the hard drive should have diagnostics under the bios run on it..
get in the setup area right at the beginning on the starting process... like hit F2.. right away at boot up
see if there are built in diagnostics for testing your hard drive... this is usually the case
if not
get a copy of seagate or western digital diagnostics testing software and place the software correctly on a cd... boot from the cd... and execute the diagnostics on the hard drive in the laptop
this will determine if the drive is good or not
tell me the answer and we will solve the problem from there
why does the netbooks allow games to be played and how can i speed it up on the wi-fi.My netbook...
(More)
why does the netbooks allow games to be played and how can i speed it up on the wi-fi.My netbook runs so slow why is it when its hooked up to the wi-fi connection?
i can not get it to boot of the windows xp installation disk.(this is a bootabl disk) i have change...
(More)
i can not get it to boot of the windows xp installation disk.(this is a bootabl disk) i have change the 1st boot as cd drive yet this did not work and also tried other options like when it first start up pressing the esc key it brings up the menu and gives you the option to select which drive you would like to 1st boot drive selecting cd yet it still does not start from the cd i have also tried external cd rom and using removable drive still no joy so how do i install windows xp or any other OS on cybercom fid2010
i have an acer 5520, that was running great then froze while being used. when i restarted it showed...
(More)
i have an acer 5520, that was running great then froze while being used. when i restarted it showed the acer screen then went blank and stayed.. after a few days i tried again an now when i turn it on it goes to startup repair which say your computer was unable to start. and it just searches for problems and finds nothing
