Hello. i can help you. begin by checking the power.
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
If that doesnt get it working again get back as there are other things that could have gone wrong.
No lights at all. It's a Dreamaker Model 8003-X-500
Ensure that the GFCI on your plug is in-fact letting power get to the spa by testing either the power at the GFCI its-self or at the spa, if you have power getting to the spa, look for a blown fuse, these are usually large Buss fuses ranging from 20-30 amps and you will not be able to see if the fuse is blown or not without a continuity tester so i recommend just replacing it. These fuses are usually located ont the circuit board or bottomof the metal control box the circuit board is mounted in. Best of luck..
Do any of the lights on the control panel come on? What model spa?
