Question about HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
ON POWER ON,3 BLEEPS,NO BOOT UP - HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
    Problem Solver:
  • 20 Answers
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. ASUS Motherboard
  7. IBM
  8. Packard Bell
  9. via
aaa19
Posted on Oct 10, 2009
  • 68 Answers
3 beeps mean that computer ram has failed
replace your ram and then start your computer
if you have more than 1 ram stick try removing one and then start your computer, if it still doesnt try removing the other one and place back the first one
Posted on Sep 29, 2009
E4212 Bleeps
RAM might be bad. Try taking a stick out and or replacing them outright.
Feb 19, 2014 | E-Machines (T2824) PC Desktop
Have a pro rider freedom sometimes it will switch on and drive other times it turns on an bleeps and wont move
hi,okay the bleeps , bleeps and pause or continuous bleeps ?
Has the scooter been serviced recentrly ?
Regards
Rob
www.gewizrepairs.co.uk
Jan 10, 2014 | Electric Mobility Power Electric Scooter...
3 beeps no boot
3 bleeps usually relating to memory... try removing and re-inserting RAM and video cards... or try them elsewhere in another machine. It may be wise to remove all the RAMs and add one at a time while trying to reboot.
NOTE: Remove the power wait a few moments before handling each RAM.
Another cause since it's been 'sitting' a while could well be the power supply due to failing capacitors, so trying another wouldn't be a bad idea.
Jul 03, 2012 | eMachines W3507 PC Desktop
4 bleeps and it won't boot
The AMI BIOS 4 beep error code usually means an issue with memory. If you are not getting any video, then the problem is probably in the first bank of memory. If you have 2 memory sticks installed, try swapping them. If not, try re-seating the memory stick. A single stick should be placed in the "A" channel slot, the one closest to the CPU. You aren't saying if this is a new build. If so, are you certain that you have the correct type and speed memory? The manual, pages 1-3 thru 1-5 lists the "approved" type/size/vendors for memory. Vendor isn't always important, but if type and size are correct, and the vendor is not on the tested list, there may be compatibility issues. Some memory requires different voltage settings than the MB defaults to. Check the memory vendor for details if necessary.
Dec 22, 2011 | ASUS M2N68AM Plus Motherboard
PS3 won't boot up. It starts but will not load menu from the hard drive.
try rebooting hold down power button until it bleep twice and should turn off hold it down again unit it bleeps 3 time then u have secret reboot menu 4 ps3
Feb 14, 2011 | Sony Playstation 3 (PS3) Console
I have a brand new SAM4S ER-180 cash register. If I plug in the power it immediately goes to error mode & beeps at me. The LED screen is reading E Lo0000 or E Lo0.00. I have tried everything & dont...
A beeb normally means defective (hardware failure) DOA. Go back to your store for a warranty replacement.
Does it start without the scanner?
http://tinyurl.com/69hd8kf
Does computer beep when you turn it on? Information on beep codes bleeps on booting, boot codes led flashing flashes 1 2 3 4 5 once twice three times on and off times on boot. power on self test fail, boot failure.
Quick help guides and LED flashing errors codes search for error codes using your
Service manual.
Maybe more info here
http://www.goodson.com.au/service/FrmService.htm
Feb 13, 2011 | Computers & Internet
My ps3 will not turn on... when I start up by pushing the power button I can hear the fan turning on, it boots on, and then turns off a few seconds later. any advise would be greatly appreciated.
hello, try resetting it, turn on the ps2 press and hold the standby on the front of the ps3 you will hear 1 bleep then 2 short bleeps after the short bleeps release the button it should reset
regards
shaun
Nov 21, 2010 | Sony Playstation 3 (PS3) Console
3 or 4 mins into any game it bleeps twice and
needs a new power supply open it up take it out and look at the bottom for the product codes go online and buy a new one. ( i have the 1stgen and it cost me 51 dollors with shipping
Jan 03, 2010 | Sony Playstation 3 (PS3) Console
Comp won't boot after installing new ram. possible motherboard problem?
try emoveing both sticks and blowing into the ram slots then replace 1 stick at a time. if this dose not work try checking all the cables to make sure nothing got knocked out of place when you installed the memory in the first place. (bleeping sounds can mean a lot of diffrent things if the problem carrys on count the bleeps and look on google to see what that number of bleeps means for your motherboard) hope this helps
Sep 12, 2008 | AOpen XC Cube EX661L (95EZ619321) Barebone
HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
181 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
