Question about Canon PowerShot A430 Digital Camera
Batteries draining Hi My camera drains the batteries within 5 minutes of inserting them. I don't think it's the batteries as my partner uses the same ones in his camera and doesn't have the same problem. Any advice would be greater appreciated. Thanks Kathryn
  • 5 more comments
  • katewood Dec 22, 2007
    Many thanks, I'll do as you suggest.
    Kate
  • emglow Dec 25, 2007
    I also replaced both batteries and still have the low battery indicator flashing. Any suggestions?
  • Anonymous Jan 08, 2008
    Loaded new batteries
  • Tom55 Jan 15, 2008
    I am having problems with battery life as well. I have tried branded, cheap and nasty, and rechargeable batteries but still with the same problem. Anyone got any ideas?
  • hawk24s Feb 10, 2008
    I have used coppertop (Duracell) batteries mainly in this camera, and everyonce in awhile I use energizer, but it seems to hold no pattern as to when it will do the same thing. It will all of a sudden display "change batteries", promptly shut down, and then upon replacing the batteries, it will do that again......very frustrating! I lost the receipt during a move, and now I have a camera, that I can't use! It is relentless with shutting down.
  • Eman37 Apr 10, 2008
    My daughter's camera is having the same problem. Battery output is fine. Is there a problem with this model camera? Has anyone heard from Canon?
  • Anonymous May 03, 2008
    I have the same exact problem
    Genius:
  • 2,985 Answers
Check that you DO have the correct batteries for YOUR camera in power out put .
If you have according to the manual then contact the Canon as this could be a fault.
Posted on Dec 22, 2007
TGA Mystere mobility scooter. Scooter drives perfectly but drains batteries within 5 minutes of driving. Have tested with brand new batteries but still does the same. Help!
Hi again ring TGA PARTS FOR A PRICE ON CONTROL BOX 0117 329 1740 good luck i think u need to check THE BATTERIES condition buy a BATTERY LOAD TESTER .OF E/BAY COST APROX ,$35 ,.THIS WILL GIVE U A TRUE READING ON THERE CONDITION,,. Cheers
Dec 27, 2016 | Health & Beauty
Batteries die
have you tryed rechargeable batterys on it. thats something to try for a start.
Jun 10, 2008 | Nikon COOLPIX L3 Digital Camera
Hi I put new batteries in the camera and it comes up after a few minutes please replace batteries Thanks
I hope the camera is pulling the maximum out of ur batteries and so your batteries are getting drained soon. One better solution for your problem is to go for rechargeable batteries. They will reduce the cost on which u r spending for your batteries. You can charge it and use it when it is getting drained.
Aug 02, 2010 | Cameras
Batteries are being drained. We barely use our camera and the batteries are being drained after only a few photos being taken. Camera is rarely used, maybe twice a day. At the most 5 pictures per day. ...
there seems to be a short if you have already tried replacing the batts then yes there is a short taking the power have it looked at by a lic pro
Jun 18, 2010 | GE A830 Digital Camera
My battery drains out within 15-20 pictures on the A550. What is the reason? I am using Eveready Duracell batteries. If I just remove and insert the same batteries again it takes about 5-10 pictures more....
digital cameras are just like leeche for batteries.even if you spend a thousand rupees for an imported alkaline it would go off in 20 mins.get yourself a rechargeable NiMH batteries.
May 29, 2010 | Canon PowerShot A550 Digital Camera
Battteries depleted messageon Pentax Espio E40, even though have tried brand new batteries.
HI. this seems to be a battery scanning fault in the programming. try to reset the board by pulling the battery and removing all power of 30 minutes. completely drain all power from this unit for 30 minutes. if this message continues after you have rest the programming, this will confirm a serious fault within the internal program. you will have to send this device back to a pentax repair terminal for reprogramming.
May 22, 2009 | Pentax Optio E40 Digital Camera
Kodak Z1085 IS - drains battery even when camera is not on
the camera takes 1.5v to operate it
anything less the camera will shut down
recharge batteries are only 1.4v so at full
recharge it won't last long
The best batteries are litheum that have the right
volts and capacity to keep the camera going.
try turning or the camera stablizer setting...
might save your battery power.
Mar 17, 2009 | Kodak EASYSHARE Z1085 IS Digital Camera
Immediate Battery Draining
I had the same problem with my A345, it got worse and worse until now, everytime I try to take a photo the camera turns off. My brother has the same camera, his also does this.
Dec 02, 2007 | Fuji FinePix A345 Digital Camera
Battery drain on Canon zr70mc
If you have the idiot proof switch on, it makes everything AUTOMATIC and drains the batteries fast. Open the LCD door and check if the switch is in the wrong position and change it. Go into the menu and set thing s the way you want them. The more Auto stuff you have on, the faster the battery goes. Are you using a light? Even using the LCD uses more power than the viewfinder. Also, batteries do go bad. It's best to run them all the way down and recharge, if you haven't been doing that, short life. I buy my batts on ebay. Instead of one for $150 I get 10 three hour batteries for that.
Sep 16, 2007 | Canon ZR70MC Mini DV Digital Camcorder
Recurring dead batteries
Get it serviced to find out if it is repairable or only insert battery to use then remove when not in use
May 10, 2017 | Canon EOS Rebel T2 35mm SLR Camera
Canon PowerShot A430 Digital Camera Logo
120 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
