do is on the Mp3 player itself u will see a slide switch which will say Hold/Unhold or Lock/Unlock............
Just make sure it is not Locked or On Hold and then try to turn it on.........
Good Luck.......
Take Care
And now it should recognise it
Jan 22, 2009 | SanDisk Sansa e250 MP3 Player
Usb connection
-Tha Mp3 Doctor
Nov 02, 2007 | SanDisk Sansa e250 MP3 Player
Malfunctioning sansa e250
In case anyone else has this problem, I fixed it. I unscrewed the back and removed the battery, then I put the battery back in, and the sansa performed fine, except that I have to put the songs back on that I was trying to put on the device before.
OR
-Tha Mp3 Doctor
Aug 20, 2007 | SanDisk Sansa e250 MP3 Player
High speed usb v. non-high speed
Sir you must use the right USB cord for your Sansa!
Apr 04, 2007 | SanDisk Sansa e250 MP3 Player
Can't connect!
Has to be Windows XP for either USB Mode but im not sure whether u can connect it to other computers under different versions of Windows or not and I know Apple computers dont work at all with the Sansa E200 series. Also connect ur Sansa to the rear USB inputs instead of the front inputs. Something that has to do with power distribution if none of these call their tech support they were very helpful with my issue.
Dec 25, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
41 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
