Question about Canon PIXMA MP130 All-In-One InkJet Printer
Waste ink absorber is full How do i empty it - Canon PIXMA MP130 All-In-One InkJet Printer
    President:
  • 2,306 Answers
You can't empty that one, you need a shop to replace the pads which are under the printer, and they can reset the waste ink counter at the same time.
Posted on Sep 29, 2009
    Problem Solver:
Waste ink full
Posted on Sep 30, 2009
Message about ink asorber full keeps appearing
When the printer is not being used, the print-heads slide to their "resting" position,
in order to keep the ink-jets moist, i.e., to NOT dry-out.
Some ink is absorbed into that INK-ABSORBER.
Now, after a few years of usage, that ink-absorber is "full".
Like taking-out the garbage from your kitchen waste-basket when it gets full, and replacing the full waste-basket with an empty waste-basket, it's time to get your printer serviced -- replace the "full" ink-absorber with an "empty" ink-absorber.
Note that CANON printers do not actually "measure" the fullness -- they electronically estimate the fullness, given information about how much you print, and how often you print, and the "density" of the pages that you do print (text is much less dense than colour-photos).
Mar 09, 2011 | Canon PIXMA iP1600 Printer
Tip
"The waste ink absorber is almost full" message?
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there.
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
on Apr 02, 2010 | Office Equipment & Supplies
Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
Error Number: 1700 The waste ink absorber is almost full. What is it? Where do I get a replacement? How do I replace one?
Not all the ink that gets pulled out of an ink-cartridge reaches the paper. Some of the "ink" is "waste". As such, it goes into an "absorber" (a sponge). The electronics inside the printer "predict" when the absorber is getting full, based on the number of pages you print, and the time between printing pages.
So, take your printer to a qualified printer technician.
They will empty the absorber, or replace it,
and "reset" the electronics inside the printer,
to indicate that the absorber has become "empty".
Sep 08, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Waste ink absorber is. full. How do I empty it?
The waste ink absorber can sometimes be removed and cleaned out and put back into place. Although it is not always easy to get at. Usually once this happens it is time for a new printer. You can also contact Canon and see if they have a replacement part for this.
May 28, 2010 | Canon PIXMA iP2000 InkJet Printer
Full ink absorber
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Jan 02, 2010 | Canon PIXMA iP90 Mobile Printer
Canon ip 1300 ink absorber is full. how to empty
you can not empty it without going to service centre?
Aug 15, 2009 | Office Equipment & Supplies
Waste full
The waste ink absorber is a piece of sponge that (as its name implies) absorbs waste ink. On many Canon printers it an be removed if you are fairly dextrous. Wash it out and dry it and then refit. It may well be a fiddle but it will go back in.
The difficult bit is resetting the printer so that it knows the absorber is empty.
Do a google on resetting the waste ink warning for your particular printer (it's not the same for every Canon). It's done with various combinations of button pressing and light sequences and generally works first time (though one of mine took 4 or 5 goes before it actually reset).
Jul 26, 2009 | Canon Office Equipment & Supplies
Indicates waste ink absorber is almost full on cannon i9900 print
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
The waste ink absorption pads cannot be emptied, only replaced.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 16, 2009 | Canon i9900 InkJet Photo Printer
Ink waste absorber
Waste absorber is full. Where is the waste ink absorber and how do I empty it?
Apr 08, 2009 | Canon PIXMA iP1600 Printer
Canon PIXMA MP130 All-In-One InkJet Printer Logo
354 people viewed this question
old marine
old marine
