Question about HP LaserJet 4345mfp All-In-One Printer
Hp4345mfp seems to be working fine, accept 3 customers can't get through to our machine. Any ideas?
    Champion:
  • 224 Answers
It seems that there may be a problem at the customer side. if everything alse is fine the problem seems to be there
Posted on Mar 31, 2010
I receive a 150 error when trying to enter the right side stitches. I can only accept the default of +90. How do I fix it
sorry not idea as I see no make/model listed . try the manufacturer's website and customer support
Sep 29, 2015 | Sewing Machines
Tip
New detergent Sheets are NOT a good idea for front load washers
In the last week i have went to many customers home to remove detergent sheets from washing machine pumps on front load washers.
Purex® Complete 3-in-1™ Laundry Sheets are now on my "DONT USE THIS PRODUCT LIST." As an appliance repairman, i have made lots of money removing these sheets from the drain pumps on front load washing machines. I was at one of those jobs today and the customer watched me pull 14 of these sheets out of the pump and up into the hose that leads to the pump. I tested the machine and it then worked fine.
About 1 hour later, the customer called me and was furious because as she was doing a load a laundry and the water would no drain out again. I went right back to her home and once again i found more of those sheets inside her pump, 5 to be precise. About an hour later, i was done doing a complete clean out of her washer to make sure this didnt happen again.
She will no longer use Purex® Complete 3-in-1™ Laundry Sheets per my recommendation.
The sheets were designed to keep you from wasting money on using too much soap with the added ease of it also being a fabric softner sheet. Dont be lazy and dont use these sheets in a front loader of any brand.
The problem is that small articles of clothing like baby socks, and these sheets, make it thru the front seal and make its way between the tubs and on to the pump. This does not seem to be a problem with top loading washers yet, but we will find out in the near future.
Levi Holiday
www.lartoday.com
on Dec 09, 2009 | Washing Machines
Cabrio washer won't fill normally but diagnostic shows valves are fine
when doing the diagnostic testing machine fill up almost full and stop display an ol mode
Apr 17, 2013 | Whirlpool WTW6400SW Cabrio Washer
Hi my beko wma510w is working fine accept that when it goes into ajor spin in seems to bang intermintantly it seems fine then bangs then seems fine again any ideas i dont think its the bearings as my last...
Hi from retired Englishman in SW France
I would start with the following guidance ;-0)
I mostly answer front load problems but ' out of balance' is a common problem with both!
So- I don't know your particular machine but the initial cure is the same.
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine (sorry about my UK spelling!) and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning.
Good luck,
John C
Mar 01, 2011 | Washing Machines
Creda Concept Solarglo Cooker. Grill not working. Elements seem ok as top oven works fine. Any ideas gratefully accepted! Thanks in anticipation.
Most common problem is that the grill element is probably faulty/blown. Also check the wiring at the grill element terminals as wiring sometimes burns off. The grill controllers don't normally get faulty as they generally last a lot longer than the elements.
Feb 11, 2011 | Ovens
I have a Royal JS2 shredder not working
I have the same problem with my machine. It started when I turn the switch to the midle before the machine was completely stopped. I took the lid off to have a look the inside. I believe that it is a problem with the elctrical part of the machine and therefore I cannot fix ti by myselve.
Nov 24, 2009 | Kitchen Appliances - Others
Customers sometimes get "Failures" faxing orders to us.
They might have DSL or some other digital fax line.
May 29, 2009 | Office Equipment & Supplies
Machine working but not brewing coffee
Hi mate, Check the water - in pipe to ensure there is no blockages/. also check up around the group head to ensures old coffee ground have not been left there and gone hard.
Jul 31, 2007 | EXPOBAR Office Pulser Espresso Machine
HP LaserJet 4345mfp All-In-One Printer Logo
Seeker5211
Seeker5211
