Question about Hunter Fan Company 5/1/1 Programmable Thermostat
We just bought a house that the thermostat had been removed and the wires were just coming out of the wall not labeled. The furnace is a Tempstar gas model 9MPT125L20A serial # LO13778617.As far as we can tell the furnace was bought 6-8-02. We bought a Hunter a progammable thermostat,serial #712086, that looks exactly like the picture you have here. Not knowing the wiring we just matched the colored wires and kept the red jumper wire that goes from RC to RH as we have no air conditioning with this furnace.We finally turned it on to try it and the furnace worked but now it won't shut off unless you manually go down and shut the furnace off. did we wire it wrong? Oh course after we bought the house my husband lost his job and we are struggling to make our house payments let alone to be able to afford to have a furnace person come here. Please can you help?
  • 221 Answers
The Red and White wires coming from the furnace are the only ones that call for heat. the Green wire turns on the fan continuously, the yellow is for AC. If you have another wire color, it may be a Common wire and should not be used if your t-Stat has batteries. If no batteries, it goes to the C screw.
Posted on Dec 30, 2009
  • 70 Answers
It sounds like you have a short in the t-stat wire. pull a new 4 wire
Posted on Oct 04, 2009
My gas pack won't light
First, the thermostat white wire is the wire that initiates the furnace to start. When you select heat on your thermostat the tech should get a 24-28 volts between the white wire and common on the thermostat wire in the furnace. If you do not get the required voltage, there is a break in the wire from the furnace to the thermostat that needs to be tracked down and eliminated.
Feb 27, 2014 | Goodman Manufacturing Goodman...
Put a new honeywell thermostat on and heat won't come on
Take the thermostat off the wall & jumper Red wire to White wire. if your furnace kicks on, then either the thermostat is bad, or it is not connected to the correct terminals. BTW, I'm assuming this is a single stage gas furnace.
Nov 28, 2013 | Honeywell Heating & Cooling
I need to replace a gas furnace thermocouple on a Tempstar gas furnace. How do I do this? Part # SV9500M2682 on Tempstar model # NUG5100BHB2
HI follow the thermocouple lead back to the gas valve undo the silver nut foloow the lead back to the pilot and undone the nut on thermocouple or it may just pull out , or the burner might have to come out to replace it , if you arenot sure on this then a local gas fitter will do this .
Jan 26, 2010 | Heating & Cooling
Replaced mercury thermostat w/Honeywell CT87K - doesn't work!
You need a specific thermostat for a Wall Furnace it is a Millivolt Thermostat and not a 24v standard thermostat....usually it will work anyway however if the powerpile (generator produces millivolts from the pilot light) is weak it may not be producing enough...or the Pilot light may be dirty and lazy...won't produce enough millivolts ...or you can have bad or dirty contacts or connections....or a combination of any of the above.....a 24v Thermostat and particularly a non-mercury thermostat has too much resistance in it for a millivolt system....as your Wall Furnace (other than the fan) runs on less than 1 volt
Oct 31, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
I just bought a repo house and there is no identification on the wires coming out of the wall for the thermostat. I have a red, green, white, and blue wire coming out of the wall. I need to know where to...
The best way is to see where the wires are connected at the furnace and duplicate them at the thermostat but typically the connections are:
Red wire to "RC and RH"
White wire to "W" (for heating)
Blue wire to "Y" (if you have central air)
Green wire to "G" (this is for the furnace blower)
Aug 27, 2009 | Hunter Fan Company 5/1/1 Programmable...
RTH2520B Honeywell Programable Thermostat wires
Hi soozankrayg!
Your problem should be pretty simple. (assuming that it is a typical 24volt system) you should hook up the black wire to the "RH" terminal and the white wire on the "w" terminal. Make sure that you turn off the power to the furnace at the breaker or the furnace itself before attempting this. The reason for this is that you can cause a short and either break the fuse at the furnace or burn up the circuit board. This can happen very quickly and is very common when a thermostat is removed.
Jan 28, 2009 | Honeywell Programmable Thermostat Heater
Short cycling..continually..minimal heat
Is this furnace standing pilot or electronic? if standing pilot turn power off then take t-stat off wall and connect the wires labeled r and c together and see if that keeps furnace working. If electronic check flame sensor you can check flame sensor buy cleaning with steel wool. if that doesn't work then try t-sat.
Jan 21, 2009 | Coleman Propane Forced Air Heater...
Dellllllllllluxe programmable thermostat chronotherm plus iv
Does your thermostat have batteries. What is the brand of furnace and model # . Does the furnace have a pilot light or is it electronic ignition. if you need heat you can take thermostat of wall and take wires that are labeled r and w and wire nut them together to see if furnace comes on. Make sure you turn breaker off to furnace first before you take thermostat off the wall. If furnace comes on after you turn power back on after you connect those two wires together then you will probally need new thermostat. If not you have a problem with your furnace. If you have any questions after you try this feel free to ask any more questions.
Jan 16, 2009 | Honeywell Programmable Thermostat Heater
Williams wall non-elec gas heater. Black copper wire tagged thermostat?
First make sure this is a heater set up for a remote mounted thermostat. If so, the gas valve has 3 screws labeled TH (thermostat) and TP (thermopile) that's the flame sensor with 2 wires coming off it, I don't know where the goofy name comes from. there will be one screw that has both, usually the top one. Wire accordingly. The new valves have a solenoid on the bottom. this connects to the high temp. sensor up top. It has 2 wires on it, one connects to the thermostat wire, the other goes to the screw with TH and TP. Or you can skip it and connect the wire from the back of the valve to the Th and TP screw. Make sure the thermostat wires aren't pinched somewhere, thus eliminating the thermostats control.
Feb 23, 2008 | Heating & Cooling
Wall gas furnace
look inside the control panel of the heater. look for a 120 volt to 24 volt transformer.  There may be a fuse on the transformer secondary.  The thermostat switches a hot 24 volt wire so you won't find a common at the thermostat.
Nov 13, 2006 | Empire GWT-25 Wall Mounted Panel Heater
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
444 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
