Question about Maytag Washing Machines
Maytag neptune mah6700a - ran diagnostic board output test. when i tested the drain pump... it makes a weird noise and does nothing.. it keeps trying but just fails with the wierd noise. so i assume this means there is an issue with the drain pump. what should i do to check it?
    President:
  • 1,304 Answers
Unplug the pump
disconnect the hoses
turn pump body 1/4 tun
inspect pump
bet you find a quarter
Posted on Oct 05, 2009
Maytag MAH6700A
have you checked the belt to make sure its not worn and loose? that would be the first thing I would check
Aug 17, 2007 | Maytag Neptune MAH6700A Front Load Washer
Neptune #MAH6700AAW will not drain, how to test control board?
Have you checked lid switch? If bad, unit will not spin and drain.
Sep 12, 2017 | Maytag MAH6700AWW Neptune Front-Load...
I have a maytag neptune front load washer mah9700, and i need to know how to reset it. its on a quick wash cycle, but it has a delay for the door to lock , then when it does, it does nothing. it has a...
The "nd" error code on a Maytag Neptune MAH9700 means that the water level is not draining quickly enough or at all, in some cases a symptom of a restricted drain system or a hose twist. If you have the tools and don't want to call a repair technician, the service manual (found at http://www.applianceblog.com/manuals/16025909.pdf), recommends the following steps:
1. Check for restricted drain system. 2. In cold climates, check for frozen drain hose. 3. Check for 120 VAC at the pump when a spin cycle is selected. 4. Check pump motor winding resistance. (14.2 +/- 7% ohms) 5. Check that the machine control correctly senses the water level in the washer [by performing the] Board Input Test [found in the manual]. 6. [Perform the] Board Output Test and perform the Pump Out Test. 7. Check the Machine Control Board connections at CN10 (Pin 6) for the pump. Should see 110-120VAC.(Refer to the component testing procedure). 8. Check tub to pump hose for twist in hose.
I would recommend trying several of these steps that are within your comfort level. If the problem persists, it may best be solved by a licensed repairman.
Aug 29, 2011 | Washing Machines
I have a Maytag Neptune Washer Model #MAH5500BWW. I am getting an Lr error code. I ran a diagnostic wash and it stopped with the Lr cade and I pushed ^ t continue the diagnostic test. What should my...
Hi
Lr means locked rotor, this issue occurs due to locked rotors, you'll need to check the rotor wiring and motor windings. If the wiring is good and windings are not burnt then you'll need to replace your motor and motor control board. These are sold as one unit, it is a 3 phase motor and one of the phases is bad as a little power surge can damage the boards. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | Maytag Neptune MAH5500B Front Load Washer
The washer does not drain and /or spin
Hello,This unit will not spin if it cant drain.Check to make sure there is nothing stuck in the drain pump. you can access it from the back.Pull the hose off and check that nothing is in the pump...
Jun 18, 2011 | Maytag Neptune MAH6700A Front Load Washer
My washer is showing a sd or 5d in the minutes place and locking what should I do.
Hi
Thanks for using FixYa. Error 5d means too much detergent was used. Try the following procedure---
Run the unit through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent. If still the problem persists, then please check the following things--
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 26, 2010 | Maytag Neptune MAH6700A Front Load Washer
Will not spin or drain during spin cycle and make a humming noise
More than likely coins or other debris have made it to the drain pump. It is an easy fix but costly if the pump is damaged. I have had to remove coins from mine atleast 10 times now.
Oct 10, 2009 | Maytag Neptune MAH6700A Front Load Washer
UC code on may Maytag Neptune Washer FAV6800WW
Continuous Unbalanced Circuit. Improper signal from Tub Displacement Sensor.
Wet Clothes • Very small clothes loads can cause unbalanced loads - add additional towels. • Excessive suds may have been present. • Check Tub Displacement Sensor connection and main harness connector at machine control board. • Check Tub Displacement Sensor for 0 to 3.0 Volts DC output voltage between ground and the board input. Check for 12 Volts DC input voltage between the ground and the board output. Only check for voltage at the Tub Displacement Sensor. Do not perform a continuity check. See Tub Displacement Diagnostics • Excessive motion was detected in spin Run Quick Spin Test with an empty tub to check Tub Displacement Sensor and machine control board. • Check for restricted drain system.
Jun 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
79 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
