Question about Fuji FinePix S7000 Digital Camera
Flash unlocks but does not pop up . works fine if you hold it up with your finger. how / what do i take off / apart to fix it / Thanks !
4 Suggested Answers
  • 11967 Answers
SOURCE: Fujifilm Finepix S700 Digital Flash Doest Pop-Up.
Two weeks old?...return it.
Posted on Aug 18, 2009
SOURCE: The flash unit on my Fuji Fine PixS5770 no longer works properly.
Did you fix it ? I have the same problem now
Posted on Jul 13, 2010
  • 4 Answers
SOURCE: my fujifilm s5700 has a
The Flash Spring mounting breaks
Anyway if you are brave and handy you CAN fix this.
First remove the back of the camera - 3 screws in battery bay, 1 in the side above the memory card door, The two rear most on the bottom, two in the USB/video door, and the rear most on the left hand carry strap bracket.
Carefully prise the back rearward about 5 to 8 mm.
Now take a look at the two screw holes under the flash (when popped - or flopped out now that is broken) now go and bend a screwdriver of the type you used for the previous screws - you will need a 90 degree bend very close to the tip to fit in this gap and be able to turn the screws a few degrees at at time.
A little at a time lock the screwdriver into the screws and undo until the flash cover comes off.
You can then slide the shaft out of the flash to release the spring which will have the end that should fit into the broken bracket now sitting proud..
Make a suitable U shaped bracket that will slide over the broken plastic bracket and drill a tiny hole in the side where the spring will clip in.
make sure it fits really well and then epoxy into position.
Getting the spring back in is a fiddly job - I found the best way was to fit the end of the spring into the new bracket, slide the shaft just into the spring - the lever the other end of the spring down into the back of the flash body and then slide the shaft all the way into place.
I did have to file down the little plastic "blade" inside the lid which presumably is designed to assist the the (now broken) bracket from breaking....
reverse the dis-assembly and now you should have a working flash
Posted on Dec 08, 2010
Ny headlights dont work have to hold lever for high beams lights to work,dont know where the headlight relay is on car.
If low beams are working then the relay is fine. Sounds like the dimmer switch is bad.
Oct 14, 2012 | 2004 Chrysler Sebring
DSC H-5 the flash pops up but does not flash, camera is set to automatic mode and flash is turned on.
Flash pops up shows that flash release mechanism is working as camera wants to flash.
There are 3 thick wires connecting between flash bulb and flash charging circuit in camera, one of thick wire seems internally broken and causing problem.
Camera will be apart to check wires.
Let me know, if you are willing to apart camera, for further help.
Thanks.
Dec 31, 2009 | Sony Cyber-shot DSC-H5 Digital Camera
Our flash clicks open but won't pop up
I am not a camera repair guy, but it sounds like the small spring that lifts it and keeps it up, is broken.
How to fix?
1. Buy a similar camera on Ebay for parts. Remove the top. Unsolder the wires to the flash and remove it from the parts camera. Set it aside.
Take your camera apart the same way. Swap parts, and reassemble. Be careful no to pinch any wires or you will have to do this all over again. Oh yes, DO NOT touch the flash capacitor in either camera or you could get a nasty shock that requires medical attention.
2. Pay a repair guy to repair it for you.
3. Buy another camera with a working flash.
4. Buy an add-on flash for the camera.
Aug 22, 2009 | Cameras
Sounds like loose part in Canon 350D / Rebel XT
This is nothing to worry about. The sound is made by the metal linkage inside the flash housing. Pop up the flash and touch the linkage with your fingers. You will see there is a little movement. This movement is enough to make the sound you hear.
Jun 08, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Sd card won't click into place on my Nikon d60
Check your SD card, there may be a piece of it missing. Did the same to my camera and looking into the card holder, there was a piece of SD card lying at th bottom! (I used a needle to dislodge it!)
Mar 11, 2009 | Nikon D60 Digital Camera
T180 won't shut down.
Hi Fix Ya team.   Thanks for your email.Fortunately an update from microsoft seems to have fixed the problem,but I still have my fingers crossed.Thanks again.Regards to you all Tim.
Sep 19, 2008 | Acer Aspireā„¢ T180 PC Desktop
How do i take it apart.
using your fingernail, there are multiple plastic clips that should pop off as you run your finger around the edge, let me know if you still can't get it, you may also try a small flat headed screwdriver to pry it apart.
May 12, 2008 | Samsung SCH-u340 Cellular Phone
Flash don't work
Check out the Technical Support team at Sony. When you press the button to release the flash- holding the button in depress the flash a little with a finger.
Jun 15, 2007 | Sony Cyber-Shot DSC-V1 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
