Question about Dryers
Kenmore electric dryer won't stop running / no heat! 110.62512101
I set my Kenmore electric dryer (has 110.62512101 on a tag on inside of door rim) to dry while we were gone... came back 8 hours later to find it still running, and no heat.
The thing only shuts off if I turn the knob manually to "off".
Usually, I just turn it to 60 and return in an hour.
    Sergeant:
  • 288 Answers
Without anymore info. is sounds like the timer motor on the setting controller (the main knob) is bad. The entire timer/control part is usually pricey but if its made to where you can just change the timer motor that will be less. If possible check the timer motor with a meter for continuity to be sure. the parts supplier will usually help you with this, if they are worth a shit.
Posted on Dec 19, 2007
Kenmore 80 series dryer won't start.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch this part testing video.
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Aug 21, 2011 | Dryers
I have a kenmore 80 series electric dryer it was deying cloths and just shut off . now want come back on . what would cause that to happen
Hello there and thank you for choosing fixya
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch the part testing video at the bottom of this page. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached. tbirdfan1_95.jpg
Jul 31, 2011 | Kenmore Dryers
The dryer won't stop running after a heating
Hello, Thank You for using FixYa. I will be helping you today.Replace the timer.It has a bad contact.
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Kenmore 64882 Electric Dryer
Stopped heating
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 18, 2010 | Kenmore 62602 Electric Dryer
My Kenmore 90 series electric dryer not running
http://www.washerwizzards.com ,,,,check the thermofuse in the back,,it is a white fuse coverd in plastic with 2 wires attached ,,,,hook the 2 wires together and test it
Dec 23, 2009 | Kenmore 63942 Dryer
Kenmore electric dryer heat stays on when door open
Sounds like your thermistor/thermostats could be your problem.
They control the heat coming from the heating coil.
Unplug the dryer.
If you remove the back of the dryer, look for the air tube coming from the blower to the drum, normally inside the air tube you will find the heating coil and the thermistor/thermostats. Replace as needed.
Good luck,
Hope this helps
Oct 05, 2009 | Kenmore Dryers
Dryer will run for a second and sound three beeps and stops.
Sounds like the door switch has gone bad., but your description is confusing.
First, it takes a few minutes for you to feel the air blowing hot, particularly when the dryer is in a cold garage. The heating elements have to heat up the mass of the metal, and any clothes in the dryer.
The timer design is such that it can not speed up (the motor inside wont start running faster, due to it's electrical design.).
I am suspect that the door switch has failed for some reason, because reading between the lines, I think you are saying when you release the Start button, the dryer quits operating. If the door switch is bad, then it will cause that condition to happen.
Jan 18, 2009 | Kenmore 62802 Electric Dryer
Kenmore 110.96588210 Electric Dryer
you can take the top panel back off and check the start button with omes meter,push button in you should get a reading,let button out no reading ,if it fails the test replace,let me know what you find
Sep 22, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
554 people viewed this question
Top Dryers Experts
Marvin
Marvin
