Question about Beam Industries 750 Classic Bagless Central System Cyclonic Vacuum
I have a Beam Rugmaster Plus power head Model BM1 393 Type AB and the connection were the metal pipe meets the plastic swivel broke close to the unit. It appears like a manufacture defect in that is broke in two small places and not the entire unit. Can this piece be replaced or glued??
    Scholar:
  • 95 Answers
This is most likely repairable. Lots of the Beam parts are available. I would recommend checking out any local vacuum shop or searching online for a central vacuum store that sells beam products.
Posted on Oct 02, 2009
Testimonial: "I AM THINKING ABOUT SUPPER GLUING THE PART BUT IF THAT DOES NOT WORK I SHALL LOOK FOR A REPLACEMENT PART. THANK YOU"
    Problem Solver:
  • 18 Answers
Definitely all parts are available from the beam dealer
Posted on Nov 25, 2014
Beam BM1386 AB need to change belt but can't find manual
Not familiar with the beam model but they are all the same. Take off the shield that is covering the beater brush and you will see the groove and the diver motor where the belt was. Slide it on and put the cover back on and you are done.
Aug 04, 2014 | Beam Rugmaster BM1386AB Belt
Change belt
flip it upside down , undo 2 phillips screws, flip top up and off from the back, lift out roller , replace belt , stretch back in place , put top back on starting with front lip, then put in screws
Apr 25, 2013 | Beam Rugmaster Plus Belt
Glue kenmore vacuum plastic
The glue might not work because glue can melt and since it is close to your vacuum motor that creates heat causing it to melt so I personally would just go buy a new one they are like 20$ but if you want to keep on trying glue I think super glue would be your best gues
Apr 16, 2012 | Vacuums
We have had the power wires that run through the swivel elbow at the end of the main handle extensions and the power head break after being repaired two times. The new swivel elbow and wiring connection...
Have them replace at the Aerus Electrolux shop. Aerus uses a higher grade plastic (Lexan, read about it on the net) which should last the life of the the power nozzle and wands. The part and labor will have a 1 year warranty.
Nov 15, 2010 | Electrolux Epic 6500 Vacuum
Power nozzle shuts on and off
HI There, When a Kenmore power nozzle cuts on and off, this usually indicates that your electrical hose has gone bad and has a short circuit somewhere. You can try and troubleshoot the hose to find out where the short is by trying to determine what position the hose is in when it cuts on and off, and try to isolate the short circuit by spinning the hose on both the end that plugs into the canister, as well as the end that plugs into the wand. Sometimes the short is in the wands, or even the swivel neck assembly on the power nozzle where the wands connect. I would say 9 times out of 10 though on Kenmore canisters, the problem is in the hose. Kenmore is actually manufactured by Panasonic, and the two brands use a lot of the same identical parts, including the electrical hose (most cases). If your Kenmore has a two position switch, with a setting for floors and carpets, then here's a link to the corresponding Panasonic hose that you can buy. The Panasonic hoses are a little more expensive then Kenmore, but the huge benefit is that they come 100% completely assembled, where as the Kenmore hose has to be assembled (which is extremely difficult even for me to do). Panasonic 3 Wire Electrical Suction Hose To Fit Kenmore Canisters On just a handful of Kenmore models, an additional modification has to be done with the internal switch. Kenmore must have had the hose modified so you'd have to buy the genuine Kenmore part, but luckily simply switching two wires on the switch will allow the Panasonic hose to work. Try just plugging in the hose into the vacuum first, and if it still doesn't work properly, then you can modify the switch. If you find that the short is in the wand or swivel neck, just use the comment field on this repair page and let me know, I'll be happy to follow up and walk you through either of these repairs as well. If this was helpful to you, please be so kind and rate the repair, or leave some feedback for me. This is greatly appreciated. Chris Jones GoVacuum.com
Jun 15, 2010 | Kenmore 22612 Bagged Canister Vacuum
The beater of my kenmore vacuum won't turn on - the primary light goes on but none of the sensor lights go on.
Kenmore vacs generally have three male contacts at the machine end.Internally when the hoses swivels these contacts run on three brass rings which can also get dirty due to proximity to dirt. They can get dirty or dirt can fall into the corresponding female socket where the hose meets the vac. If you have just changed the bag inspect these connections near the intake port on the vac.
The working LED means you have a partial connection. Also try wiggling and twisting gently at the handle of the hose and where the wand connects to the hose and the power head elbow... you have 4 connections between vac and head
Sep 06, 2009 | Kenmore 22812 Bagged Canister Vacuum
Beam Serenity Plus doesn't ****
there is definately a clog somewhere
run a snake thru your pipes and dont for get the exhaust
Aug 28, 2008 | Beam Industries 2775 Serenity Plus Central...
Miele Vacuum cannister
Most times you have to replace the neck on the powerhead. Sometimes the switch in the handle of the hose will have a bad solder connection. But S300 is not a good model number, also the powerhead has its own number on the bottom, so couldn't look up parts for you.
Feb 21, 2008 | Miele S300 Bagged Canister Vacuum
Kirby Belt Lifter Assembly
I have tried to get a parts breakdown for your vacuum cleaner with no success. The way that then washers should go is the flat smotth metal washer on the inside followed by the fibre washer and the wavy washer on the outside. The waves are used to bite into the plastic so it cannot work loose.
Oct 28, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
888 people viewed this question
Top Beam Industries Vacuums Experts
Thatvacguy.com
Jerry Kramer
Jerry Kramer
Are you a Beam Industries Vacuum Expert? Answer questions, earn points and help others
