Question about Smeg WDI12 Front Load Washer / Dryer
Loud noise coming from machine
I have a Smeg WDI 12C washer/dryer and it's starting to make a lot of expensive sounding noises.
it can be fine for periods and then the noises start again. I initially thought it was the teeth on the motor that had worn as generally it wont spin when these noises happen. I've only had it 18 months so should the motor be packing in as soon as this?
If it is the motor what sort of price would it cost for a new part?
  • 1 more comment
  • JPCLARK Dec 19, 2007
    I'll have a look at that, thanks.
  • JPCLARK Dec 20, 2007
    I had another look at it last night and after a short while it was making the same loud noises again. This time the machine shut down and in the display is showed Sr OP, i dont know it this is some sort of error fault or not.
  • carlos1234 Jan 09, 2008
    i have a smeg wdi 12c washer dryer and it displays all manor of errors and does not drain or spin, it just sits still with a loud noise. this only happens sometimes can you help?
  • 249 Answers
I would say its the bearings in the drum rather then the motor,that would be expensive over $200?
Posted on Dec 19, 2007
  • eamonn close Dec 19, 2007
    watch out for something that might have got caught in the drum,causing noise
  • eamonn close Dec 20, 2007
    I like to able to hear the noise's,I would check the brushs in the motor,but its only 18 months ,they should not be wore.
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' ...
? 4:32
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
I have a smeg washer drier wdi 146 with error code e13. Can you tell me what the problem might be. Thanks
i beleve your door interlock is fautly
or the wiring too it can overheat and cook
so youll need a new one from smeg uk
and check out the connector for any issues
see here for some details
although its a different model i would assume the company uses the same error code setup for all its models
and i would order direct from smeg
Dec 20, 2014 | Washing Machines
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Hi There Our Smeg S650 Washing machine makes a lot of noise whilst spinning. Just wondering what might be the possible problem & if that is something that could be fixed by us or better to call...
Thanks for choosing FixYa and welcome to the site. Any noise the washer makes while spinning usually is traced back to the motor drive ot the spin bearing. This is if it is only while spinning. It will make loud noises. You need to check the motor drive or the spin bearing. One of them is probably bad. The motor drive is what spins the arm. They can go bad or it might be the bearings.
Apr 25, 2011 | Smeg Washing Machines
Gallery ser. front load makes loud clunking sound in all cycles
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Smeg WD1 12C, error code 10
I have a smeg wd1 12c washer dryer showing error code e01 any idea how to fix it?
Nov 06, 2008 | Smeg WDI12 Front Load Washer / Dryer
Noise from washing machine
Oct 25, 2008 | Whirlpool AWG329 Front Load Washer/Dryer
Error code e14
E14 Dryer temperature probe in short circuit or interrupted
Jan 29, 2007 | Smeg WDI12 Front Load Washer / Dryer
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Smeg WDI12 Front Load Washer / Dryer Logo
420 people viewed this question
Top Smeg Washing Machines Experts
Tom Chichester
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
