Question about Texas Instruments TI-30XA Calculator
How can i raise to a negative power on TI-30xa
I need to raise a neg power
  • Texas Instru... Master
  • 7,993 Answers
Use the Y to the x key [Y^x]. To enter the negative exponent use the change sign key [+/-] not the regular minus - sign.
Hope it helps.
Posted on Sep 29, 2009
How to remove and replace oil pan gasket on a chevy camaro 5.7 LT 1
safely raise car and support on jack stands or vehicle lift
disconnect Neg. battery cable and insulate
remove engine air duct system
remove motor mount bolts (with auto. transmission)
raise and support engine
remove exhaust/convertors
remove oil pan bolts and pan
Feb 01, 2014 | Cadillac Escalade Cars & Trucks
Window is stuck and wont roll up master power switch broken how to manually pull up window
go on you tube, I'm sure you can find how to take off the door panel. Once you get there, supply positive and negative power to the window motor from your battery, it should go up, if it doesn't ,switch the pos and neg sides on the motor. The motor works by reversing polarity.
Dec 07, 2013 | 1997 Toyota Corolla
1.009 to the 17 power and higher
The TI-30Xa has a "y^x" key located just above the divide key. To calculate 1.009 to the 17th power, press 1 . 0 0 9 y^x 1 7 =
Mar 26, 2013 | Texas Instruments TI-30XA Calculator
Where is th carot symbol and how do you do to the power of and to the negative power
The key is marked y^x and is just above the divide key.
As an example, to raise 2 to the -3 power, press 2 y^x +()- 3 =
+()- is the key between the decimal point and = keys.
May 12, 2011 | Texas Instruments TI-30XA Calculator
How do i multiply 1.04 to the 5th power using the TI-30XA calculator?
To raise 1.04 to the fifth power, press
1 . 0 4 y^x 5 =
y^x is the key just above the divide key.
Feb 20, 2011 | Texas Instruments TI-30XA Calculator
I am trying to figure out how to enter negative logs into the TI-30XA. I have a chemistry exam on Tuesday and we need to be able to do problems with the negative log and I can't seem to find any...
Use the +- key to the right of the decimal point to enter negative values and to change the sign of an existing value. For your sample:
2 EE +- 3 LOG +- =
Nov 15, 2010 | Texas Instruments TI-30XA Calculator
Need color code for kenwood kdc mp 245
black - ground, red - switched or ignition, yellow - constant (memory) power, white - left front spkr pos., white/black - left front spkr neg., gray - right front spkr pos., gray/black right spkr front neg., purple - right rear spkr pos., purple/black - right rear spkr neg., green - left rear spkr pos., green/black - left rear spkr neg, blue - antenna remote, blue/white amp remote turn on.
Nov 02, 2010 | Kenwood KDC-325 CD Player
I need to raise e to a power on my TI 30XA Can you help? Thanks! ammathtype@earthlink.net
Put in the number, press 2nd [e^x], then =
[e^x] is the shifted function of the LN key on the top row of the keyboard.
Oct 25, 2010 | Texas Instruments TI-30XA Calculator
I'm wanting to get the most power from my amp for the sub. Its a 2ohm dvc. If you say series or parallel I'll be confused. Need exact explanation. Thank you.
series is a straight line and parallel is is a big x. come into the connection pos and neg from there hook that to the pos and neg on one side of the dvc.on the speaker take the pos to the open neg and the neg to the open pos
Sep 12, 2010 | Car Audio & Video
How do i divide by powers of 10 in my TI-30XA calculator?
The same way you would divide by any other number. Just use the EE key (just above the 7) to enter the exponent. If the exponent is negative, use the +<>- key (just to the left of the =) to enter the negative sign.
Aug 30, 2010 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-30XA Calculator Logo
617 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
