Question about KitchenAid BCG100 Electric Blades Grinder
I have a coffee grinder kitchenAid model BCG1000 and I need to find a part . The gear on the base was made in rubber and exploded, the one that's connect with the cup. Where I can get it?
4 Suggested Answers
SOURCE: KitchenAid coffee grinder
Apparently we must be the only two people on the planet with this problem. I have a Breville burr grinder that I received as a gift, and it magnetized the grounds directly out of the box. I am considering opening the casing up and grounding the motor through the plug. I would need to replace the 2-prong plug with a 3-prong plug. The casing is made of plastic and stainless steel, so they wouldn't need to ground the chassis, but if the electric current running through the motor or the burrs (attached to the motor) are the root cause then I would think that grounding the metal chassis of the motor through the plug/outlet should do the trick.
Posted on Mar 14, 2010
  • 6 Answers
SOURCE: I am looking for a glass replacement for the
Try contacting Kitchenaid directly. They have a fairly extensive parts department:
Contact Center Hours:
Monday – Friday 8am – 8pm EST
1-800-541-6390 http://www.shopkitchenaid.com/cc_contactus.asp
Posted on Jul 20, 2010
bfreder57674
  • 5 Answers
SOURCE: I need to order the
I found this while searching for shear pins http://www.partselect.com/PS984110-Whirlpool-9707016-Nut-Acorn.htm
Posted on Aug 17, 2011
Where can I get an Kitchen Aid A-9 burr grinder repaired?
Softly Scrambled: Kitchenaid A9 Grinder Refurbishment.
softlyscrambled.blogspot.com/.../kitchenaid-a9-grinder-refurbishment.ht...
Mar 1, 2014 - This is an original A9 from the days when Kitchenaid was owned by Hobart. ... Yes, it worked and would grind coffee, but the motor seemed to labor and the grinds were ... I am now doing this for mine, but I can not for the life of me get to the bushings. Does ... I don't recall a ball bearing from repairing my A9.
KitchenAid Burr Coffee Mill KCG200 (aka A-9) - Automatic Washers ...
www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?44466
Jan 13, 2013 - 49 posts - ‎12 authors
I'll definitely use that cleaning method if I can't get the grinding mechanism .... I'd try lifting the lower burr assembly out with the aid of two flat ...
Kitchenaid A9 Coffee Grinder - HubPages
hubpages.com > Food and Cooking > Beverages
Sep 20, 2013 - Where can I buy a retro Kitchenaid A9 Coffee Grinder? ... are paying for (is it new in box, has it been used for 20 years, or does it need repair).
KITCHENAID A-9 INSTRUCTIONS MANUAL Pdf Download.
Dec 21, 2015 | Coffee Makers & Espresso Machines
Sharpen KitchenAid A-9 burrs
You simply can not sharpen it.
The grinding is not based on actual cutting, but more like crushing. The "knives" are slightly conical pair and you adjust the grain size of the ground coffee by adjusting the space between the two parts.
If it is actually damaged you have to replace it, but if you have been grinding very "oily" beans there might be some left over stuck into the burrs. Then you need to clean it by taking the grinder apart and brush the knives with a stiff brush - do not use soap or water. A stiff toothbrush is just ideal for this.
All the best,
Villi
Apr 28, 2014 | KitchenAid Coffee Makers & Espresso...
How do I clean the inside of the coffee grinder kitchenaid model A-9
Instructions Things you need
  • Soapy water
  • Screwdriver
  • Burr cleaning brush
  • Damp cloth
1 Turn off your KitchenAid coffee grinder and unplug it from the socket.
This reduces the risk of injury while cleaning the appliance.
2 Turn the bean hopper, located at the top of the grinder, counter- clockwise and remove it from the appliance.
3 Slide the coffee bin toward you to remove it from the grinder.
4 Wash the hopper, hopper lid and the coffee bin in hot, soapy water. Rinse and dry these parts after cleaning.
5 Locate the grind control dial on the front of your KitchenAid coffee grinder. Screws are located to the left and right of this dial.
6 Turn the screws counter-clockwise with a flat head screwdriver to remove them from the grinder.
7 Pull the entire faceplate assembly gently toward you and out of the KitchenAid coffee grinder. The faceplate assembly is attached to the back of the grind control knob.
8 Pull out the burr shaft assembly, which is right behind the faceplate assembly.
9 Brush the burr shaft assembly with the burr-cleaning brush included with your KitchenAid coffee grinder to remove any debris or remaining grinds.
10 Reassemble the KitchenAid coffee grinder by returning the burr shaft assembly and faceplate assembly to the appliance. Tighten the screws with a screwdriver to hold the assemblies in place.
11 Wipe down the exterior of the coffee grinder with a damp cloth.
12 Return the clean coffee bin, hopper and hopper lid to your clean KitchenAid coffee grinder.
Aug 17, 2012 | KitchenAid Model A-9 Coffee Mill Grinder
Cannot remover the coffee grinder from machine.
Remove Coffee Maker's top cover. Slide coffee bean container off (after emptying it of coffee beans). Remove fixing screws (normally philips) securing the bean container platform. Remove grinder's bean intake rubber seal. Unscrew the grinder's fine/course selector, paying close attention to where it was originally fixed, from factory. 4 rubber bushing are anchoring the grinder in place, which can be seen from the front of the Coffee Maker (w/ door opened). Wiggle each rubber bushing through, as you pull grinder from the top. Grinder should come loose, after unplugging wires. - Good Luck
Nov 13, 2010 | Miele Coffee System
I am looking for a glass replacement for the receptical for a Kitchenaid top of the line coffee grinder as we dropped the glass receptical.
Jul 20, 2010 | KitchenAid Pro Line Burr Coffee Mill...
Cannot get the grinding ring option to turn
This is a set screw. You need to take this out.
You can access this to either clean the burr
grinding wheel. Maybe this needs changed.
If you google the Kitchenaid A-9 Burr grinder you can get instructions to download on this machine.
Mar 05, 2009 | KitchenAid A-9 Electric Burr Grinder
Parts and Grind Selection
The current Kitchenaid A9 burr grinder glass jar is interchangable with the original Hobart/Kitchenaid A9 glass jar; therefor, the gasket should also interchange - contact Kitchenaid customer service to order a gasket.
Setting the grind is accomplished by grasping the body of the ginder in one hand and the grind-selector ring (collar that the jar screws into) in the other. Hold the base tight and turn the selector ring clockwise for a finer grind, counterclockwise for coarser. Be careful not to completely unscrew the selector ring; if you are not sure how much adjustment is left, screw it all the way clockwise until it stops (finest grind); then, back it off, up to one full turn to make the grind coarser.
The selector ring has the words coarse, medium and fine cast into it; these are rough postition markers. There is a triangle cast into the body of the grinder, just above the brand name, that can be used to diral in a preferred level of grind. I use a medium-coarse grind for drip coffee makers; to do likewise, position the selector ring so that the triangle is pointing midway between the words coarse and medium.
Dec 21, 2008 | KitchenAid A-9 Electric Burr Grinder
Manual meat grinder no longer provides suction
Hi, I know you posted this several years ago but found a solution which might help you or others. I recently bought a used Rival grinder and the base would not stick. I tried to take off the black rubber base to look underneath and turned it about 45 degrees but it would not come off so I turned it back and pressed it back into place on the bottom. Just shifting and replacing the black base fixed it! Also make sure the base is all the way around the bottom and try to place a little water on the base too.
May 14, 2008 | Coffee Makers & Espresso Machines
KitchenAid BCG100 Electric Blades Grinder Logo
119 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
graybeard32301
Ismael Rodriguez...
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
