Home | Xerox | WorkCentre M15i Laser Printer | Xerox M15i paper get...
Xerox WorkCentre M15i Laser Printer
Problem for Xerox WorkCentre M15i Laser Printer
Xerox M15i paper gets jammed above the fuser
By gabriella592 on Sep 29, 2009
Xerox M15i paper gets jammed above the fuser "paper jam 2" fuser is hot but i think its supposed to be. Almost every sheet gets jammed.
Solution #1
posted on Oct 17, 2009
Not Rated)
gilbertgonz8
Rank: Guru  Xerox Computer Hardware  Expert
Rating: 94%, 28 votes
This machine might have the vertical transport guides broken. The tips break when the white plastic guides are stained yellow.
You may need to have Xerox come out to do the repair, there is extensive work involved in replacing the part and other parts as well. You would need to make sure you have ordered the correct parts for this specific model.
Was this helpful?
Yes
No
Solution #2
posted on Oct 06, 2009
Not Rated)
tryit
Rating: 89%, 1279 votes
Yes it is supposed to be hot. Let is sit off for an hour.
Open the right side as if you were removing a jam. You will see 4 silver phillips screws. Remove them, unplug the fuser and slide it out. I think you will find either a paper folded up in the fuser or in the paper path just past the fuser.
The fuser itself probably needs rebuilt or replaced.
Was this helpful?
Yes
No
Popular Solutions for Xerox WorkCentre M15i Laser
Questions and Unsolved Problems for Xerox WorkCentre M15i Laser
Do you recommend Xerox WorkCentre M15i Laser Printer?
Answer
Answer
i have bought a used machine & i am having problems connecting it
Answer
i need a meter reading for a konica magicolor 2400W. How do I do this?
Answer
I enter CREATE PDF FROM SCANNER. Select XEROX M15WORKSERIES. ERROR MESSAGE : CANNOT BE SET TO THIS... (More)
Answer
I have problem in my printer it is not accessing the order threw the my pc
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Xerox WorkCentre M15i Laser...:
Top Printer Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
