Question about Lexmark Wheelwriter 3 Typewriter
My ribbon broke, I don' t know how to fix it.
I just pulled my trusty IBM Wheelwriter 3 and typed a few solid lines of a poem. Then, out of nowhere, the ink strip breaks! I pulled out the IBM "Easystrike" High Yield Correctable Ribbon Cassette (1 299 845) and tried to fix things but am having trouble reloading the ribbon. Any suggestions?
  • Lexmark Master
  • 3,594 Answers
The ribbon has 2 little (feet) on the rear of the cartridge they hook into the ribbon deck and it just rocks into place. You can get a picture and instructions @ lexmark .com klick your way to publications. Be sure to advance the ribbon by hand a foot or so to be sure it isn't sticking to itself.
DickyO
Posted on Sep 30, 2009
IBM Wheelwriter 3 won't type
Print hammer selenoid cap is broken, or print hammer selenoid is gummed up.
Jan 03, 2014 | Lexmark Wheelwriter 3 Typewriter
IBM Wheelwriter 3 - Cannot get the complete word - Middle part of word is white
Type on a two part form if the carbons are goog then you have a ribbon problem. Look at the ribbon. Do the letters overlap (ribbon feed) If they don't fall in a line near the center of the ribbon (ribbon lift) Check for folds in the ribbon.
DickyO
Oct 04, 2012 | IBM Wheelwriter 30 Typewriter
Hi, I have an IBM Wheelwriter 30 Series II. When I type text it does not type the bottom 20 % of letters. I changed the ribbon and made sure that the roller was securely locked down. Any suggestions? ...
yes in the carrier ribbon there is a adjustment of ribbon to fix it up and down.
take out the ribbon.
see the cam from where the ribbon carrige lift up.
in side that cam a adjustable screw from that screw you can adjust the ribbon hight.
Nov 25, 2010 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 3 will not type
Probably the plastic cap on the print soleniod is broken. They are available from us for 15.00 but a little tricky to install.
DickyO
Jun 20, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter III
gotta clean the wheel off with old ink sometimes this can be a problem but the ribbon might not be seated properly
May 07, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 6 ribbon not advancing
Befor you put a nrw motor in try a few drops of light oil on the m
motor bearings (WD40 works well).
DickyO
Mar 24, 2008 | IBM Wheelwriter 30 Typewriter
Wheelwriter 3 printwheel
If you know where the print solenoid is try a few drops of oil on the front and rear of the plunger. If the pad needs replaced it can be done without removing the printer from the machine but it is tough. If you know how to remove the printer take it out, remove the printwheel, there are two screws that hold the solenoid once the dolenoid is out the installation is simple.
DickyO
Mar 23, 2008 | IBM Wheelwriter 30 Typewriter
Ibm wheelwriter 6
1press and hold the code key and type the # 1 thru 99 wher you want to store the job(chose any one number)
2 the store light should blink
3 the ARtn light comes on
4 the carrier returnes to the left margin
4 the printwheel spins
5you may begin typing when the store light is on solid
6 let the carrier return automatically at the end of each line of type
7close the store when finished by pressing and releasing the store key
Mar 08, 2008 | IBM Wheelwriter 30 Typewriter
IBM Easystrike Cartridges
The ribbon cartridges can be pried apart they are pressed together, getting it apart is easier than putting back together.
Next time you have to install a ribbon advance it by hand for a foot or so as old ribbons tend to stick to themselves.
Hope this helps
DickyO
Feb 08, 2008 | Lexmark Wheelwriter 3 Typewriter
Lexmark Wheelwriter 3 Typewriter Logo
108 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
