Question about Boating
I need to know what to set the carb ajustments at
  • William Slattum May 11, 2010
    Make model engine please.
  • Carl
    Carl May 11, 2010
    In order for us to help you with your free question,, you would need to be allot more spesific with your question.. Like - what motor,, year,, make,, model,, size,, etc.. Please clarify.. Have a great day !
  • 86 Answers
Turn the idle mixture screw 1 1/2 turns out from being seated. Then with the engine running in gear under a load in the water turn slowly clockwise. When it starts to die then go a half turn counter clockwise. That is your correct fuel mixture and you should readjust it anytime you have a change in altitude.
Posted on Oct 16, 2009
Wot is float setting on a rd125lc mark 1
not sure with bikes but the float is in the carb on older cars you could ajust the amount of fuel going into carb fuel chambers but i know nothing about bikes dont know if this is any help
Oct 19, 2014 | Motorcycles
Diagram of carb to ajust the screws to make mortor work right
!. or
2.
Are where you might find details since you have not mentione make/model of your motor.
May 10, 2012 | Motorcycles
I have a 2003 ttr 125l and I nned to rebuild the carb. after installing the new needle and float, what other ajustment do I need to know?
If you have set the float properly and the carb is clean, other than changing the air filter and cleaning the intake tract I would pull the gas tank, dump the fuel and remove the petc0ck - there is a small filter on it that should be cleaned or at least checked. Fill it with fresh fuel.
Other than that - you should be good to go! Good luck!!
Scott
May 27, 2011 | 2003 Yamaha TT-R 125 L
Ryobi bc30 idle and run probloms; plastic ends on ajustment screws on carb keep you from ajusting carb. how can you ajust. can start with chock but will not run with chock off.
mmarote, this is what I did to solve that problem....remove carb...take a hacksaw or dremel tool and cut or grind slots straight across the centers of both screws deep enough to get a thin bladed screwdriver in the slots....turn to adjust....et voila....
Jun 25, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Wont start unless i pour gas in carb throat, MTB snow blower. float ok, gas is good to feed .MTB snow blower. I'm sure carb problem, what to do next?
depending if you have a ajustment on the bowl you will need to ajust to get the right mixture if this will not fix your problem then you will need your carb rebuilt
Feb 08, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
Does anyone know the carb. setting for a Homelite 45cc chainsaw. Or set up procedure??
Start 1.5 CCW from lighty seated then do as the link suggests.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
Dec 28, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
What are the high and low carb settings on a stihl fs76?
high 2 turns out and low 1 and 1/2 turns out
after you get runing up operrating temp ajust
again throttle wide open ajust high neadle and
win idle ajust low neadle
Jul 18, 2009 | Oregon Scientific Complete Carburetor for...
Want stay running
try ajusting carb did get better.if no rebuild carb and ajust carb again should fix your problem low needle 1 turn out and high needle 1 1/2 turns out this will get it runing and you might ajust again run full throttle to ajust high needle.let me know if this help you.ok
Jul 14, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Fuel lines rotted replaced them. carburation is off how do i reajust the carburator it has two small ajustments side by side and one large ajustment above it i think the one large one is the idle screw i...
large adjustment is the idle
if it is a zama carb then 1 turn out each
if it is a walbro carb. 1and1/4 out each
preliminary adjstments they will have to be tweeked after its running or maybe not
Jun 10, 2009 | Craftsman Garden
Boating Logo
77 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
