Question about Sanyo DP42746 42 in. Plasma Television
I have a 42" plasma tv that was going off every once and awhile but if i unplugged it and plugged it back up it would work. it will not work at all now. is this going to be a costly job.
    President:
  • 1,124 Answers
It is probably the power supply unit in the tv..
It should run around $150.00 to $200.00 to fix..
However - it would need to be tested to be diagnosed properly..
There are allot of shops tat will offer a free estimate..
Or maybe apply the estimate fee as credit to the bill if they do the work..
Have a great day !
Posted on Sep 29, 2009
Panasonic 42 tcp42x3 plasma tv turns off after 5 minutes solid red ligh no blinking will turn back on if I unplug and plug back in but off in 5 mins again
The fact if unplugged etc and tries to function means a micro related problem---if unplugging all units for a while does not change this then suspect a power supply or main board (controls all functions).
Oct 15, 2012 | Panasonic 42 TCP42X3 42 Plasma TV
LG 42" Plasma - remote wouldn't turn off TV, nor
unplug for a couple of hours. the tv holds charge and bleeds off electricity very slowly.
Mar 22, 2011 | LG 42PG20 42 in. Plasma HDTV
I have a Hitachi 42" plasma/ 42HDT51 and the power
Replace your buffer boards they are two unit located on the right of the plasma if you are looking the plasma from behind. Do you have any sound?
Thanks,
Nov 21, 2010 | Hitachi 42HDT51 42 in. Plasma SLC1551AW
42PF9630A 42 in. Plasma Television: hi there, I have a phillips 42 inch plasma flat...
This is because the power switch operated the socket that your TV is plugged into. Unplug it and plug it in another socket that is not operated by a switch. Appliances should not be plugged into a socket operated by a switch because of the inconsistency of power to the socket. Lights are about the only thing that should be plugged in.
Dec 23, 2017 | Philips 42PF9630A 42 in. Plasma Television
Toshiba 42DPC85 Won't Turn On
Hello!
I'm adding a "Troubleshooting" part of the manual to this TV.
Hope it will help!
https://manualsbrain.com/en/manuals/981801/?page=45
Nov 16, 2017 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
I have a hitachi p50x01au plasma and I was just watching tv and it turned off by itself.I tried to turn it back on and all I get is a green blinking light.Do I need to call a technician?
you need to unplug power cord from back of tv and let it set for awhile then plug back into the back of the tv i also have a plasma and it sometimes does that also
Jan 06, 2010 | Hitachi 42HDT79 42 in. Plasma Television
42"doesn't turn on
your power supply board is going out.
Dec 06, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
My Hitachi comes on but no cable picture unless I
now do you have a cable box if you do disgard
if not tray to rescan for chanels and after the tvv is done scaning
hit menu
then
setup
then
rest software
then
no for resting the tv to the manufacter setting after going off
and that would take care of the problem
Jul 30, 2009 | Hitachi 42HDS69 42 in. Plasma Television
42" Plasma Cycles on/off when turning tv on
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 29, 2009 | LG 42PX5D 42 in. Plasma HDTV
Green Screen
what you can do is take off the back pannel and there is a cord on the top of the board that looks like a computer board, there are many boards in the TV but the one I am talking about is twords the bottom where the video jacks plug in to the TV. Ok once you have located the pannel there is a cord on the top kinda tword the right side, it is many wires inside a black covering. What you need to do is just simply unplug it and plug it back in, do this as many times to try to get it to work. If that doesn;t work you can replace the cord and if that doesn't work then the screen is out and would cost WAY too much to fix, you could buy you a new name brand TV.
Dec 12, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Sanyo DP42746 42 in. Plasma Television Logo
50 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
