Question about Samsung Washing Machines
I put some washing in my samsung J845 front loader the door will not lock before the washing can be done. my husband brought a new door latch due to the other one been burnt out and he put it back on the macine. Same problem still wont lock and no red lock light coming on you can oull the door open when you go to push start Also it keeps flashing the coad dem door is open but cant close it. please help me, i cant keep spending $100+ at laundrymat every week.
Just bang the door again until the error goes away. The door is not lined up and won't latch properly. At least that is what ours does. I usually slam the door on my machine.
Posted on Sep 25, 2010
We have a Samsung J845 Front Loader. The door lock shorted out so we replaced it with a new one but now are just getting a DE error.
DE is door lock error possible main pba or wire harness check connections on new switch first .ohm wire harness If you can to check for break in wire
Mar 12, 2016 | Samsung Washing Machines
I have tried everything, but my front loader (Samsung J845) door won't open. I can't get a repair person until Monday and the clothes trapped in there are rotting. Have only had machine for two years and...
Remove the plug and see if the program can be activated. If not try to reset the program, if there is a failure to shut off the door lock it is possible that the program controller has failed.
If so you will need to first of all drain off the water in the tub by removing the drain hose. Please make sure that the washer is kept out to drain or there could be flooding inyour room. Once the water has drained use a long head screw driver to manually release the lock of the door.
You might have to use agood light to see the latch to release the lock.
Nov 03, 2010 | Samsung WF206ANS Front Load Washer
We have a samsung j845 top loader and a de error came up while it was washing and i cant even drain the clothes
DE indicates a door lock error.
Either the door lock, wiring or main control board can cause this fault.
The door lock is relatively inexpensive so it would be worth trying a new door lock first.
Check the wiring between the door lock and the control board.
If a new door lock doesn't fix it and the wiring is ok you are only left with the control board.
Aug 30, 2010 | Samsung WF337AA Front Load Washer
Door jammed shut
normaly this is due to water still in the drum
Sep 20, 2009 | Washing Machines
Help remove and replace the diaphragm on my samsung J845
The front loader machine should be done by a appliance dealer because this is a diffuclt job and need a lot of patience if you do it. Hope this might help.
Jun 02, 2009 | Samsung WF337AA Front Load Washer
Error code de on samsung front loader J845
The door lock is the problem... try to push the door harder... or change the door lock! It is usually done in 5 minutes.. .... if it is only 5 months... you have a warrenty!
Jan 26, 2009 | Samsung WF337AA Front Load Washer
How to replace the belt on a Samsung J845 front loader washing machine
Its on the back of machine and after you remove the back cover plate youll see that its very easy to install the new one.You shouldnt have to use any tools to put on the new belt.Just loop it around the motor pulley and around the large tub pulley that you see right in front of you.It may even appear to be too tight while your winding it on the pulleys but its not .
May 20, 2008 | Washing Machines
Intermittent problem with door not latching correctly
Hi Your husband can replace the Door Lock Hoop Assembly Part Number #22003269 also have him make sure the door hinges are in good working order and aligned correctly. this should make you happpy and save a lot for beer... Let me know if this helps?
Aug 18, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
522 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
