Question about Arcsoft ShowBiz DVD 2 (3265)
I have ArcNB0,ArcNB1,and ArcNB2 files (NBZ files) which I cannot open. What software do I need to open them?
Aspire 5750 keeps showing a message There is no associated program to perform the requested action and will not operateon windows 7 Home Premium. What can I do? . What can I do
What type of file are you trying to open? Are you trying to watch a movie, open a document that was written on an older computer, or some other file?
If the software that should open the file is on your computer but not associated with that file type, right click on the file and choose Open With > Choose default program. Then Browse through programs on your computer (Program Files and Program Files (x86) and their sub folders). Alternatively, click Start > Control Panel > Programs. Under Default Programs, select Make a file type always open in a specific program. Scroll down to the extension and add a program for it.
Many computers do not come with all the software you might want. In that case, you will need to get the software or a plug-in to add to your software. For example, a computer with a Blu-ray optical drive may not have the Blu-ray player software. Office files may have similar limits. (WordPad reads Word files; Excel and PowerPoint viewers aren't always included.)
I hope this helps. Please add a comment with the file type you need to open for specific program suggestions.
Mar 21, 2013 | Acer Aspire 5750 15.6 inch Laptop Intel...
Tip
How can you crate setup file or .exe using QT platform
We are developing software but we are unable to run in others PC/Computer. As we know that QT is Platform Independent and Open source Software, which is use Nokia to develop Mobile Application.
Needs:
  • Qt
  • Setup creator
  • libgcc_s_dw2-1.dll
  • mingwm10.dll
  • QtGuid4.dll
  • QtCored4.dll
Procedure:
  • When you start a project then automatically qt creates 2 folders within main Directory. One is "Debug" and another is "release".
  • If we are want to run application in other PC then we need ".dll" files and combined them.
  • Open My Computer and go to the "Installation Drive" where QT is installed.
  • Find out the Main Directory of the QT. If you install in "c:" then go to the c drive and open "qt" folder and get a directory name as "2010.01"
  • When you open "2010.01", then you can see another directory as "qt" open it.
  • You click on Search option from the "Standard Button" bar and type the libgcc_s_dw2-1.dll file and search it. When you find it copy the file and paste into your Project Directory's "Debug" folder. Do same things for another three ".dll" files.
  • After that you can run your application by the .exe file. Does not need to open Qt and open your project then run.
  • Now you can simply copy the project Directory and paste into other PC and open Directory and run it.
  • Or you can create a shortcut on the desktop as others software. From where you can run it by Click.
Deploy and Packaging:
If you want to create a setup file as other software, need to install it. Then -
  • First download a file "icinst", it's free. After that install it.
  • After that open it from start programs and windows will be come where you select your Project Directory and do "Next".
  • You can create a License Agreement as others software.
  • Do as per the given Instruction.
Note: Before create a setup file you must be collect all dll files and paste in "debug" folder
Imon Saha
on May 16, 2011 | Computers & Internet
I cannot open an email attachment on microsoft office 2007. what seems to be the problem?
What type of Attachment is it?? If its a .zip, .rar (compressed) folder you may need a software to open this attachment for you. If it is a .Pdf file you will also need a software to open this type of document. I would recommend Peazip (google Peazip and download/Install) to open compressed files from E mail attachments and extract them to a format Microsoft Office will open (assuming they contain files for MS office). For .pdf files I would use Acrobat Reader (google and download/install) Or Foxit Reader (google and download/install). I hope this helps you get what you need. If you have any other questions please feel free to ask.
Ryan
Feb 26, 2011 | Microsoft Office Professional 2007 Full...
The software erased from its memory the video footage that I needed last week. I have retrieved the deleted file from the backup with another software but can't open the file now. Is there any way that I...
The easiest way to fix this is to find out what the file extension is.
Example: word.doc
doc is the file extension.
If you can't open the file. Search on the web for the file extension and what program to open it with.
"How to open .doc" in the search bar.
Hope this helps!
Aug 01, 2010 | Computers & Internet
Cant open an nrg file
An NRG file is a file associated with Nero burning software. An NRG file is an image file, and can be converted using NRG2ISO.
Either way, you need Nero's burning software to open it.
http://www.fileinfo.com/extension/nrg
Jan 24, 2010 | Allied Telesyn Computers & Internet
I am unable to open jpeg files. Need to install ?
was it opening before . try restore if it was . try downloading any image opening software .
Oct 19, 2009 | Microsoft Windows Vista Home Premium with...
Have simple tech 320bg , backed up files using the onboard software.... files show up and I can actually move them back up to new computer but.... can't read file (ext = NBP/NBZ file) also looks like I...
Sorry, best I can do is advise next time don't use the backup/restore s/w that came with the drive. I own the same one and found Windows Backup works flawlessly. In fact, if files are still on orig computer, re-back-them-up using Windows Backup and restore to new machine same way.
Apr 24, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
I cannot download or open any msi file type.
It just, no application can open that file so windows is suggesting to search for application to open/run that kind of files. Say example you have pdf file and you don't have adobe reader or application that can open pdf format it will flag that kind of message for you to be able to view/run it.
Hope it helps.
Apr 24, 2009 | Dell Inspiron 1720 Notebook
About .rar file
mikeyaro,
  • The .RAR file is not a multimedia file. Its a RAR archieved of compressed files and/or folders of WinRar format. To open these compressed files/folders you need the WinRar software, any other software which can expand these files.
  • For a trial of WinRar click here
  • Make download and try to open your .rar file.
Thanks
Iqbal
May 01, 2008 | Computers & Internet
Arcsoft ShowBiz DVD 2 (3265) Logo
158 people viewed this question
Top Arcsoft Computers & Internet Experts
Piyal Perera
Piyal Perera
huzaifa mahmood
Are you an Arcsoft Computer and Internet Expert? Answer questions, earn points and help others
