Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
Hello i keep faxing and it says gthat it is not
Hello i keep faxing and it says that it is not going through with error but then it does? print out says it did not go through? error 405 and other errors....
    President:
  • 1,187 Answers
Check the phone number of the fax maching you are trying to send to.
Call the fax number with your phone (not fax machine) and confirm that a fax tone sequence is trying to sync.... If you get a "Hello" .. then you have a wrong fax number...
Posted on Sep 29, 2009
How do you retreive faxes in the memory of a brother intell 2800
The intliFax 2800 has 2 types of memory.
If you have enabled the Fax Storage option (menu 2 5 2) then you can either turn this option off and you will be prompted to print or you can press Menu 2 5 4.
If there are faxes in the emergency memory, they should print once you clear the error message, if not, then press Menu 2 6 which will attempt to print out any jobs in memory as well.
Thanks,
Pat
Apr 08, 2010 | Brother IntelliFAX 2800 Laser Fax
Hello my fax machine keeps giving me error codes how do I fix this, I need my fax machine. thank you
Hit the setup button, select fax setup or setup fax, and make sure the option to "Junk" fax blocker is off. The default when you setup the machine itself is on yes. This helped me with my "error 410" message I received when printing fax log.
Mar 15, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Lexmark X160 doesnt Copy or print faxes
I have been getting a remote fax error often enough that's it's becoming a nuissance. Any suggestions on how to fix this problem?
Apr 07, 2009 | Lexmark X6170 All-In-One InkJet Printer
Copy report after sending fax
it will be under reports, you can set all faxes to do a report after a fax has been sent, ill keep the terminology easy as
Brother, canon, konica blah blah all uses different terminology for it, but there is a setting in reports for user that they can turn on, it like error reporting if a fax deosnt go it will print out a error report so same thing to do with copy report.
regards
Fax Tech
Apr 01, 2009 | Office Equipment & Supplies
Sharp Inkjet UX A 1000
I had the same problem and, like you, went to the internet to find a solution. One answer I found was to unplug the vax, wait one minute and then replug it. This didn't solve the problem for me. Out of desperation, I printed the fax "Help" pagea nd, lo and behold, after it printed my Sharp 510 Fax was back to normal.
Nov 04, 2008 | Sharp INKJET FAX UX-A1000
Fax not printing
may be you are having tonner empty error
press menu(*) #1934 menu(*) select new cartige then u will able to receive fax to print
jignesh
Aug 12, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Error 401 & 634
error 634 is an indication that the line was either busy, or there was no answer on the receiving end.
Jul 23, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
Fax in memory light stays on
I've had this 830 for about 5 months now and am very impressed with its speed, but the glitches, Holy Smoke.
The one you're describing is one I've had before. The only solution I've found is to unplug the machine, wait about one minute and plug it back in. All is then OK. The problem with that system is that if there are any more docs in memory, you've lost them.
I'm having a similar problem with receiving faxes. The first sheet prints, and then the display indicates that there is a 'fax output error check page size and press OK'. The memory light shows that there are more pages of the fax (I presume) that need to be printed, but they won't be because of this error. Of course one checks the size and presses OK but it simply prints out the same page followed by the same error message. This could go on for eons if one would allow it. I then have to unplug the printer, wait and plug it back in, and again all is well, but I've lost the documents in memory.
There are so many little quirks with this machine I am almost tempted to go back to my miserable HP, but I've chosen to keep working with the MP830 with the hopes that after years of learning its idiosyncracies, there will eventually be a class action suit against Canon which I will be part of, to cover the cost of psych services and physical therapy (bas shoulder from throwing the machine out the window.
Wes
Oct 13, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon laser class 2060p super g3 fax machine
The error keeps flashing and the machine will not work. The error reads, "check cover/cart". We put the cartridge in and out about 10 times and the same error message keeps flashing. the fax machine is still not working. Help!
Apr 24, 2007 | Canon LaserClass 2060P Plain Paper Fax
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
87 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
