Question about Dell 924 All-in-One InkJet Printer
On my toshiba vista my printer will only print the last page.
When i ask to print all (pages), only the last page gets printed. I have to select and print each page separately to print out whole documents. I'm printing from an Hp using windows Vista 6.0. This...
some printers collate pages, which means they print from the last page to the first page. so that when you pick up the pages from the finished printing tray they are in order.
if you say it stops after the first page, there are a few possible reasons for this.
either you closed the application you were printing from before you finished printing (which sometimes cancels the printing job)
or the computer decided it wanted to cancel the printing on its own, this can happen if the printer has sometimes an error, this error or cause could be a lag between the data transfer to the printer.
try printing without collating the pages, while keeping the application/document open.
and make sure you have the latest drivers.
May 09, 2011 | Lexmark X7350 All-In-One InkJet Printer
Single page printing
OK, well when printing from the internet it quite often only prints the screen you are on, I presume, because you likes what you read, you wish to print it, well as you are on Page 3 the end of the document, thats what get printed. You actually, need to go to the File Menu, select, Print, and actually select, the type of print, there are options, Print ALL, Print Page, Print Selection, you need to set that, it sometimes remembers a setting and perhaps 3 was the last setting.. In any event don't just "Hit Print" you have to do as related, I am not sure if you can set up special "Print Now" parameters, but I expect you can, choose a "Default" setting.
Mar 31, 2010 | Lexmark X5650 All-in-One InkJet Printer
THIS IS NOT AN ISSUE WITH MY MARGINS. I have Microsoft word 2007, an HP Officejet Pro 8500 Premier and windows vista. After some research I found a commonality with my problem and these three operating...
The problem may lie in the printers setting for the margins. Do you set the margins only in word 2007 or do you check the printers margins too?
Also the issue may lie with the printer having the incorrect paper size
Have a look in the printer properties (When you go to print, its beside the printer selected) and look through there and see if there are any issues.
Dec 02, 2009 | Toshiba Satellite P205D-S7454 Notebook
Problem with Toshiba e-studio 280- need vista 64 bit driver
You update your copier driver for 64 bit windows suppoted.www.toshiba studio 161.com
Mar 11, 2009 | Toshiba e-Studio 161 Copier Copier
Wireless Printing problems Vista to 10.3.9 Mac to Brother Printer
I have a wireless Mac ,version osX.4.11. I have a Colorsmart HP Priner 4100. I have created documents in IWorks Pages. I can not print directly. I have to save the doc as a PDF email, email to myself, go to Safari, then the printer will print. What am I doing wrong?????
Feb 26, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
HP 4550 will not print graphics
This printer will work with Vista. I use the driver that Vista provides with the standard HP internal network card and it works fine. Try putting your network card back in and undoing the USB adapter changes. Then just go in and add it back with the "Add Printer" wizard.
My compliments on the 4550, though. It's a great printer. A bit slow compared to what's out there new, but a workhorse that will last nearly forever.
Feb 12, 2009 | HP Color LaserJet 4550 Printer
Lexmark x3650 not printing after installation with my vista lapto
You can lastly try a hard reset of the printer but if that is to no avail the printer has an issue with it. See if you can get it to work with another computer for the heck of it just to make sure.
Aug 29, 2017 | Lexmark X3650 Printer
HP photosmart 7280 - when printing with Toshiba or HP notebooks (both Vista) a blank page is ejected between EACH printed page of a document. HP had no solution.
Assuming that you are connecting directly to the printer via USB, on the advanced tab under the printer properties, make sure the "Print Directly to the Printer" option is selected.
Aug 16, 2008 | Televison & Video
Only prints last page or least few pages of a ulti page document
if your taskbar displays printer icon on system tray double click on that & delete all privious prints.
select the text or area which you want to print. & give print command, & Click on print selection button & then Print.
Jan 17, 2008 | Lexmark X7170 All-In-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
27 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
